OMGOMGOMG!!! ordered :D
OK, so those are my final-final results until I get a vdimm mod going for some 2.7v+ action.
Now, other F2-6400PHU2-2GBHZ kits may do better or worse. This is just to show that those clocks can be reached with up to 2.5v but not neccessarily and likely not every kit will be as good. I have no idea about average clocks for this particular line but it seems like DDR2-1066+ 8-4-4-4.0-2T is common.
ASUS M2N-SLI Deluxe (nForce570 SLI), BIOS 0304
AMD AM2 Athlon 3200+ "Orleans"
Arctic Cooling Freezer 64 Pro
EVGA 7800GT KO 256MB @ 490+30/1390, ForceWare 84.21, Modified driver settings (High Performance)
G.Skill F2-6400PHU2-2GBHZ "0605", Micron D9XXX
MAX fully stable DDR2 8-4-4-4.0 clocks reached ---> DDR2-1140 @ 2.5v
SPi32M -------------------------------------------------- SP32M - Drive Strengths window
http://www.clockmehigh.com/cooler/sc..._32M_1_4x3.jpg http://www.clockmehigh.com/cooler/sc..._32M_2_4x3.jpg
SP2004 LargeFFT 9hrs ----------------------------------- SP2004 LargeFFT 9hrs - Drive Strengths window
http://www.clockmehigh.com/cooler/sc...9hrs_1_4x3.jpg http://www.clockmehigh.com/cooler/sc...9hrs_2_4x3.jpg
3DMark2001 & 3DMark03 -------------------------------- 3DMark2001 & 3DMark03 - Drive Strengths window
http://www.clockmehigh.com/cooler/sc...DM03_1_4x3.jpg http://www.clockmehigh.com/cooler/sc...DM03_1_4x3.jpg
3DMark06 ----------------------------------------------- 3DMark06 - Drive Strengths window
http://www.clockmehigh.com/cooler/sc...DM06_1_4x3.jpg http://www.clockmehigh.com/cooler/sc...DM06_2_4x3.jpg
:peace:
btw, what chips 1GB kit uses?
wow, i look forward to my kit. should be here in a day or two. whats the deal with the 'old' and 'new' micron D9 chips? whats the difference?
at least bachus is hitting these on non-bad axes...is there some sort of bug with those boards or something whats the deal?
great results bachus :toast:Quote:
Originally Posted by bachus_anonym
cant wait to get my hands on this stuff :slobber: :D
I think I'll be ordering a pair of these sticks myself :D
FYI: i just got my pair in and its 0506 instead of the 0606 they told me they would be shipping (oc-wear that is) :woot: .
/me is happy, now all i need is a mobo and a proc :p:
Same question :confused:Quote:
Originally Posted by caater
F2-6400PHU2-1GBHZ for example- D9, Elpida or something else?
elpidaQuote:
Originally Posted by Rutz
i took a peek under the pair i got at newegg
its a 605. micron d9gmh , havent gotten a chance to test it yet as im still selling my old pc so pay for this new upcoming one. to classify confusions
tHESE ARE NOT FATTY D9 ICs
THESE ARE NEWER REVISIONS.
and they seem to run with less volts then fats, which is a god thing
None of the G.Skill's were Fatbody...Quote:
Originally Posted by ooeric
They were just anounced as D9xxx.
They were never announced at FATTY but as Micron D9
If 0605 are D9, 0606 still are, rigth??
Wow, I see these sticks rule :banana: But aren't youy afraid of using the voltage of 2.5V? Isn't it dangerous for the chips? Which voltage is safe for the Micron D9 (not FB) chips for the everyday use?
Everything from 0605 (which includes 0606) should be D9. So you're safe to go with your 0606 kit.Quote:
Originally Posted by _JP_
It's not D9, it's D9GMH!!
D9 is just a code for "Micron DDR2" and doesn't means anything about performance!!
I think you should stay under 2.3v and with a cooling fan for 24/7Quote:
Originally Posted by mach82
I have the same IC's on my ram, and I couldn't thouch the PCB for long when on 2.3v (800MHz 3-3-3-x) and with the fan turned of for just 30secs.
But you should be able to give 2.8v without killing it when benching.
Ordered me some F2-6400PHU2-2GBHZ from the egg, should be here tomorrow. I'll try them out in my current rig, since it can only go up to 2.3vdimm let's see what they can do.
My 606 just arrived:toast:
http://img412.imageshack.us/img412/3...stpi4pp.th.jpg
http://img77.imageshack.us/img77/2731/ram35jb.th.jpg
I`m having some 3D stability issues here. BF2 is the worst. Can`t get stable over DDR2 800:stick: .
Whats safe voltage for these modules?:confused:
wow those are damn sexy and the price sure isnt bad at all,, infact its smokin... i may have to break down.
anyone had any issues with any of the conroe boards currently out aside from thebad axe which seems to be working just fine ?
im hearing people say the 965 boards are really picky
0.01v before they burst into flames. http://1000smilies.com/babies/onfire.gifQuote:
Originally Posted by Nightprowler_77
:eek: That's a crazy, excessive voltage!!Quote:
Originally Posted by Makubex_GB
When you go that high you should put your ram under dry ice to be in the safe zone.
:rolleyes:
got some in a p4 system(p4's just to use till i get a conroe) today. haven't thoroughly tested at all yet, trying to find cpu and mem limits, cpu seems to do 4.5Ghz (930 duallie, pretty fast actually) on air. mem seems to do around, well its passed a few super pi 1mb's at 1060 5,5,5,15, 1020 4,4,4,15 with ranging from 2.15 to 2.3v on the new asus 975x conroe board. tbh i don't know aht all the best settings are, have ignored p4's, intel boards and ddr2 for the last 2 years so just messing around at the moment.
with asus bios options, what do all the other settings do with the performance/turbo like options in mem section of bios? what can i use to see timings in windows? memset won't open, newest cpu-z won't show command rate cl through trc are shown in cpu-z. what else can i use?
