Theyre running the same as 1048's :\Quote:
this is a temp placment for the rad till i find a way to get more tubes from the US :(
http://img361.imageshack.us/img361/9...cooling3uu.jpg
Im going to show the blocks i make, very known in spain.
The vga block.
http://i6.photobucket.com/albums/y21..._universal.jpg
Later, Im showing the cpu one and nb one.
Saludos.
postman, es aluminio anodizado ó Delrin?
Se vé muy bien tu bloque, tiene cierto parecido al Maze4 y la base del espesor del MCW60, muestra imagenes del interior del bloque.
Saludos.
Originally Posted by postman
Any pics of the internals?
Hmm WB pr0n, take it off!
Hi Geep.Quote:
Originally Posted by geep®
Why in Spanish? Do you personally know him?
Well, it seems to be a little bit similar to the Maze 4 I own.
If he could dissamble it to get some images it could be great.
Postman... just remember to be carefull in that way and check the seals before installing it again (for leaks).
really sweet setup D,
the water is so watery :D u used zerex only right?
yeap I only used zerex racing super coolant and distilled water:cool:
Hola.Quote:
Saludos.
Es Delrin, a ver si le hago fotos al interior a alguno de los bloques que tengo sin ensamblar, y las pongo.
Ok, i will show the internal when i arrive to my house.Quote:
You are right, this is a english talking forum, then, we could to speak in english.Quote:
Hi Geep.
No problem with leaks, the top and base plate are sealed with a piece of rubber sheet, you will see it when i show pics of the internals.
In addition, i have done hundreds of blocks for the people, and no problem with leaks.
Greetings.
Here's my pocket Dual Opteron SLI powerhouse :)
http://tweakers.net/ext/f/5dd550c384...c2d9/thumb.jpg
All clean and interior watercooling (CPU's that is, the SLI cards are cooled with air)
http://tweakers.net/ext/f/cf0e4ca7c9...4e47/thumb.jpg
This case is small, so I'll really have to think were to put all those cables :)
http://tweakers.net/ext/f/8eb8eed525...976e/thumb.jpg
A push-pull setup with SilenX 14dB fans (which are noisier than 14dB on 12V ! ;) comparing them to the stock Lian Li fans...), the radiator is a Black Ice GT Stealth 120
fpompert,
Mate love it, clean looking. What display in the top bay is that mate.
A little liquid system for dayly use...
http://i73.imagethrust.com/i/500653/dscn0866.jpg
http://i73.imagethrust.com/i/500652/dscn0865.jpg
Thats a MatrixOrbital MX620 PLED screen (aluminium bezel) with a black bezel installed, so actually it should be called MX630 :)Quote:
Originally Posted by 4Qman
Its a lot brighter than on the picture but I have to use the sports setting on the camera to get a decent shot...
You can get it in the UK at kustompcs.co.uk if you are interested:
http://kustompcs.co.uk/acatalog/Displays.html
Ok, there is no problem, Yo entiendo completamente ;)Quote:
I just was wondering if you personally know Geep.
Bueno, y los bloque del CPU y del NB?Quote:
(Well, and the CPU and NB blocks?)
You said later, it's been a day! Don't play with us!! :nono:
Originally Posted by Makubex_GB
mmmm, sorry.
Here is the NB block, the internals are the same in the VGA block.
http://i6.photobucket.com/albums/y210/p0stman/web.jpg
The internal design may seems very simple, but the performance is very good (I have compared directly PostmanVGA and Maze4, and get the same performance), and the restriction is very low.
Greetings.
http://i72.imagethrust.com/t/101143/picture007.jpg
http://i72.imagethrust.com/t/101144/picture009.jpg
http://i72.imagethrust.com/t/101145/picture010.jpg
specs: D5, Swiftech micro res, storm, silverprop cyclone fusion, bip2, masterklear 7/16 tubing.
curios..how many radiator u have there??Quote:
Originally Posted by paco420
one 3x120mm & one 2x120mm??
How many pumps, waterblock?
Cause i'm curious whether a G5 pump is sufficient enough to power
An Apogee, MCW60, MCW30, BI GT240 + BI Gt120...
Need advice and comment from pro here...
still in process building my own set...
reason i get a GT240 & Gt120 to able squeeze all in a midle tower case.wit mod of course.
Nice... and i spotted a Hidden Mickey..Quote:
Oh, mickey, its true, maybe that block should be called "Postman MickeyBlock".Quote:
Originally Posted by daze
Greetings.
oohhhhh :slobber: , I can see the insides... just leave me alone with it for a minute...Quote:
:p: Very cool, thanks man.
Nice block Postman. Very nice!
Re-did the loop and all my case wiring. The tubing is much better now too.
http://img512.imageshack.us/img512/489/656462624rk.jpg
http://img74.imageshack.us/img74/6084/1212212128wp.jpg
http://img522.imageshack.us/img522/9...33232321vv.jpg
http://img343.imageshack.us/img343/2...45454543qt.jpg
http://img360.imageshack.us/img360/4...56556564yd.jpg
