-143C... outch I don't find the words buddy! :)
Holy Sh*t!!! :banana:
Now go and buy some R14 + R740 (Argon) ... I think about -160°C should be possible with this thing! ;) :toast:
Keep it up ... this cascade is really a masterpiece!!!
So this could get colder?
It can always be coolder (to a certain extent), just depends on how much money your willing to spend.
You have to consider $$ for every °C you lower the temps. It gets to a point where the few °C is not worth the money.
thanks ppl! i realy didn't expect this colder with ethylene :) need to find a way to get argon, nitrogen, etc to try some mixes :)
is realy awsome to condense ethylene on vacuum hehehehe i devenitly love this hx's 2nd stage has perfect pressures
:toast:
Amazing job Ricky :toast: Your are doing great :clap:
-143ºc :D great work :D
congrats m8 ;)
mig and tig welders use argon and can be found @ b o c here in the ukQuote:
Originally Posted by |RickY|
Awesome Ricky :D!
I remember seeing pc_ice using R50 (Methane) as a 3rd stage refrigerant ages ago and he got -150c IIRC. Depends what you can get hold of though.
With a cascade like this , whats the meaning of ln2 ? :banana: :clap:
Dont you purge with Nitrogen?Quote:
:toast:
Fantastic work, nothing that I wasnt expecting from my partner in bench :toast:
Can wait to put my CPUs under that cascade :D
True, specially considering most of X6800's start to cold bug at -140ºC or less. So -140ºC full load (I don't have any doubts that Ricky will achived that) will be the sweat spot. ;)Quote:
Originally Posted by Athens[2004]
And we can bench for hours and hours :D
great 3stager ricky , looking forward off the tests on the X6800 and ure QX6700 ;)
This is sick Rickey :)
I started mine yesterday but it is not good. I only tested it load on a 6800 so dont know what it did unloded. I get -114c evap idle in win and this in win
http://i23.photobucket.com/albums/b3...i-5ghz-web.jpg
lol look at the speed fan temp... dont think thats right :(
Loaded with 05 the evap is -107c.... wil tweak the cascade more on monday too try too get better load :)
But yours is just awasom :)
Ricky do you have any frost pics :p:?
Rikey: Whats static pressure on stage2 and stage 3?
It's getting cold over there :shocked: , very very nice work Ricky :clap:
thanks ppl :)
overklokk, i dont know lol i put 5bar on each stage before start 1st stage but i need to get some off, it is overcharged
i'll check tonight
Tnx.Quote:
When wil you load test it?
WOW RICKY :clap: !!!
I'm don't know how Nitrogen will behave in the mixture, but could it be possible to obtain a small amount of it from a paintball shop? I've heard they use Nitrogen now in some of those paintball guns. The problem would be how to get them from the cartridges into the cascade :p:
load test soon :)
s7e9h3n nitrogen i can get easy soon :) argon i think i'll test argon/co2 sl4ck have, 80%argon 20% c02... just to test
Co2 bad bad bad!
Dry ice at those temps!
:D?wtf?:DQuote:
Originally Posted by Pedro Rocha
Ln2 runs out, this cascade will not.
yes i know but it's just a litle of c02 heheh
