Septim,
Thanks for thinking of me. That's an idea. I have been working with Phelan on the Coolermaster Stacker concept, but first I have to learn how to drill fan holes neatly at the top of the case, in hardened steel, no less.
y can't i see the pics massaville?
I cant find this guy malicious on here... Im thinking of buying a Lan Li PC-7 case and putting a Thermochill PA 120.3 on top in that style but with tube at rear as opposed to at the back...
You have any idea how i can contact him i.e where i would buy those fittings he used to do it? Means all id have to do is drill 12 holes rather then buying a jig and making cut outs etc..
thanks.
The pic from the above post shows rad mounted on top... i would like to do the same... where would i get such silver braces or where would i get screws long enough??
malicious is from hardforums, if you look closely in the threads, masa shows a link to a thread for the forums there with his picureq
I have been studying the forums learning about watercooling using the TJ07. I have started my first watercooling project and have been reviewing the information sources. This was one of the more complete and interesting example but now the pictures are gone. Any chance they could come back or be seen to me?
same here pics are gone.......
massaville?
Seems like he hasnt posted in a while, bummer. Does anyone remember how he did the twin pumps and reservoirs? Im very interested.
Nope, I do have one picture of his rig on my PC.... here:
http://img105.imageshack.us/img105/8485/3000my5.jpg
I too would like some pictures of his build back up... im debating about a new case and it will have 2 loops in it.
Nice WC setup :)
any else got pics of massaville's rig?
If anyone is still looking for pics of my TJ07 project you can find them here. Haven't been on-line in ages and the originals were taken down.
http://cid-b59eedd34cc268a5.skydrive...x/.Public?uc=5
Distilled water, couple of drops of biocide (petras), and some food coloring hehe. I haven't had to touch this loop since I built it. Clean as a whistle with no junk/gunk or clogging. In fact I've never even topped it up, but I'll probably have to do that soon. Easy enough though since I just need to add more distilled water. Make sure you go with acrylic reservoirs as well.
Best advice I can give noobs as well. Stay away from that useless solution like Fluid xp, etc. Waste of money and completely useless. It will make a nasty mess of anything you put together.
