Sicness, what Cpu and ram does your friend that hit 400fsb have? It's worth knowing just so we can see if there are any further issues with other equipment...
regards
raja
regards
raja
I'm currently seaching options for better cooling without going water. The 1.85v mch on my P5W DH is not doing me alot of good because of cooling. I think someone noted that Asus said it was not recommended to use that much voltage without improved cooling to the northbridge. I can't imagine how the abit board can handle the 2.0v available with just passive cooling. When I find something suitable for both the AW9D-Max & P5W DH I'll let you know. My concern right now though is bit-techs statement:Quote:
Originally Posted by TWY
Now the board is reaching retail channels and available to end-users, but no bios update as of yet. This is a bit disappointing considering Abit was already aware of issues and decided to release the board anyway without a bios update to correct some of the problems. Hope mine isn't too problematic.:rolleyes:Quote:
We were told by Abit that there are some kinks in the BIOS that makes the board a little fussy at times when overclocking. We are hoping that these are fixed before the board reaches retail, because 450-460MHz+ FSB on an unmodded 975X motherboard is pretty impressive
Why :)Quote:
Originally Posted by The Nemesis
My cpu is orthos stable 3.6ghz 9X400 1:1 with 1.4750vcore set in bios. Now that I can lower the multiplier with the ASUS P5W DH I should be able to do 8 X 450 for the same 3.6ghz orthos stable, but I'm not. The pc freezes & when I touch the heatsink over the north bridge its very hot. Eva got his board stable above 450 FSB after changing the thermal paste and such. I figure if I remove it, I may as well replace it with something better. None of this is necessary I'm sure, if you just want 400FSB or so. But I wan't every bit of FSB I can get, therefore better cooling is necessary. Thats why.Quote:
Originally Posted by Tacops
I see.. Currently I'm still trying not to add any fans to the motherboard cooling system. :p:Quote:
Hmmm, think you didn't reply to my qn on whether will you change thermal paste on the motherboard sinks first? Or you'll be just plonking some extra cooling fans on? :D
Like I said if I remove the heat pipe system, I'm gonna replace it rather than just reseat with AS5. I have Zalman V900's on my video cards so adding something like swiftechs mcx 159-cu shouldn't be any louder.Quote:
Originally Posted by raju
RAM is Corsair 2GB 6400C4 (DDR2-800 4-4-4-12)
Enermax Galaxy 1000W PSU
More results should come in later today ...
vowkilmer: Since I seem to have a dud and Turrican has a proper AW9D-Max that let's him connect his EPS 8pin and run 1:1, I'd recommend the AW9D-Max right away. I'll get a new one myself.
what CPU does he have to hit 400fsb, is it 2mb cache or 4mb?
He said that he had 3,6GHz when using 400MHz FSB, so it must be a 9x multi ... prolly a 6600 :)Quote:
Mine is not hitting a high FSB 370+ , no problem running 1:1
Tony is correct, we need 1333 strap in bios. They can be pushed a little but no where near enough.
We also need upward multi's on the X6800
You don't hit 370? Welcome to the dud club. I just ordered a new AW9D-Max and will return this april fools board with it's funny connector next week.Quote:
Originally Posted by FUGGER
There is no upward multi here or?:confused:Quote:
Originally Posted by Heidfirst
Man, a board which costs near 300 bucks, SHOULDNT have that fail. I havent seen yet that problem EVER, have you ?
BTW, Good to see 400 1:1 @1,6vmch from other users, not really impressive if you ask me... I still want +470 from this board, until that, its useless ( a board with 2v option from stock should do that at least )
That was a quick test he did after return from work at 11PM. I hope I'll get a board with a proper connector tomorrow, there should be other user's results soon too.Quote:
Originally Posted by ^don.k's^
Good luck with the new board, thats pretty strange that the 8-pin was wrong.
.....well.....after some mods I can boot up to 413MHz fsb and 1:1 CPU:Ram.....It accualy did well with the Micron Fatbodies chips with VERY tight timmings as well......No?.....:)
http://www.thelab.gr/images/Hipro5/C...13.734_png.png
3D benchable at the SAME timings @ 410MHz....:)
Hipro5 already modded his board - lol :D
412MHz 3-2-2-1 is a very nice score! :slobber:
...412.8MHz = 413MHz.....don't steal me 1MHz......:DQuote:
Originally Posted by Vassili
Great job mate :clap:Quote:
Originally Posted by hipro5
What did you mod ? VMCH ??? I hope Vfsb or something else, not vmch... Please tell us a bit more on that ;)Quote:
BTW man, that time sucks, i got near the same time with 370 4-3-2-1 and emule, msn, everything running... Its the mobo that performs badly or what ? Ok, maybe interleaving... my fault. Id like to see time comparison between AW9 and P5W tho.
VMCH, VFSB and some capacitors for the time been....:)Quote:
how much vmch & vfsb did you need for 413MHz fsb/1:1.....:)Quote:
Accualy with 1.91VMCH and 1.6Vfsb....Quote:
Originally Posted by Dynasty
1.91VMCH into bios is not as it seems....;)
Oh, so, max in bios, how much it is for real ? 1,91v for 413 1:1... :nono: Any P5W with 1,9 can do over 440 1:1 if im not wrong.... Well, keep praying for newer and better results like we were hoping...
