@ Ka Lok & Darkatom...
Do you guys have a work log for your rigs... I would love to see them?? ;)
My TJ-09
http://i144.photobucket.com/albums/r.../SS100120a.jpg
http://i144.photobucket.com/albums/r.../SS100119a.jpg
I do have some plans for it, just need the funds first.
front intake
http://www.techpowerup.com/gallery/1315/__6.jpg
inside view
http://www.techpowerup.com/gallery/1315/__2.jpg
http://www.techpowerup.com/gallery/1315/__9.jpg
entire case
http://www.techpowerup.com/gallery/1315/__1.jpg
http://www.techpowerup.com/gallery/1315/__3.jpg
http://www.techpowerup.com/gallery/1315/__7.jpg
http://www.techpowerup.com/gallery/1315/__5.jpg
lower compartment with the 2 pumps
http://www.techpowerup.com/gallery/1315/__8.jpg
Woah really nicce setup Sir Stunna Lot.... got a work log??
and also... @ Ka Lok & Darkatom... I would love to see your work logs too... if you have them?? :up:
Hello i'm french i don't speek very good english.
My TJ09 :
http://img232.imageshack.us/img232/3...0062el4.th.jpg
http://img232.imageshack.us/img232/3...tre1jo1.th.jpg
Hi Junkee,
Sorry its taken so long to get back to you. Got distracted by xmas and food!
Dont have a work log but have given a summary of what Ive done in the following link
http://www.xtremesystems.org/forums/...31#post2645131
Hope this helps!
You know, despite having been a Silverstone fan for a couple of years- I have both a TJ06 and a TJ07- I can't help but notice how shoddy I think their window treatments are.
The disparity between how they treat grillwork- which is formed and flush fit- and windows- just a slab of Plexi bolted to the panel- is very odd.
It's like they thought of the window just as the case left the factory and used the most expedient solution.
I wonder if this will change or will the window panel remain the red-headed stepchild of the design aesthetic?
Hello,
My Silverstone TJ09 CLEANED.
http://img169.imageshack.us/img169/8871/img00001mi2.jpg
http://img152.imageshack.us/img152/7997/img00005pe2.jpg
hi i am new and this is my 1st custom wcs here are some pics of my work...
http://i27.tinypic.com/2qauu5k.png
http://i27.tinypic.com/2qkidr7.png
http://i31.tinypic.com/2rr1b7t.png
http://maxupload.com/img/48195928.png
http://maxupload.com/img/999DEF53.png
http://maxupload.com/img/EF1F60F6.png
http://maxupload.com/img/89B5C67A.png
http://maxupload.com/img/70CC59AA.png
http://maxupload.com/img/61F1E16B.png
^^^ thankx when i change it next time i will try blue.. let me photochop and see..
Jay78, i think the orange looks awesome. cant say that i remember seeing orange coolant before
The orange coolant looks fiery hot! o.O I'm sure it's cool though :D
i got my subfloor finished...
Hello sorry for my english i'm french :
http://img177.imageshack.us/img177/2122/img00009hl9.jpg
http://img120.imageshack.us/img120/2659/img00001lz1.jpg
http://img238.imageshack.us/img238/8...g000092dk7.jpg
http://img408.imageshack.us/img408/9105/img00010vl7.jpg
http://img179.imageshack.us/img179/6281/img00020tp7.jpg
http://img128.imageshack.us/img128/694/img00025dt8.jpg
http://img179.imageshack.us/img179/4425/img00037nv5.jpg
Well here my contribution to the SilverStone Shoecase thread. Its a Temjin SST-TJ03 case and are older pictures. I since have upgraded to all new components (see sig). I'll post pics with the new guts later mean while here it is.
http://img.photobucket.com/albums/v8.../PICT0012w.jpg
http://img.photobucket.com/albums/v8...ICT0086aza.jpg
http://img.photobucket.com/albums/v8...ICT0069aza.jpg
http://img.photobucket.com/albums/v8...ICT0079aza.jpg
i love the TJ03. Tubing could do with a clean and some blue UV coolant then it would be pimpin.
@ Scooby
Where did you find those awsome springs/coils in chrome?
I would love to have some of those in 7/16 - 5/8 for my build.
Thanks in advance!
@nzbleach, yeah the tubes and coolent needed changing but it's all cool now as I redid the whole loop for the new gear.
@Vargher Warg, those are not springs or coils their Weilded Nickel Rings (4mm x 3/4"). I found these ring at my local hardware store and thought to myself these would make cool anti-kink for the tubing and the fit snug on 1/2"ID-3/4"OD tubing.
http://img.photobucket.com/albums/v8...ICT0180azz.jpg
http://img.photobucket.com/albums/v8...ICT0173azz.jpg
Here I put them to the test and they passed with flying colors.
http://img.photobucket.com/albums/v8...ICT0186azz.jpg
http://img.photobucket.com/albums/v8...ICT0199azz.jpg
BTW here is the new setup, I'm still doing the fine tune on it, you know all those wires.:up:
http://img.photobucket.com/albums/v8...0PICS/Max2.jpg
http://img.photobucket.com/albums/v8...0PICS/Max1.jpg
Scooby;)
