That's amazing. No one can touch that for custom PC build.
crazy russians :D
back on topic:
http://img7.imageshack.us/img7/7369/img1308hn.jpg
can you spray paint sleeving?
I tested it ;)
The result was verry bad, because the paint peeled off with every movement :D
I guess I'll stick with technoflex clean cut black then. I can't find blue that doesn't suck at 1.5"
Did you try Nils' sleeving??
MDPC-X
I can't buy the "big" size for the atx cable =( separately.
You can buy the tubing sleeve seperatly...
As I remember the size is the same ;)
Damn, Nils, great timing with these crimps, just AFTER i got my sleeves ;)
Some photos from my router cooling project...
(Original topic here - in Thai language)
Open for all comment :)
http://image.ohozaa.com/id/tid_7502.jpg
http://image.ohozaa.com/ie/tid_7505.jpg
http://image.ohozaa.com/i1/tid_7522.jpg
http://image.ohozaa.com/ig/tid_7520.jpg
http://image.ohozaa.com/iw/tid_7536.jpg
http://image.ohozaa.com/if/tid_7534.jpg
http://image.ohozaa.com/is/tid_7549.jpg
http://image.ohozaa.com/id/tid_7551.jpg
http://image.ohozaa.com/iu/tid_7552.jpg
http://image.ohozaa.com/i1/tid_7550.jpg
http://image.ohozaa.com/iq/tid_7558.jpg
http://image.ohozaa.com/iy/tid_7560.jpg
http://image.ohozaa.com/ig/tid_7562.jpg
http://i50.tinypic.com/21j4mqr.jpg
24pin with my little monster
http://i46.tinypic.com/29gyzn.jpg
8pin sleeving
http://i46.tinypic.com/34dsq2r.jpg
6pin rocks with oranges
http://i50.tinypic.com/33ng2hg.jpg
Holding 6+2pin together - It simply rocks
http://i50.tinypic.com/1zz018k.jpg
6pin alone
For more: Arthur's WC Worklog with Lian Li PC-9
Really nice work FunFunBoy, seams a shame to close the door on that excellent work of art.
@Arthur sleeving looks excellent mate I really do like that orange.
I do find looking through the water mark is a PITA thou.
I know you do it so people don't use your photo's without your concent.
But still I feel it take away from your art.
@ funfun
WTF !!! You killed it man :D
nice work :woot::woot:
I found this link on a Dutch site http://www.pcgameshardware.de/aid,68...a/Gehaeuse/New
it made my day
Oh the stupid Germans :D
fhantastic - post your pics :ROTF:
hey you are insulting yourself now hahaha
(I say stupid nederlanders all the time):doh:
My sleeve, 24pin in progress.
http://img22.imageshack.us/img22/2007/dscn5850.jpg
http://img192.imageshack.us/img192/8107/dscn5846.jpg
Grand bleu and Pentium 3 fits really good :D
http://www.abload.de/img/blau1suuyh.jpg
Can anyone lend me an ATX pin remover? I just ordered all my sleeving and shrink for a shot at this, forgot the stupid tool. Promise I'll return it good as new soon as soon as I'm done.
Last time I tried the staple method while making some extensions, I ended up with quite a few staples in my thumb and vowed to never try that again.
Also, best tool to use for shrinking the shrink? I'm seeing a mix between heatgun and hair dryer. I'm afraid a heat gun might melt the sleeving.
BTW, looks like I'm the first one attempting this on a power supply with threaded connectors:
http://i270.photobucket.com/albums/j...owerSupply.jpg
Wish me luck.
It's a pity that you don't want to try again with staples. My first few cables were nightmare, but now i can't visualize myself buying 30$ tool - there is no sense in that.
Hint: don't use your fingers to push the staple in, try small pliers (i use my girlfriend's pliers for jewelery making).
I never tried anything else than lighter. Some patience and you will be fine.
http://lh5.ggpht.com/_40L7h_SFpEw/S1...0/IMGP9158.JPG
http://farm5.static.flickr.com/4032/...18d4001d_o.jpg
http://farm3.static.flickr.com/2719/...31f5389e_o.jpg
http://farm3.static.flickr.com/2719/...944ab682_o.jpg
http://farm3.static.flickr.com/2759/...9f97f42b_o.jpg
http://farm5.static.flickr.com/4064/...337b70a7_o.jpg
http://farm5.static.flickr.com/4060/...20df35a3_o.jpg
http://farm3.static.flickr.com/2804/...e6786694_o.jpg
My first adventure with cable sleeving, courtesy of Nils...
http://pictures.closetredneck.net/pc.../worklog_4.jpg
http://pictures.closetredneck.net/pc.../worklog_5.jpg
http://pictures.closetredneck.net/pc...worklog_52.jpg
http://pictures.closetredneck.net/pc...worklog_53.jpg
http://pictures.closetredneck.net/pc...worklog_54.jpg
I redid the SATA cables later and made the shrink a bit longer...
http://pictures.closetredneck.net/pc...worklog_55.jpg
http://pictures.closetredneck.net/pc...worklog_56.jpg
http://pictures.closetredneck.net/pc...worklog_57.jpg
http://pictures.closetredneck.net/pc...worklog_67.jpg
:eek: especially to your last picture...
That looks just amazing but don't you think the tube from the bottom is a little bit too short ;)
90 degrees would work better, though...
