400:800 is looser strap;)
Thanks m8, so 400;800 should help me overclock more that if it was set at 333;667. I only ask as when im messing with occt i can get code 1 and code 4 errors so by using 400;800 i could push my cpu more because of the looser strap on the ram??
finally, it detects my E8400 :( weird !
so i tried to pushed it while it detect...
some how its hard for me to clock my E84 into 4.4Ghz 440 X 9...:shakes:
is it true that this X48 have limitation ??? :(
anyone can help me the best voltage setting to raise up about 500 X 9 ?
and btw what is the perfect GTL should be ? is't neccessary to use GTL ?
thx........
every chip may vary m8, i reckon around 1.37 - 1.44 for that clock.. my Q6600 needs only 1.4v stable at 3.6 with this board instead of 1.47v with my old x38 quadGT, but u can find tons of guide here if u havent read.
good luck
no probs, bro ;)
happy to hear that 45nm of yours working well now :up:
trima kasih
Not sure if this was posted before, but TomsHardware just did an X48 roundup here:
http://www.tomshardware.com/reviews/...d,1941-29.html
And guess what..the DFI came out on top as the best CPU overclocker..:)
http://media.bestofmicro.com/Z/U/106...l/image042.png
I can't wait for a bios update I hate the fact that my usb or ps2 keyboards won't respond sometimes at boot.
here's a bench of everest photoworxx DFI x48 vs Asus MF at the same clock. guess which one is faster ;)
How have these boards been fairing from a QC point? I will consider buying one tomorrow if people haven't been having too much trouble with the lottery.
EDIT : I see some people have had issues. Time to see what the warranty policy is at my shop haha.
@Martinm210 & safan80: thanks for posting! :up: but this article from HardwareZone is making the DFI get burned by a clown board. :mad:
Bloody hell it is so confusing. HardwareZone got a low OC but I'm going to blame it on their skills. I'm still deciding on whether to get this board or wait for P45. I don't see P45 being that much cheaper, especially when everyone starts piling on the extra things like 4 ethernet ports.
Cellshocks came today. MemoryC rocks for cheap fast shipping:up:. I've got to go to work in about 30 minutes so I'll mess around with them tomorrow morning and post back my results/problems.
works goods cell shock with this board...
E8400 04/02 BIOS
496x8, Memory 1190MHz
2x2GB OCZ PC2 9200 Flex2
XFX8800 GTS (G92)
Yellow Slots Used For Memory
VDIMM Measured 2.120V
http://www.edgeofstability.com/image...ios/main_s.jpg http://www.edgeofstability.com/image...ios/volt_s.jpg
http://www.edgeofstability.com/image...s/dram_1_s.jpg http://www.edgeofstability.com/image...s/dram_2_s.jpg
http://www.edgeofstability.com/image.../clock_1_s.jpg http://www.edgeofstability.com/image.../clock_2_s.jpg
http://www.edgeofstability.com/image...os/phase_s.jpg http://www.edgeofstability.com/image.../feature_s.jpg
Code:CPU Feature Page
Thermal Management Control................Enabled
PPM (EIST) Mode...........................Enabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Auto
Execute Disable Bit.......................Enabled
Virtualization Technology.................Enabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown After AC Loss....................Disabled
O. C. Fail Retry Counter..................0
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................8x
CPU N/2 Ratio.............................Disabled
CPU Clock.................................496 MHz
Boot Up Clock.............................Auto
DRAM Speed................................333/800
PCIE Clock................................100MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................Auto 1.2200V
CPU VID Special Add.......................108.50%
DRAM Voltage Control......................2.150V
SB Core/CPU PLL Voltage...................1.510V
NB Core Voltage...........................1.504V
CPU VTT Voltage...........................1.160V
VCore Droop Control.......................Enabled
Clockgen Voltage Control..................3.45V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Strong
GTL REF Voltage Control...................Disabled
CPU GTL 1/2 REF Volt......................110
CPU GTL 0/3 REF Volt......................110
North Bridge GTL REF Volt ................110
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
T2 Dispatch...............................Enabled
Clock Setting Fine Delay..................Listed Below
CAS Latency Time (tCL)....................5
RAS# to CAS# Delay (tRCD).................5
RAS# Precharge (tRP)......................5
Precharge Delay (tRAS)....................15
All Precharge to Act......................6
REF to ACT Delay (tRFC)...................54
Performance Level.........................Auto
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................2
Write to PRE Delay (tWR)..................14
Rank Write to Read (tWTR).................11
ACT to ACT Delay (tRRD)...................3
Read to Write Delay (tRDWR)...............8
Ranks Write to Write (tWRWR)..............Auto
Ranks Read to Read (tRDRD)................Auto
Ranks Write to Read (tWRRD)...............Auto
Read CAS# Precharge (tRTP)................4
ALL PRE to Refresh........................6
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Auto (7)
Channel 1 Phase 1 Pull-In.................Auto (7)
Channel 1 Phase 2 Pull-In.................Auto (7)
Channel 1 Phase 3 Pull-In.................Auto (7)
Channel 1 Phase 4 Pull-In.................Auto (7)
Channel 2 Phase 0 Pull-In.................Auto (7)
Channel 2 Phase 1 Pull-In.................Auto (8)
Channel 2 Phase 2 Pull-In.................Auto (8)
Channel 2 Phase 3 Pull-In.................Auto (7)
Channel 2 Phase 4 Pull-In.................Auto (7)
Clock Setting Fine Delay Page
Ch1 Clock Crossing Setting................More Aggressive
DIMM 1 Clock fine delay...................140ps
DIMM 2 Clock fine delay...................630ps
DIMM 1 Control fine delay.................630ps
DIMM 2 Control fine delay.................350ps
Ch 1 Command fine delay...................840ps
Ch2 Clock Crossing Setting................More Aggressive
DIMM 3 Clock fine delay...................140ps
DIMM 4 Clock fine delay...................420ps
DIMM 3 Control fine delay.................420ps
DIMM 4 Control fine delay.................420ps
Ch 2 Command fine delay...................840ps
Ch1Ch2 CommonClock Setting................More Aggressive
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
XP SP3
http://www.edgeofstability.com/image...prime_xp_s.jpg
http://www.edgeofstability.com/image..._3d06_xp_s.jpg
http://www.edgeofstability.com/image..._crysis_xp.jpghttp://www.edgeofstability.com/image...190_ut3_xp.jpg
3dx Max w/V-ray
Time to render: 14min 32sec
http://www.edgeofstability.com/image...chmark_680.jpg
Everest - Right screen shows C1E enabled
http://www.edgeofstability.com/image...erest_xp_s.jpg
Vista 64 Bit SP1
http://www.edgeofstability.com/image...prime_64_s.jpg
http://www.edgeofstability.com/image...dmark_64_s.jpg
http://www.edgeofstability.com/image...mark_van_s.jpg
http://www.edgeofstability.com/image...0_pcmark_s.jpg
http://www.edgeofstability.com/image..._crysis_64.jpghttp://www.edgeofstability.com/image...190_ut3_64.jpg
3dx Max w/V-ray
Time to render: 15min 56sec
http://www.edgeofstability.com/image...erest_64_s.jpg
anyone have try last beta bios for this board?
LANPARTY LT X48-T2R
2008/05/30
File X48AD530.exe
Major Reasons of Change:
Added New Micro Code for 45nm family CPUs
praz: - nice results with 4gb.and vantage. my score was alot lower than that , i wont post it since its fairly misserable lol
just wondering if u tried tighter settings with ram and what happend . also do u think theres any benifit to setting tref higher ? with either latency or stability? i have mine on 16383T but didnt notice a difference . not sure what its function is exactly.
What is the maximum FSB with dual core support in this motherboard?
It's possible 555MHz in the bus ?
very nice praz
hey praz in your opinion which board do you like better for max crasy clocks, the p35 ut t2r or the x48 t2r?
