I got my MSI 975X from Ewiz a couple hours ago. It was version 2.1 power up edition for those of you wondering :) . The install went smoothly and the system started up normally. The only problem I ran into was installing my Big Typhoon, this was because my case was completely full. The biggest problem I am having right now is horrible temps. I am still waiting for my conroe so I am using my ES PD 950 and at 12x200 1.16Vcore I idle at 48 in bios and 52 in windows :(. If I even try to go to my stock speed of 3.4 Ghz I start getting into the mid 60s. My board came with bios 6xx. Aside from this, I can't seem to flash the bios using the MSI live update thing, can anyone assist me in this? I think my temp problem may be because I did not apply the thermal compound correctly or maybe I did not tighten the screws on the big typhoon enough. Can anyone help me with my heat problem and also help me with the bios flashing?
Thanks, If I can get these problems sorted out I can actually OC or something.
HELP! :(
