Yes, but i dont see a point :)
Are you sure it is 2.3V???????Quote:
P5B-E vmem moded
It doesn’t make any sense to me
you have the reprogrammed SPD with epp support maybe this helps someway in overclocking? :confused:Quote:
Originally Posted by srkiller
http://img86.imageshack.us/img86/6453/cellshock1un3.jpg
these are the ones I have ;)
I think a guy somewhere said something like that but any way that should help in booting onlyQuote:
Originally Posted by GrimReaper
It's 2.3V for sure, I use a multimeter only ;)
Nothing really changes if I turn the 2.6V...
You have to use an nVidia chipset based motherboard to feel an advantage of EPP. The EPP is useless with boards based on non-nVidia chipsets absolutely.Quote:
Post a shot with AISuite open to show vdimm and it running orthos on the memory and a shot of cpu-z timings.
AiSuite show maximum bios Vmem for this board, true value is 2.3V
How about Orthos + SPi32M parallel...
Im done, this memory rocks!
this memory rocks
:clap:
I wonder how the CAS5 perform.
Should receive mine in 2 days or so .Will elt you know what I think when they arrive ;)Quote:
Originally Posted by nicepun
I've got the c5 kit, i'll post some screenshots up tonight, I'm up to 1200mhz, 5-5-5-15, at 2.25Volts. Prime95 stable for 13 hours as we speak. I haven't had a play with the timings, though I'd like to hit 1300mhz ;) Highly impressed so far!
CPU-z shot coming up when i get home!
RwD
Wow! 500MHz 3-4-3-8 .... DDR timings on DDR2 :eek:Quote:
:clap:
Very nice! Keep us updated... :)Quote:
Originally Posted by Rinsewand
http://www.rinsewand.co.uk/gallery/a...Hunter_037.jpg
apologies for the huge screenshot!
had to up it to 2.3v on the ram, 1200mhz, 5-5-5-15. Will try for more when i can get a fan blowing on it!
EVGA 680i
BFG 8800GTS
Cellshock 2*1Gb PC8000 C5
RwD
Screw it, I'm going to beat my bank account into coughing up the dough for some of this stuff. Is the 1000 c4 worth the extra cash over the c5?
EDIT: Nevermind, I just went ahead and ordered the C4. And if anyone else is thinking of ordering, now is the time to do it. 7.5% off with code DF35TA. :D
WOW, this memory is awsome. I'll have to learn about memory timings more before I get rid of the gskill hz's. 4-4-3-5 @ 500mhz+ makes me happy. My memory scores are MUCH lower with my timings being very close. Any advice on what timings to use to get higher bandwidth scores?
just for bench but awesome at 2,45vdimm :stick:
http://img442.imageshack.us/img442/582/pi9xt.th.jpg
bye
There is no such D9 that can do DDR1000 tCL @ 3 with 2.3V, period.Quote:
Originally Posted by EnJoY
That is just some sort of a bug.
Yes, I have shown a while ago how one could possibly claim impossible CAS3 clocks on P5B Deluxe. All you need is Memset. There is NO WAY any currently known IC would do DDR2-1000 CAS3 with only 2.3v, especially ORTHOS stable :rolleyes:Quote:
Originally Posted by The Stilt
http://www.xtremesystems.org/forums/...ug#post1742681 plus some screenshots I made two posts down...
Even @ 2.7V but stable
Never seen such thing
Wow, Those rams you guys got was godly. I received mine a week back and it dont seems to be behaving so perfectly.
My rams specification on was a 2.3v instead of a 2.2v on the sticker behind it. BUt i have tested 2.2 on default specs and it boot. Even with 2.4v i dont seem to be able to clock at 1200 @ CL4 :(
did anyone say all 1000 do 1200? tried 1200C5? a good mainboard (for example i680), psu etc. is also needed to reach stable 1200MHz RAM-speeds.
btw. we lifted specification for all CellShock DDR2-1000 series to 2,3V also for the former ones sold with 2,2V on sticker ;)
I had a pair that did 580 max at cas4 (only stable enough for 1M) and even at cas5 600mhz wouldnt work. Same setup/settings me 2GBHZ does 613mhz on. Some of the older kits seem to do a lot better but whats new ;)
ahh, good to know about the 2.3 volts! I'll stick some more through it when i get back to uni! Any recomendations on ram coolers? Mine seems to be getting a bit toasty at 2.2volts...
RwD
