Actually most of the SuperTalent on Ebay is way over priced.... even if it was D9.Quote:
Ive got my pair of T800UX2GC4 few days ago, didnt expect much, as everyone kept telling the old story about the newer revisions.......but mine are running at
500Mhz 4,4,3,8 @ 2,25V (2,2 in bios), didnt memtest them yet, cause I dont think that the latest ver. of Memtest86+ supports P35 chipset yet, Tell me if Im wrong.....but I did run orthos Blend test (CPU and memory stress test) for few hours with no errors....
Strange bios on this GA P35-DS3, as always with gigabyte, strange options, no CR 1T or 2T, theres something like "option 1" and "option 2" ddr dll overclock?!?!?, im even running them at option1, and getting better latencies and bandwidth, according to new everest........must test with memtest, and see.....so far, so good
Putting together a new rig for a friend. He doesn't have a lot of money to spend to i'm trying to get best price/performance on every piece of hardware. Recent customer reviews say they are still good clockers. I found them on ewiz for 59 bucks. Anyone got a set of these recently and how are they doing?
i have this supertalent with blue heats week 23/06 D9GKX
FSB=500x7 prime stabil timmings 4-4-4-4 on asus p5b deluxe wifi cpu e6600.
or they can drive 5-5-5-15 @600 stabil
http://s4.directupload.net/images/07...p/6wrekjfq.jpg
http://s5.directupload.net/images/07...p/xalkx7b7.jpg
http://s3.directupload.net/images/07...p/n3fi65zs.jpg
A friend of mine have this pair. not D9GMH. but it clocks very well on gigabyte P35 boards, not good on ASUS though.
I have 2 of these sets, got them a few days ago
one set does 4-4-3-8 1000Mhz @ 2,2v, haven't tested stability other than Spi 1m, but it looks promising for now. I have gotten this set up to 1300Mhz 5-5-5-15 @ 2,4v but not it was only desktop stable, crashed as soon i started SuperPI... I am almost certain this set has D9GMH, i will know for sure when i strap my thermalright HR-07s on these, but thos coolers are still some days away..
The other set doesn't look as promising, and i suspect this set has promos or any other kind of crappy ICs:( But i still has to test this set properly, it might just be the fact that this was the first set i tested, and i hadn't done any memory overclocking before i got these sets in...
Does anybody know if it is possible to id the kind of ICs these sticks use without prying of the heatsink?
I've got one 2gb kit at home now with D9GKX & have another set on order. Unable to test just yet as my PC is still half finished.
STT use chips Promos with the kit 6400 4/4/3/8 (Micron D9 too but rare now) :(
I should have mentioned that the kits I have are actually PC2-8000 (T1000UB1G4).
ouch!! I hope they aren't Promos. They are delivered today so i'll let you guys know how they do. If they do well then Ewiz has a sweet deal on em. 60 bucks for a 2x1gb kit.
OK. Got em installed in my machine for testing before i put em in my buddy's rig. Unfortunately my board will not allow 4,4,3,8 so i had to run em 4,4,3,9. No problems @ 800mhz. Cranked it up to 1000mhz and loosened timings to 5,5,5,15 with 2.2v. No problems there either. So far this RAM is looking like a steal for 60 bucks. Gonna see how tight i can run @ 1000mhz next. More results to come.
No dice on 4-4-3-9 @ 1000mhz.
Bottom line: These modules will do 5-5-5-15 @ 1000mhz for 60 bucks @ ewiz.com. Not bad..... not bad at all. (Week 32/ Year 07)
Mine are Promos i know, cos i burned a few Microns in last 1/2 years;) They perform godlike for 60$ 2gb memory (Week 27 /Year 07)
Absolutely stable 1200 5-5-4-10-4-35-4-8-3-4 2.15V real 2.11:eek:
Prime and memtest dos/windows
And can do SuperPI 32M @ 1260mhz 5-5-4-10-4-35 @ PL6 with 2.25v set 2.27 real:shocked:
Here paired with my watercooled Q6600 4 cores enabled 1.64v idle 1.57 load :shocked:
11m 29.390 sec
http://img517.imageshack.us/img517/9...4242wj5.th.jpg
:up: :up: :up:
Very nice. Yeah i'm pretty much sold on them. I ended up ordering a kit for myself as i plan on a new rig pretty soon here.
Hi!
I have 2 KIT of these T800UX2GC4 (2*1GB), so its 4GB memory running @ 1000MHz in CL4-4-4-8-4-35 with only 2.25V:cool:
Now what I'd like to know, is what is the correct SUBTIMINGS for these KITs!
At this moment, its running 10-10-10-12 (tRRD, Write to Read Delay, Read to Precharge, Write to Precharge Delay)
Does anyone know what timings is for the best?
For example, my prevous A-DATA (d9gmh) kit could do 2-9-4-11...(this is the 4 last subtimings of course)
So?
Hi again!
Tough I wrote an e-mail to Super Talent support a few days ago, they haven't responded yet, so I tried a few thing on my own, based on my previous overclocking experiencies:)
So right now, I am running this 4GBs RAM at 1000MHz with 2.25V.
Latencies:
4-4-4-6-5-35-5-9-7-12
Just getting better and better!:p:
Is this a way to know what chip I have in my kit with out taking off my heatspreaders ?
I have this num on : 37975
I'm having some trouble getting my sticks to work @ 4/4/3/8 :(
The whole pc runs at stock speeds. The sticks run by default at 400MHz 2:3 5/5/5/15.
I changed the following in bios:
Advanced-JumperFree Configuration
AI Tuning: manual
CPU Frequency: 266
DRAM Frequency: 800
PCI Express Fre. : 100
PCI CLock..: 33.33
Spread Spectrum: Disabled
and then
Memory Voltage: 2.25
Memory Remap: Disabled
Configure by SPD: disabled
timings:4/4/3/8/6/42/10/10/10/10
Static Read Control=disabled
which got me the wanted timings but it gave me a lot of BSODs while playing PES2008.
As suggested by a fellow forumer and after running memtest for about an hour with no errors, I thought the problem was with the fsb ratio. He suggested I oveclocked the cpu to run @8x400 so I could get the 1:1 ratio.
I tryed the following settings but the pc did not even post :( :
Advanced-JumperFree Configuration-AI Tuning σε manual
CPU Frequency 400
DRAM Frequency 800
PCI Express Frequency 101
PCI Clock Synchr. Mode 33.33
Spread Spectrum dis.
Memory Voltage 2.05
CPU Vcore Voltage 1.325
FSB Termination Voltage 1.3
NB Vcore 1.45
SB Vcore - Just one up, after auto
ICH Chipset -Just one up, after auto
Advanced-CPU Configuration
Cpu ratio setting: 08.0
C1E Support: Disable
Max CPUID Value Limit: disable
Vanderpool: enabled (and cannot be changed)
CPU TM function: enabled
Execute Disable Bit: enabled
As I am a first time overclocker, any advice on the subject would be appreciated. :/
At least the proper settings for the sticks to work @400MHz 2:3 4/4/3/8 with the cpu at default speed.
Thanks in advance.
Back!
ST support hasnt asnwered my e-mail still ... :(
But I checked the RAM, removed the heat spreader, its D9GMH chip!
Week 27 year 2007.
Hmmm, I have 2x1GB Supertalent T800UX2GC5 with silver HSes. Week 21, Year 2007. I have them on Asus P5B vanilla.
Very bad sticks, won't go 4-4-4-8 at all, despite 2.4V and low frequency of 667MHz.
Max stable clock is 850MHz with 1.8V and default timings, increasing of voltage doesn't bring anything at all. At 900MHz it won't even boot.
I have E2160 CPU, so luckily I don't need high freq chips, but I hoped for 800MHz and 4-4-4-8 with ~2V.
How do you know the week and year of these sticks ?
EDIT: ok I find myself , you can see it in CPU-z , mine are Week 27 year 2007 too.
so how are these doing currently if they were to be ordered now.. how are they oc'ing and are they for sure going to have the promos chips on them?? thanks
Just getting tighter and tighter timings with this ram (all 4 gig)
http://aycu10.webshots.com/image/394...1880155_rs.jpg
