Wont even boot 1 stick up. I have OCZ Alpha PC8000. Do i need to go and pinch some mates memory?
looking at the smartguardian screens you posted, does 'fsb vtt' refer to the cpu vtt or the nb vtt? And yeah, does vtt count for getting high fsb or high cpu speed?
cpu vtt = fsb vtt. just labeled differently.
vcore is what helps get higher cpu clocks, while fsb vtt, and nb core helps with higher fsb. mostly people who are running really high memory speeds need to increase the voltages more.
I find that for the most part, people on these forums are using way too high NB and FSB voltage for what they are achieving. thats imho though.
When I try to disable PPM (EIST) Mode Windows will always crash the second it starts up.
Any ideas to fix it so I can turn EIST off?
I hear ya about the NB, been contemplating adding to my loop, as I have 2 mcw 30's sitting around collecting dust, but been to lazy to do anything about it. Also was thinking about mounting my apogee to it, as it would fit, but also too lazy. I have 0.2 more V on mine for my ram @ 1113, needed it to get quad 32M stable.
I am going to pick up a thermaright HR for the NB and see how it works compared to the enzo I have on it now. First things first though, gotta play with the transpiper on Monday :)
i got my e8500 today so ill let you guys know how i get on with it
yes please, im been waiting for results with this board and that cpu
PWM temp's got down from 59max to 56max after 5 day's burnin, with the MX2 it looks like it's working great now will mount 60x60x15mm fan on the heatsink and I think it will stay bellow 50c @ all times. I'll report again about it when I got my mobo out again :)
balls!!!
i just tried 9*500 on my e8500 and the machine spins the fans for a few secs then goes off :( going to try clearing the cmos before i cry
I got my new board a few days ago and it's working pretty well.
450x8 1:1
http://www.abload.de/thumb/dfix38_450x8chn.jpg
Settings:
Code:CPU Feature
- Thermal Management Control: Enabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Enabled
- Virtualization Technology: Enabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 8
- Target CPU Clock:
CPU Clock: 450
Boot Up Clock:
DRAM Speed: 333/667
- Target DRAM Speed:
PCIE Clock: 100mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU VID Control: 1.3875
CPU VID Special Add:
DRAM Voltage Control: 2.15
SB Core/CPU PLL Voltage:
NB Core Voltage: 1.456
CPU VTT Voltage: 1.211
Vcore Droop Control: Disabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disable
x CPU GTL1/3 REF Volt: 110
x CPU GTL 0/2 REF Volt: 110
x North Bridge GTL REF Volt: 110
DRAM Timing
- Enhance Data transmitting: Normal
- Enhance Addressing: Normal
- T2 Dispatch: Enabled
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: AUTO
- DIMM 1 Clock fine delay: Current
- DIMM 2 Clock fine delay: Current
- Ch 1 Command fine delay: Current
- Ch 1 Control fine delay: Current
Ch2 Clock Crossing Setting: AUTO
- DIMM 3 Clock fine delay: Current
- DIMM 4 Clock fine delay: Current
- Ch 2 Command fine delay: Current
- Ch 2 Control fine delay: Current
Ch1Ch2 CommonClock Setting: Auto
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto (where cpuz sees 1T or 2T SETTING)
CAS Latency Time (tCL):4
RAS# to CAS# Delay (tRCD):4
RAS# Precharge (tRP):4
Precharge Delay (tRAS):12
All Precharge to Act: 4
REF to ACT Delay (tRFC): 42
Performance LVL (Read Delay) (tRD): 7
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
- Channel 1 Phase 0 Pull-In: Auto
- Channel 1 Phase 1 Pull-In: Auto
- Channel 1 Phase 2 Pull-In: Auto
- Channel 1 Phase 3 Pull-In: Auto
- Channel 1 Phase 4 Pull-In: Auto
Ch2 Read delay phase (4~0)
- Channel 2 Phase 0 Pull-In: Auto
- Channel 2 Phase 1 Pull-In: Auto
- Channel 2 Phase 2 Pull-In: Auto
- Channel 2 Phase 3 Pull-In: Auto
- Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): 14
Rank Write to Read (tWTR): 11
ACT to ACT Delay (tRRD): 3
Read to Write Delay (tRDWR): 8
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): 3
ALL PRE to Refresh: 4
I cant seem to get 475 or more to post, not sure what the issue is I have tried upping nb vtt ram and vcore but no matter what i do it wont boot at 475. I even tried lowering the multi on my chip and no go. Any ideas?
boooooooooooooo!!!!!!!!!!! no more testing for me... my psu just blew up :|
every over clock above stock wether it be 500*9 or 450 * 9.5 with 1.450000 on vtt, 1.5 on chipset, 1.45 on cpu caused the machine to just switch off after 1 second.
just tried another overclock and *spark* my psu blew up -no stand by light on the back of the psu or board. the psu smells of burning :( since i have no other psu to test with then im not sure if my components are broke :down:
the other worrying thing is that i got that psu from scan about a year ago but when i bought my e8500 from them yesterday i had to re-create my account because my details "somehow were deleted"
wow sorry to hear that sounds like the psu was def holding you back then
Most likely the PSU holding you back as the board seems to like these processors. Not really a high clock but this was done from a CMOS clear with completely default settings. Haven't really had time to do much else yet.
http://www.edgeofstability.com/image.../misc/3690.jpg
Can anybody tell me in short how to work with Clock Fine Delay settings?
And what does "- DIMM 1 Clock fine delay: 7 (raised from Current 2)" in practice mean?
Is there any differences between running two modules of memory in slots 1+3 VS 2+4?
Sorry about it Origin, was this the Etasis 850W server grade PSU in your sig?
Put a E8500 in my board a few days ago but somehow i cannot get this thing working in the x38 like a q6600.
FSB will not boot higher than 518
Memory is absolutely not stable at almost every speed/divider ....
The board is acting like a 1st class ........ with the e8500 and is in need of a bios that fixes this ASAP !
I have got the exact same problem with my board and the e8500 but it will only do this with the 11-1 bios it works fine with the 1st release bios (my favorit).
Right got some mates ream in there, booted bios changed to 2.27V and put in only 1 stick of my OCZ PC8000 and still comes with with C1 and wont boot.grrr. Do i need to up northbridge?
Also my board wont turn on from case button(yes I have connected the cables from case to mobo but doesnt work) anyone else had this trouble?
yeah it was :( i think ill go for a silverstone decathlon or a PCP&P.
It's weird, ive bought 2psu's from scan and they've both blown up shortly after the 1 year warranty :( (im not blaming scan btw). I think this etasis is just over the 1 year :(
i did. It's VID 1.1125V
i know :( i'm quite lost without my pc now -planned on doing alot of testing this weekend.
i bet it didnt short tho :rofl:
