here my new corsair doms pc2-8500 ver1.2 i have two 2x1GB kits same ram as last post:D
just playing around with all four sticks in:)
533 at 4-4-4-12 at 2.4v
4*1GB crucial+gskill D9GMH@2.2v
http://img.techpowerup.org/090203/Capture035.jpg
and i cant do 3-2-2-1 even with memset its an AMD K10 mem controller thing
http://img.techpowerup.org/090301/Capture062.jpg
http://img.techpowerup.org/090301/Capture060.jpg
1300MHz four sticks D9s :D 2.4vbios
nice one elite22.are those the dominators in your sig?
Corsair Dominator 2GB DDR2 -TWIN2X2048-8500C5D just found a set of these the user never pushed them over 2.1v :D
my cellshock pc8000 gkx @1200 5-5-5-15 2volt rocksolid & my ep45 extreme
http://forum.hwproject.net/imagehost...be54cbe6b9.jpg
I just got in a kit of 2x1GB Ballistix 8500 16FD3 from eBay today, testing at 600MHz 5-5-5-15 on the 5:6 divider with 2.00V BIOS set. One hour+ in Memtest 86+ 2.10 and no errors :up:
Makes me hate my Cellshocks. They need 2.28v to be stable @ 1200MHz. Maybe this set is just one of the GKX kits that loves voltage.
Nope I have the 8000C4 kit.
my cellshock pc8000 pass 1 hour of memtest @ 1200mhz 5-5-5-15 with 1.92 volt.
i don't have any screen, but when my mobo return from RMA i will make some other test and post some screen. :)
@ket: biostar tpower i45 with cellshock pc8000 suck...
my cellshock on this mobo can't reach 1250mhz with very high voltage and timings...
on p5q they don't do better than 1050mhz with 2.4volt :rofl:
asus suck...
@all: someone of you know what chip is mounted on patriot viper pc9600 ELKN Nvidia edition???
thx
Could someone tell me why when I set 1T in the BIOS when it loads Windows it always says 2T? It did it on my P5E and it also does it on my UD3P. So WTF am I doing wrong?
I guess that the chipsets don't support it for DDR2, I have never seen it working on an Intel DDR2 board. The only boards I know of that can do 1T command rate are those based on NVidia's chipsets and ATI's RD600.
Oh and by the way, it's not even a real 1T command rate, it's correctly called 1N and 2N, I don't know the difference but that's what I was told. :(
Strange they are usually good sticks. Perhaps try another board.
When you set 1.92v BIOS what is the real voltage measured with a DMM? Asus boards don't all suck, my Cellshock kits all do DDR2-1200 @ 1.99v real (measured at slot with DMM) and they are 32M stable at DDR2-1302 @ 2.24v on the M2F and P5Q-Deluxe. P5Q-Pro is pretty low end, I wouldnt expect great things from it.
I still have to sort the sticks myself and make matched pairs.
With CellShock @ 2.3V...
http://img93.imageshack.us/img93/4691/333g.jpg
http://img19.imageshack.us/img19/2699/3331v.jpg
So you've measured with a DMM? Eastytune6 isn't real voltage. There is definitely an issue with your board, but the vanilla P5Q's/P5Q-Pro's etc aren't great ram clockers.
P5Q-Deluxe is much better from what I've seen, but they are not as good at clocking ram as the EP45 or UD3P.
EDIT - what happened to your EP45?
