vassalle...based on the SL, I'd bet the SM and SH are pretty good fans. The blade geometry is slightly different in the SH IIRC, but that's probably because it's a higher speed fan, and one blade design isn't 'right' for all speeds.
However, if the SM and the SL are based on the same basic design, I'm skeptical about it's 70CFM. The SL at ~1320RPM pushed ~46CFM, so I don't see a bump to 1650RPM pushing 70CFM. The designs could very well be different however.
For your PSU....I believe it comes with a black FM121 (the Evercool version....exact same specs, but CFM ratings are much more sane :rolleyes: ). If you're at its loud point, that means you're probably putting a decent load on the PSU...meaning you'll need another moderately fast fan. One thing about the FM121 is that at 8V, it's practically not spinning....unlike all other high speed fans. So any different fan you put in, will be louder at idle....but being quieter at load. A fan that's strong on a radiator is what you're looking for here :)
