Originally Posted by
unclewebb
roflcopter: Adjusting the shortcut properties shouldn't make a difference. I'm using XP and have RealTemp in my Start Up folder and it starts up Minimized in the System tray area. Where do you have the RealTemp folder located? Some users have problems because they are using a limited account and then stick the RealTemp folder in a location like C:\RealTemp that they don't have the priviledge to read or write to so their settings are not saved. Try putting the RealTemp folder on your Desktop and make sure Start Minimized is checked. Give me some more details if this doesn't work for you like what OS you're using so I can investigate further.
