Whats your max 100% cpu stress clocks?
You're asking for me? Haven't tested yet, I'm having some problems with temperature.
L720B066
1.44Vcore Real
415x9 3.737
http://i125.photobucket.com/albums/p...la/3.73ghz.jpg
This is my 24/7 usage.
Board: Asus P5K-DLX
Cooling:
ApogeeGTX
PA120.3
IWAKI RD-30
I think you should honestly only take primes longer then 3 hours. More the better. Quads tend to fail at 2-3 hours during prime, if the voltage is too low. Otherwise i'll pop my 3.825 which failed at 2 hours 30 min @ 1.46Vcore real.
Q6600 G0 - L723A924 - 4.41 GHz Wp 1024m stable - Vapochill LS [AC] stock - 1.68v (1.63-4 load) - Abit IP35-Pro stock - OP1000 PSU - by - ncsa
And the meaningless screenshot :) CPUz 498x9
List updated :toast:
@ Viper.Br, it's OK we we're all newbs at one time ;)
1) B3
2) L634A700
3) Validation: http://valid.x86-secret.com/show_oc.php?id=241932
4) 3.720Mhz
Prime95
http://img205.imageshack.us/img205/9...loadzt2.th.jpg
CPU : Q6600 G0
Week : L23B010
Clockspeed : 423x9 = 3.807 ghz
Cooling : D-Tek fuzion
Vcore : 1.52
Motherboard : Asus Blitz Formula
http://valid.x86-secret.com/show_oc.php?id=242033
12 hours Prime 95 small fft's stable.
http://img.photobucket.com/albums/v6.../3800final.jpg
got my Q6600 L723A924 today,will test and report soon
CPU : QX6850 G0
Week : L724
Clockspeed : 4xxx12 = 4.8Ghz+++
Cooling : Solid Copper pot + Dryice
Vcore : 1.8v idle = 1.68v max load in 06 cpu test WITH vdrop and vcore mod
Motherboard : Asus P5K, bought P5K-E today, will test it..
Pi time is bad because of crappy memory timings; 5-5-5-15. Cpu test in 06 is low because of 6100GFX card, got 7400 with 8800Ultra when setting was 4.79Ghz.
Wee 1st post in the forums after a long time of lurking :)
Here is my little Q6600. Hoping for better O/C a bit later with a new mobo
and maybe some better ambient temps :)
CPU: Q6600 G0
FPO #: L719B278
Validation: http://valid.x86-secret.com/show_oc.php?id=242740
Cooling: D-Tek Fuzion / Laing D5(Setting 3) / Back Ice GTX 480 - Ambient Room temps : 26 - 30 C
M/B: Abit IP35-Pro
Vcore: 1.6050 Set in BIOS 1.49 - 1.50 Real under load.... this board realy droops :S hope the new P5K Premium will not :)
http://img508.imageshack.us/img508/6...led3qv5.th.jpg
High Guys!
How about max. FSB for these quads? how high can they go?
thanks!
Q6600 G0 - L724A786 - 3.6Ghz P stable - WC D-Tek Fuzion - 1.396v - abit IP35 Pro - by --------largon
http://img80.imageshack.us/img80/663...hz8hzv6.th.jpgPHP Code:Q6600 [B]G0[/B] - L724A786 - 3.6Ghz P stable - WC D-Tek Fuzion - [B]1.396v[/B] - abit IP35 Pro - by --------[B]largon[/B]
1) QX6850 G0
2) L723A658
3) http://valid.x86-secret.com/show_oc.php?id=242768
5) Thermalright Ultra 120 eXtreme
6) 1,3625v in bios, 1,336v idle, 1,328v full load
7) Asus Blitz Formula
4)
http://img207.imageshack.us/img207/3...328vuk2.th.jpg
And some non daily oc :)
Air
http://img264.imageshack.us/img264/2...158vwf9.th.jpghttp://img264.imageshack.us/img264/5...1ghzrr2.th.jpghttp://img396.imageshack.us/img396/4...5ghzak2.th.jpg
LN2
http://img396.imageshack.us/img396/9...torifv4.th.jpghttp://img184.imageshack.us/img184/8...stomub4.th.jpg
Q6600 GO @ 3.77
L726A849
http://valid.x86-secret.com/show_oc.php?id=243080
P5K E ( pencil mod)
Noctua NH U 12
1.50 bios 1.48 actual
I just switched over from P5B deluxe.Here is my first try with this board.Will try to lower vcore.
@ dpa, that is one hefty result, but I'm going to need a stable shot of it running prime for at least an hour or at the very least a quad instance of Pi 32m :)
@ vkostas, welcome aboard :)
1) Q6600 G0
2) L727A658
3) COOLER MASTER GeminII
4) 1,5675v in bios
7) Abit IP35-E
http://img502.imageshack.us/img502/4...75vcorebm8.jpg
Gotcha dragonhunter :up:
L723B284
CPU : Q6600 G0
Week : L23B284
Clockspeed : 434x9 = 3.908 ghz
Cooling : Apogee GT (Bowed)
Vcore : 1.52
Motherboard : DFI P35-T2R
http://img234.imageshack.us/img234/7...rgeftt2nr9.jpg
RLM
