For zero- or reverse gravity (as in his case) you must use special heatpipes with different coolant.
I did a similar thing and it's very stable around 29 No Load, max was 46 so far after repeated loops of Futuremark.
http://www.msprotege.com/members/Bri...%20-%20(2).jpg
http://www.msprotege.com/members/Bri...%20-%20(3).jpg
http://www.msprotege.com/members/Bri...%20-%20(4).jpg
http://www.msprotege.com/members/Bri...%20-%20(5).jpg
@Brian MP5T: is that a SG01 as well? & what CPU HSF is that?
Brian MP5T, you should've mounted that BT with the fins facing the rear 60mm fans so you'll have crossflow of air
and how bout zip tying a 92 mm fan under it? huh? huh?
Brian, get 2 low profile enzotech forged copper nb/sb coolers, mount those, and switch that BT around so the fins are facing the 60mm fans like SaII said, that would be your best bet, i know your probably gona be hitting the stock NB cooler with the heatpipes.
It's a Thermaltake Lan Box Lite.
The CPU Cooler is a modified Tsunami by Thermaltake, (Basically bent it lower and took the fan off)
The Cooler will not fit in the case as it's a rectangle from the top, So it will not be able to fit inside if it was turned 90 Deg to aid the 60mm fans to pull out.
Basically, as it is now it does not fight the PSU fans so it's fine. As I said the Load temps are solid and low.
I believe my friend is happy with the NB and SB Cooler but I also think that if some OC is to be done Extreme spirit or some basic Zalman Blue Cubes should;d be used.
@ Deepsilver
An Enzotech Ultra-X would look better inplace of the SS Nitrogon :)
And it will cool better to boot.
Some updates of mine :)....still work in progress.
http://i11.photobucket.com/albums/a1...X/IMGP0469.jpg
http://i11.photobucket.com/albums/a1...X/IMGP0472.jpg
http://i11.photobucket.com/albums/a1...X/IMGP0473.jpg
EDIT: No more stock cooler on R600.....
http://i11.photobucket.com/albums/a1...X/IMGP0481.jpg
I like it RBS :) Thats BTX right? if so those heatpipes arent going to work properly. (the ones on the mobo)
Although my identification of Form Factors is quite bad lol
EDIT: @ Ar3s get a dominator airflow fan over those modules!
Wow RBS, really nice!
RBS, you haven't OC'd that puppy?
Since the first day :D
http://img465.imageshack.us/img465/3...aqprimepv9.jpg
Rbs.
Very nice case rbsmontemor:up:
Looks good, doesn't it? :)
http://www.abload.de/img/dsc0107393o.jpg
http://www.abload.de/img/dsc01074cq4.jpg
Hehe, big thanks :D
In the Hardwareluxx-forums I have a custom title -> Mr. Thermalright :)
That's awesome :)
Thermalright paradise :D
Rbs.
Some more..older ones :)
Bad Axe 2 + E6600 + Gskill HZ + Asus 8800GTX
http://img91.imageshack.us/img91/2784/dsc07856pj3.jpg
My rig today, when the parts arrived:
http://img142.imageshack.us/img142/6853/dsc08069td9.jpg
http://img106.imageshack.us/img106/5706/dsc08066sq3.jpg
http://img142.imageshack.us/img142/6262/dsc08064lh9.jpg
Rbs.
