héhé :D
héhé :D
My 0632 GPMW 4000+ is so freaky but had its wall @ 3,3 Ghz and 1,408 V prime stabil under single stage. I tried much more vcore, changed multis and so on but nothing changed. So it is no wonder that I couldnt break the record of starostise...only 3787 Mhz were possible :(
Man nice results congrats on the WR
yep. seeing gianni-gt's 3700+ with that temps i was thinking that a 4000+ with a good stepping could break 4Ghz barrier easy with x12 multi but it seems to be very difficult.. it s just luck :stick:Quote:
Originally Posted by stunned_guy
i found that with the same stepping, the one who has a higher TDP (shown with core temp) is always better.
my 4000+ was 50W tdp and got 65°C in full with only 1.5v under my freezer 64 pro and 21-22°C ambiant
i think i've found the one who can crack the 4ghz, but the guy wouldn't sell it :( maybe i'll win in the lottery, then i pay 1k $ for this baby... :D
Addict :fact:
Hello!
This is a small uppdate of my Old Kab1e 0626FPMW 4000+, I sold it to a friend over att Techsweden.org, whom has a Mach1 and he did, this http://i148.photobucket.com/albums/s...ta/3508Mhz.gif He is aming for 3,6ghz prime next. BTW what is the prime WR for none FX A64´as? Best Regards from sweden ;)
The prime wr for AMD non-FX is about 3530 Mhz from gianni-gt: http://bastel-gianni.ripping.org/ove...4bpmw_3530.jpg
your test is not really stabil because its the false prime with the false test, no blend, large fft´s or custom only !!!
Is there anyone of you who is interested in some good amd athlon64 san diego / clawhammer cpus ? If yes please pn me ;)
next week or so, i'm getting a 4000+ 0633 epmw, so count me in for some action.
hopefully without coldbug. :D
I'm currently lapping my X2 4200+ 0601SPMW (not a very good clocker) and I will see what I can get out of it this weekend with DICE.
dual-cores? who cares :D
Hehe gianni you are right :D
my new 0626FPMW: http://valid.x86-secret.com/show_oc.php?id=178200
water-cooling @ 8°C, vcore @ 1.77V, cpu-temp @ 20°C
You have to get some more...about 250 Mhz. But for water a good job :)
Damn.
I actually got 3 off stock voltage primed for 12 hours @ 36 max load and I was pretty impressed, but these results are amazing. I had no clue! I could prolly do more with the chip, but my Neo 4 board maxes at 255 FSB.
For 24/7 use I think this is a pretty good OC. Should I aim for more for 24/7 stable usee
Any general recommendations?
http://img398.imageshack.us/img398/6...ntocwb4.th.jpg
AMD 64 4000 @ 3.0
Zalman CNPS9500-LED
MSI K8N Neof-F s939
Corsair XMS Dual Channel (1 gig @166 2.5-3-3-7)
Nvidia EVGA 7600gt
Ultra 500 Watt PSU
Aerospeed Extreme Engine 3T Case
Windows Vista Ultimate
little update from my 4000+ under water (+2.5°C).... cpu-temp: 15°C, vcore 1.8V
http://valid.x86-secret.com/show_oc.php?id=178504
tomorrow i'll get my new power-chiller (SC15)... :banana:
Gianni I´m getting nervus... :D But I will be proud if you will catch some records back....our little contest isn't at its end :D
I got my A64 4k+ at 3,2GHz on WC. 3,05GHz max on air :mrgreen:
knock knock.... place 3 is mine... http://valid.x86-secret.com/show_oc.php?id=181353
cpu-temp: +7°C, vcore: 1.9V
omfg, awesome result gianni :toast:
Very nice work my friend! I bought myself a 4000+ (KAB1E 0626 FPMW) which does 3Ghz on stock volts no problem. (28 hours orthos stable) Thinking about getting WC/Chiller to get some more out of it ;)
O BTW, got a nice set of TCCD based ram as well 350Mhz 3-4-4-8 @ 2.9v and got a 280Mhz 2-2-2-5 BH-5 comming my way :)
not bad here some 2x512MB Sticks
@HTT320 1:1 Corsair Twinx1024 3200XL TCCD
Timings 2,5.4.4.7.12.14.4.3.2.4 @ 2,8 Volt + 120 Lüfter
http://img69.imageshack.us/img69/562...0mhzyg8.th.jpg
@HTT335 1:1 G-Skill PC3200/4000 GBLE 2x512 ohne ES
Timings 2,5.4.4.7.17.19.4.3.2.4 @ 3,2 Volt + 120 Lüfter
http://img165.imageshack.us/img165/3...ig02si3.th.jpg
@HTT340 1:1 Geil one PC3200/4800 ES 2x512 without HS
http://img170.imageshack.us/img170/6...nnt2th8.th.jpg
