hey pazza should be good you read some pages back plenty of nice info
extra powa not needed those 2 molex i tested all and do notha if you have a strong PSU
as for best bios also already mentioned 1409 / 1805
cheers and enjoy it
Sergio
first two ram slots died :(:upset:
the second two work, but don't belong to the same channel. stupid condensation!!! :mad::mad::mad::mad:
anyway it will magically work again if i leave it alone for a while?
How do i explain this to asus :(
Thanks for your help Sergio. I have a Corsair 1200 so should be fine without those molex.
I'm still having a bad time trying to understand this...
I used an "old" 4Gb 16000CL6 PI kit, at 2133 7-10-7-27 1.65v because I thought they were faster then the 8Gb kits... but...
4Gb 2133 7-10-7-27 1T
http://img849.imageshack.us/img849/9823/4gb.jpg
8Gb 2133 9-11-9-28 1T
http://img98.imageshack.us/img98/2610/8gbx.jpg
My question is WTF...
Load voltages are ~1.392v
it is completely dry now, it was always dry, at least it seemed to me... still the same thing :(
yes... but i do turn it off at night. I let it dry in my room for a day, and i just came back to it today... still the same thing. Q LED DRAM lights up and i get a black screen with post code 38. Only works with channel B1 and B2 but they are different channels so it will only run in single channel mode. :(
Called up asus for rma, but sticker isn't on the darn motherboard and only on the box. (i don't think i should have told them that) so now the customer support guy needs to ask his supervisor on what he can do. Already has been rma'ed before by it's previous owner, i was willing to pay for them to fix it, but they might not because there is no sticker on the board :shakes:
Seems like i am sol
What sticker Bad?
Did you try the usual battery out, reflash bios etc.?
I know this is being lazy but Sergio or one of the guys with a Linq stable 5ghz+ clock post their bios settings for me to start tweaking from please!!! lol
no problem friend
here are for you
http://img338.imageshack.us/img338/1...0916112245.jpg
http://img528.imageshack.us/img528/5...0916112301.jpg
http://img521.imageshack.us/img521/1...0916112313.jpg
http://img412.imageshack.us/img412/1...0916112324.jpg
http://img838.imageshack.us/img838/4...0916112350.jpg
http://img831.imageshack.us/img831/1...0916112425.jpg
http://img444.imageshack.us/img444/3...0916112434.jpg
Uploaded with ImageShack.us
and some stabilty tests
http://img338.imageshack.us/img338/103/5ghzblend1.png
http://img90.imageshack.us/img90/993...ot21339119.png
http://img41.imageshack.us/img41/6484/3dm11vgarod2.jpg
games i play all days DOWNSAMPLED to 2560+ and 3040+ this forces your system like any test
this are only 3 of 20 games i play downsampled
hard reset 2560+ all maxed out
http://img266.imageshack.us/img266/8...0914220435.jpg
homefront 2560+ all maxed out
http://img269.imageshack.us/img269/1...0820120917.png
Medal Of Honor 2560+ all maxed out
http://img99.imageshack.us/img99/218...0904214040.png
F1 2011 2560+ all maxed out
http://img534.imageshack.us/img534/3...2133653251.jpg
BC2 Vietnam again maxed out and downsapled
http://img26.imageshack.us/img26/862...1218153919.jpg
cheers hope you got all the info u need
Sergio
Mine 's very near andressergio's I use a slight less vCore ( 1.415v for 4C8T and 1.385v for 4C4T ) and a bit more vccIO 1.1125v, I also tend to use vPLL at 1.65v.
5.1Ghz screen
http://img51.imageshack.us/img51/3152/5100lowv.jpg
5Ghz 4Gb
http://img232.imageshack.us/img232/732/testap.jpg
I've a lot more of screens... I just need to find them ><
Thanks for this mate much appreciated. I will test these settings out tommorrow and tweak. I am looking for linx stable do you ever use linx?? I have 3x 580's for Tri so the performance should be great in games.
You see any improvement in clocks / Temps with HT off?
HT off will give you slight less temps ( you can also diminish the volts a bit with it off ). THe difference wont be as near as it was with 1366, here it will be 1/2ºC and something like -0.025v. For LinX see my post, but be aware there aint a lot of CPU's doing that :p
Thanks stoned I will start at these settings you guys are suggesting!!! did you need new Linq definitions for those tests mate. My linx works great on Gulftown but have not tried on Sandy yet.
There is not alot of CPU's linx stable at 5ghz?? evan with higher Vcore?? May as well leave HT on then!! for that small trade off!!
would you guys like to see a physical review of the gene-z? like my GB reviews? i have a gene-z i was thinking about doing a physical review on it and posting it. would anyone be interested? or is it a waste of my time?
"physical" review to stike again. Ohnooes :)
keep awesomeness on GBT :)
