Keep the great pics coming! As someone said earlier, you could practically build one just using the pics for reference. I have never seen this done with so much visual detail. :D
OK, heres the comparsion between the old system and the new one that leakec (i mean the organisation of the pipes)
The new organisation:
http://www.xtremesystems.org/forums/...&postid=168857
The old one:
As you can see the path of the freon is optimised (on the high side) and always flows down (exept the valve) wich leads to a constant suply of liquid freon to the TXV + the filter acts like and acumulator + filters the freon right before the txv
Here is the sight glass, the pic comes from the old organisation but you can see solder joints of the valve , the old unused cap tube and some freon in it
And here are my crap but unleaking solder joints (i dont braze beacause i dont have a proper torch :/, instead i try to do these joints as well as they can get)
Ok and heres how i mountedthe txv:
1. The tools ^^
Mounting the txv ^^
Txv mounted ^^
And connecting the TXV's bulb to the suction line:
damm i have to wait until moday to view these.this is a 56k nightmare to look at.i just cannt veiw them at all on dial up.
but i know they are good,keep them coming i will get to see them one day.
you might try resizing them some for most of the guys watching.i resize all mine to 500 x500 or something close.
OOoooOO lucky me, it works ^^
They are 640x480, i think its a very nice resolution, a compromise between quality and sizeQuote:
And heres the exchanger all frosted up ^^
The temp after few mins of work (later it went to -38C, the system is unloaded and overcharged a little):
Here is what on the exchanger sits on for the moment (ill make a aluminium casing in the next few mins) and ill start mounting the 2nd stage compressor
Do you guys know does the 2nd stage compressor need to be isolated ?
You use silver solder or tin/lead?Quote:
www.tool-up.co.uk sell propane and mapp and deliver europe wide if you live in a silly gas law country...
]JR[
Gas isnt the problem, poland is a §§§§ed up country where you can buy everything but a good torch is so damn expensive you cant even look on its price O_o And silver solder costs a fortune also..
Arent you worried @ cascade pressures the solder wouldnt hold then?
]JR[
This is the I stage of the cascade... in the 2nd stage ill have to use silver solder :(Quote:
]JR[
No, the 2nd stage compressor just needs to be in a place were it will not get too hotQuote:
Damn, theres a leak and i cant find it :/
you should check your joints
I'm eating the pics up, but I have 1.5 down, I couldn't go back to 56k...would drive me nuts! :D
What kind of torch do you prefer if you could find it?
Thnk God for Broadband:toast: :smileysex :toast:
indeed :toast:Quote:
but i only have 0.5mbit :(
Still better then 56K
None of the joints is leaking :OQuote:
Il seperate my chiller in to two parts and ill see wich part leaks, then divide that part in to two... and so on :O
