Originally Posted by
KTE
Hmm..
Ace: I had their first one as I mentioned earlier, it was no good over other TEC/low WC units or even over many air units. But if you can run 3.5GHz idle/P95/OCT load I can tell you if theres something wrong with your unit/fix/sensors or not since I'm aware what it gets with 130W TDP QX6700 at 3.4GHz, and Penryn is supposed to be much cooler with less leakage.
First of all, before you do any comparisons, we need to get Penryn crocked up temperature readings sorted. I'm looking at your idle 3GHz here, what is the ambient heatsink temp please and what are the idle TRUE temps/volts?
Also, can you put some more stress on it to see load temps? Like Systools 16M for instance.
Looking at that, its saying, a 130W TDP processor and an air heastink/fan vs a 250W rated cooling unit both dissipate the heat just as effectively until you oc. That said, if you top the TDP capacity of the Coolit unit, it won't be able to cool the CPU. Hence, try backing down to stay near 250W (rated)
If for instance, if the QX is TDP 130W at 1.1V 3GHz, then this should be the voltage/frequency needed to achieve the max.250W rated heat load possible by the Coolit, no more;
130 x (3562/3000) x (1.4²/1.1²) = 250
i.e. 3.56GHz @ 1.4V.
If you test that, the results would be interesting and much more accurate compared to the TRUE since it's within the Coolit specified limit.
