Don't use clockgen. Use crystalcpuid. It will allow you to lower your multiplier to to 6x, so you can find your memory's max speed.Quote:
This memory most likely won't work in a P5B deluxe from what I've read.Quote:
Originally Posted by GrimReaper
the problem is after I lower multi I cant raise FSB because Clockgen doesnt work.
Just tested the memory... theseQuote:
Originally Posted by madg
But I can't get it work on a Gigabyte GA-965P-DS4 !???
It works on a Biostar.
Madg... Are these the same dimms as yours ??
edit: Lol NoepZor... you have to type quicker ;).
These are really the D9DQW's from Ebay? That guy I know tried it on the Gigabyte and it didn't work.Quote:
He has those sticks:
http://www.computer-tuning.nl/tmp/d9.JPG
Do you have excactly the same sticks (D9DQW and PCB)?
Edit: That guy is Tutti :with:
Guys... 2.0v 850mhz 4-3-3-9.... I'm guessing that's pretty f'ing good. Haven't tried any higher right now, because my board wont go higher without better northy cooling and Im not about to rip this rig apart AGAIN...
I had to dremel my heatsink, my psu AND my case to fit this rig together, cause this MOBO has socket at the very edge of board, which in my midtower means the heatsink leans on the PSU... heatpipes prevented proper seating... took 5+ reseats and a full days work just getting this rig running.
Uhhhhhh....
300 System bus using 800 divider @ 1.8v 4-3-3-9 (so 900 ram)
I like this stuff.
In windows now @ 425 1:1 (850) 1.8v ram 4-3-3-9.
nice looking stuff youve got.sigh just wish i couldve grabbed a set :(
Are these faty's:
http://cgi.ebay.com/2GB-1GB-X2-DDR2-...ayphotohosting
Cant tell. probably not.
cant see the writing on the ics.Quote:
Originally Posted by derektm
can someone explain to me why this is such a good deal?
Fatbody D9, capable of running tight timings such as 3-2-2, 4-2-2 at high speeds of 800-1000mhz with the right voltages. Can handle voltage a tiny bit better than slim d9's we have today and really shine with 2.4v and above. Also, these are in 2GB flavor, very very rare for fatbodies. :)Quote:
Originally Posted by Asazman
So enjoy, is ddr900 4-3-3-9 @ stock volts good?
Yes Lithan it is, talk to me on aim. :D
gotta game
Oh, no biggie, I'm goin out in a few minutes anyway. Did you get the second set in yet?Quote:
hmmQuote:
Originally Posted by EnJoY
affordable?
they dont make em anymore.the deal on ebay is dead.someone might find more but its not likely.
Not yet, prolly gonna go through the same hoops as the first so wednesday or thursday.
One note: even with mounting right... DAAMN chip runs hot. Big Typhoon @ stock vcore (1.325 @ 3200mhz = 50*C load.) Imma recheck mounting and swap out fan for an adjustable rpm.
LOOOOOOOOOOOOL
i bought some cheap 256MB stick of Micron RAM to be my "jump start" stick in case fatbody don't work from straight boot
hell i thought why not give it a bit of a run and see what it does heheheheh :D :D :D :D :D :D (as you would)
how's this for kick arse value ram lol
http://img95.imageshack.us/img95/827...z8msupekj1.jpg
$170 US for 2GB D9DQW Fattys delivered to your door, that cheap enough?Quote:
Oh, and they also turned out to be great oc'er :banana:
hot sh*t!Quote:
Originally Posted by dinos22
Originally Posted by an0nym0us
LOL this RAM cost me $20
have a look at this :banana::banana::banana::banana:
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
621MHz CAS5 from $20 stick of RAM i feel sick :sick: :banana: :eek: :banana:
http://img144.imageshack.us/img144/6...z1msupejt5.jpg
What chips on 'em?
