Is that GPU clock @1.15V?
Very nice clocks! Looking at others card clocks we both are quite lucky to be @860MHz GPU :) .
And your score is far better than I can do on AMD for now, but you can compare to similarly priced 8800GTS 320 scores if you wish!
Congratz!
@ChaosMinionX Flash it to Pro and check for yourself if it's better! I'm on nVidia chipset BTW.
@Ownage Can your GPU go higher? have you tried up the voltage a bit?
