I think we should allow 5000 +-5 mhz.One reason,100 mhz in 32M equals 6 seconds on ivy at this freq level,so 2 mhz would mean 0.012 sec,plus it's all about the clock divider on mobo's,which variates between 5002.9-5004.
Just my 0.02$
Just my 0.02$
3770K this time :D
C-N - 6:17:531 - 49x102.09 - 1430MHz - 9-12-12-22-114-1 - Gigabyte UD5H - Corsair Platinum 2666 CL10 2x4GB (Samsung HCH9) - 1.97v - Stock Air
20oC Ambient
http://i106.photobucket.com/albums/m...2126M17531.png
Excellent score, C-N! :up:
Indeed,congrats!
Nice work C-N,some awesome results on air and Gigabyte UD5H :up:
That would be sweet :p
Wow you guys are still going strong with this. I should improve my time, got a lot of high bin samsung and some new PSC ram to test.
edit: faster time at #1462
Wow I still got a lot to learn it seems. No way I can do sub 20 :confused: Here my best run with some mediocre PSC. What they lack in quality I make up for with volt and cooling :D Running twcl 7 here with.. ehm... 2,1 volts.
Calathea - 6:21:500 - 48x104.2 - 1250MHz - 7-11-7-26-76-1 - Gigabyte UP4 TH - Corsair Dominator GT 2000 CL8 2x2GB (PSC) - 2.10v - RAM TEC cooled -14 C, cpu on H70
http://i1050.photobucket.com/albums/...psc56b06f6.png
l0ud_sil3nc3 - 6:20:391 - 50x100 - 1300MHz - 8-12-8-28-96-1 - Asrock Z77 OC Formula - Cruicial Ballistix 2133 9-10-9-24 2x2GB (PSC) - 1.89v - Stock Air
http://i.imgur.com/iPhmwpf.png
Thanks for the motivation loud! Not quite there yet, but well on my way. Waza tweaking and a lot tighter subs:
Calathea - 6:20:375 - 48x104.2 - 1250MHz - 7-11-7-27-76-1 - Gigabyte UP4 TH - Corsair Dominator GT 2000 CL8 2x2GB (PSC) - 2.10v - RAM TEC cooled -15 C, cpu on H70
http://i1050.photobucket.com/albums/...ps58f9bc3a.png
http://i1050.photobucket.com/albums/...ps2ec1c36b.jpg
I need cold air to get any decent sub zero temps on ram, TEC is only able to get ~ 20 C below water temp. I've seen -21 but then it was freezing in here :shakes:
Yes the TEC (Corsair ICE T30) is cooled by a 240 rad placed on the side of the dimastech table. 240 is overkill, heat load in magnitude of 100-130W but well, it works good. H70 only for cpu. Would be cool to mod the TEC into a H70 for very simple and easy to handle TEC cooling though :D
I will try on 1300+ cl8 today, I think it's faster.
Hey Calathea,will those Dims not run @ 26 memory Multi?With the right vtt, imc volts combo this may help you,the other thing you can disable HT,I like your setup
Hi bullant. Yes they will run 26 multi. I'm just a little old school, I'd run cl6 if I could :D 2600 7-12-7 is a no go with this temp and sticks so will see how they perform on cl8.
Calathea - 6:19:844 - 49x102.1 - 1327MHz - 8-12-8-28-78-1 - Gigabyte UP4 TH - Corsair Dominator GT 2000 CL8 2x2GB (PSC) - 2.04 - RAM TEC cooled -15 C, cpu on H70
http://i1050.photobucket.com/albums/...ps437ea354.png
http://i1050.photobucket.com/albums/...psfdfd02e3.png
Finally you made it sub 20! Congrats! :up:
I'll make an update on Sunday.
Still cant thank you yet,must need 100 post? but thank you Don Dan the old fashion way for keeping thread updated
Thanks! 1300 trrsr 4 is possible but seemed a little bit slower than 1327 trrsr 5. I think with these mems I'm pretty much done. Should try some 4x4 Dom Platinum 2666 C10 now.
Thanks Don_Dan. Keep up your good work updating this.
Hey guys so Ive bee testing memory's on air lately,still no Ln2 yet.
PSC Dram 1.94v Air ,Temp 15c to 18c,CPU -25 2742MHz 7-12-7-30 single channel 32M Pi stable my best stick
http://s23.postimg.org/8pifgncrv/kkx3.png
http://s9.postimg.org/uasvs4wyn/DSCN7043.jpg
