My friend in Taiwan sent it to meQuote:
4*512 Spectek 667 on DS4&6600 = fsb 450 1:1 4-4-3-9-22... can't hit higher with Easier timings, higher voltages
Gigabyte GA-965P-DS3 Ver 1.0
CPU Core 2 Duo E6300 @ 3.33Ghz
RAM: 2x1GB Patriot DDR2-667 (4-4-4-12 1.8v) running at 5-5-5-15 1.9v
http://img.photobucket.com/albums/v1...e71/Conroe.jpg
Could someone give me some no BS advice on a 965P-S3 + Geil Ultra 2GB combo? been outa it for quite some time...I really don't want to chuck out $200 for the P5B but if the memory issues are that bad with the DS3 / S3 then I may have to?
Great! can you tell me your spectek serials and you know which chip used for it?Quote:
nominal
Wow Great! you use extreme performance series or signature line series??Quote:
River Side
Ran some new benches on the ds3 with the new F7 bios ( new for me anyway :P ) and my geil pc6400 5-5-5-12.
The specs:
DS3 C1 fsb +.1v gmch +.1v
E6300 1.425v 500x7
2x512mb GEIL pc6400 5-5-5-12 1.8v @ pc8500 5-5-5-15 2.2v
Pics... cpu arhitmetics
http://www.hardwareasylum.com/forums...f779eefd1a.jpg
Cpu multimedia
http://www.hardwareasylum.com/forums...f779f67950.jpg
Ram bandwidth
http://www.hardwareasylum.com/forums...f779fd89db.jpg
Memory latency
http://www.hardwareasylum.com/forums...f77a04f2b2.jpg
Cache and memory benchmark
http://www.hardwareasylum.com/forums...f77ba491ec.jpg
And the final one... F@h BENCH :cool:
http://www.hardwareasylum.com/forums...f77bae2699.jpg
I know the F@H bench is obsolete, but I like the way it scales from stock... ;)
I can confirm that my DS4 (board rev 1.0) bought few days ago is 965 rev C2 (reported by cpu-z and everest).Quote:
Originally Posted by HamidFULL
Bought it in Croatia ... Europe.
Salesman told me that was the first shipment, long time ago.
It looks like Intel did change chipset revision long time ago.
Now when you buy new board you don't know what you are getting til you try it.
Guess, I was lucky :)
its true but I bought my DS4 5 days after release! and its hand-pickQuote:
baki
Guess, I was lucky
How can I tell from the layout whether it's C1 or C2 without help of software? Help plz.
PS: I have a DS4 Ver 1.0 also.
there is no way you should install windows and run CPU-Z to find itQuote:
Originally Posted by comsci
serial number will tell you, the build date of the serial number will show when its built and you can tell that anything built within the last.. oh i dont know.. month maybe ? or less than a month is going to probably be a C2.
but i would say within th elast couple weeks would be best.
The build date is Aug 2006, dunno if that helps. :(
For Gigabyte, lot number (production week) 0636 was the switchover to C2. You will see it on the side of the box.Quote:
I've looked thru the forums and I'm still not sure if this RAM will work with a DS3. Crucial says it will on their website. Here's a good review of the 2G kit
http://www.xbitlabs.com/articles/mem...dr2-800_3.html
Seems like a good price for 119.00 after rebate
http://www.zipzoomfly.com/jsp/Produc...ctCode=80061-3
If not which Geil or G.Skill 2x512 kit?
thanks
I guess with 0638 I should have the C2. :toast:Quote:
Originally Posted by bingo13
Anyone using ds3 f7 bios pair with team xtreem 2 x 1gb pc6400? can achieve > 500?
Supposedly Bios F8 will fix the Micron D9MGH issues (ie, running above 450 FSB)Quote:
Originally Posted by cyberion86
DS3 Revision C2
E6400@3.52
Team Group 2x1GB DDR800@880
Arctic cooling Freezer 7 Pro
Solid as a rock!
My max mhz for team xtreem pc 6400 are 910mhz on ds3...
i dont pass +450fsb at 5-5-5-15 +1vmch +1fsb dont boot,
bios is F7
:s why???
Just for the hell of it, have you guys tried running single channel?
Because using the old F6 bios, I've been able to push my D9 to over 500Mhz.
But again, once in dual channel, 450-460ish is the limit.
Originally Posted by MACMAC
I have 1 module Team Xtreem PC6400 single channel and can't pass 455fsb....., bios F7
F8 really fix the problem with d9??
ThanksĄ
hi!
first sorry for my bad english...
tell me please, what memory are the best for ds4 ??
price <200-220$
thx
edit.
I meant 2x1gb kit of corse
My DS3+ Bios F9
C2D E6600 L629 + TR Ultra-120 with Tt Smart Fan 120mm. 3150rpm~
Gigabyte G965P-DS3 Rev.C1 NB Zalman Cooler NB47J
Kingtons Value 512*2 hynix Chip FP-Y5 642AA Vdimm 2.43v
6600GT
EG565AX 535watt
My English is Bad ;)
http://valid.x86-secret.com/show_oc?id=155525
Dual SuperPi 32Mb 6*524 Bios Boot & Use SetFSB For GA965 Ultra Ver 1.5a1 Set FSB To 525.....
http://www.pc-cm.com/modules/Forums/...6-6-16_123.jpg
& ORTHOS CPU&Ram @ 2hr.
http://www.pc-cm.com/modules/Forums/...urn2hr_213.jpg
Kingtons FP-Y5 642A
http://www.pc-cm.com/modules/Forums/...y5_001_201.jpg
http://www.pc-cm.com/modules/Forums/...y5_002_111.jpg
http://www.pc-cm.com/modules/Forums/...y5_003_409.jpg
Gigabyte DS-3 Rev 2.0 BIOS F10
2x1024mb Corsair Dominator Series PC-6400C4D
Zalman CNPS 9500LED
vdimm @ 2.1v
This has to be about the most retarded post I've ever seen on this forum.Quote:
Originally Posted by Onepagebook
You not man, you silly child. :lol2:
