Gnuplot
For as good as the Scythe is, it still excited the shroud+enclosure a fair amount, and generated singing and/or droning noises. Careful rpm selection would find various happy points where the noises were minimised, so unless the Scythe was matched with a non-PWM voltage controller, I would be wary of just slapping it on and hoping for low noise without any annoying excitations. I reckon a PWM controller would just make the droning worse.
T
he Tricod Science was exemplary in its minimal excitation. While overall it's maybe 1-2dBA noisier, it generated less annoying noises across the range, and the noise it made was more of a low rushing roar than any real singing or droning.
Between the two, despite what the dBA rating says, the Tricod Science played far more nicely. The Scythe is better, but you'd need to be really picking about the exact rpm's you run at it to avoid annoying excitations.
Please don't go rushing out to buy anything until I get more fans testing. I'm able to test about 1 fan/day, and there's still a lot more to get through. Plenty of time for a better choice to rear its head yet.
