.785 vREFs - i'm currently using .675 for my OC seems to like it and i've only got a vCORE of 1.325v
The ud3 reads refs differently from the p5q so you cant compare the numbers directly, the 0.785 on the ud3 is about the same as the .655 on the p5q and the 0.800 is about .665-.670 on the p5q.
Guys what is the best batch# of Q9650?
There are a few good ones, and there seems to be some variation between the chips within a batch. Have a look through this thread, there's lots of good examples.
systemviper is selling x3380. Even mfII would be enough for 9.5X.
500 FSB stable on the m2f is very unlikely tbh. 470 FSB large FFT and blend stable is all I could do. My chip is a good one too but the board wouldnt do any better. In fact my X48 REX did better.
Yeah i am trying to find a UD3P to replace my maximus formula x38 that is down right now. I would like to see what i can do with my q9650 now that i know there was a board made for them.
yet another update :) ..... 470*9 now at 4.230Ghz - Gflops gone up too - temps ok and 20 linx stable, 8 hours p95 stable too
i recon this chip will easily do 490*9 but i'm not so sure for 24/7 usage - its 4.23Ghz @ 1.325v 24/7 - i might go to 480mhz with 1.35v - i'll see!!
Nice work, my P5Q-D topped out at 473 FSB, but it isn't a great example and had an A2 rev NB. Does your board have an A2 or A3 rev NB? (check CPUZ in mainboard tab). Is it prime 95 large FFT stable?
i've got the A2 nb!!!! gonna get 4.4Ghz out of this beast - i've had it at 480mhz this week and trying to stablize it - but 470 is good 4 my 24/7 - until 480 is stable!!!!!!:)
its 20 linx loops stable and i only do 6-8 hours P95 as its a waste to stress HW for that long as its never going to happen in games etc..
sorry cryptik - to answer your original q - i think i use large fft yes - i'm not using blend as my ram is running 1:1
Guys! I`ve just bought Q9650!
Batch is L842B847.
Nice one, hopefully you'll like it :up:
Congrats she is a lil beastie :) lot of fun to play with :up:Quote:
Batch is L842B847.
I will get to home on Sunday :) Some numbers soon :up:
well I have been waiting for my cpu pot to get here so I can put my i5 650 and the memory under cold for the Gigabyte H55N challenge, so instead of waiting around I hooked up my 775 rig which is new to me.
Nkresho's old chip (C batch, 1.15 VID), UD3R and GSkill PI 9600's
http://i35.tinypic.com/2uy56b7.png
I can not run linx as it gets too hot even under my loop (EK Supreme HF>Swiftech Micro Res>XSPC RX360 rad w/ 6 SanAce fans in push pull>MCP655) and just restarts however prime blend is looking great:up:
That is an awesome cpu. Nice work.
all this batch L847C are very good clockers if you could beat the temps :S, still to find time to get a good breath to build my watercooling, but my temps 3.2/1volt linx->~60... push-pull ultra 120x@ 1000rpm, dictate a watercooling setup as fast as possible...
Yeah I have an L847C too, it's very hot :D
Vid = 1.2125
great so see this thread alive again
*congrats on the chip l0ud ;)
I think NKresho got the best chip that I have seen from that C batch. I doubt though without some kind of xtreme cooling it will do 4.5ghz linx. My chip is a 1.175vid, it passed blend at 4500mhz 14hrs but have tried many times to get it to pass linx at 4500, temps get to hot and it just wont do it, even with cold AC blowing on my rad. Only reason to keep trying would be to get the chip in that linx thread, other than that I prefer a good blend run over linx any day to test stability.
http://i34.tinypic.com/ayox2g.png
super stable and I think I can lower some volts:up:
It is so nice to finally find a golden chip.
thats impressive L0ud!!! what sort of voltages are you using - PLL,vTT,GTLs etc....
and have you run linx yet??? interesting to know the sort of Gflops this beast pumps out!!
I can get it stable at 4.3 GHz on air (prime only, LinX way too hot), but I'm board limited after that as I'm using an X48 Rampage Extreme. Does very well for an X48 though, better than the P5Q Deluxe and Maximus II Formula I tried with it.
The hot ones are seriously hot, hope you have good watercooling!
100% airconditioned air going through my 220 rad and absolutely no ambientQuote:
air in the WCing setup.AC coming from the vent hose is about 5c in early morning
and 10c at the hottest part of the day.ugly but it works
http://i38.tinypic.com/29wa0yh.jpg
Thats a great idea for the rad radaja, any condensation issues?
none so far,been doing it on and off for a year or more now.
linx gets way too hot and I get a restart before the first pass no matter what the settings or voltages, this chip shoots in to the 80's like its no bodies business so no more linx until it goes under cold which will be very soon and then just then maybe. I also have a higher VID chip coming which I hope will do 4.5 linx stable.
my voltages are all default except:
vcore 1.37500
vtt 1.34
MCH 1.4
VDIMM 2.12
the reference values are .785/.800
very true,room has to be very cool too.i have two AC units running and ambients are also very cool,thats how my ram and MB/NB stays cool too.:D
this setup works better in my case with the ac blowing through the rad into the case so it all very cold all the time:up:
You must have a pretty low Dew Point in your computer room due to the AC. Nice idea with the rad cooling :up:
you guy make me wanna pull the pi 9600 again and up the voltages , with those i seem to not get pass 4250 stable , me and andressio tried a bit but think 1.1 board seems to not like pi 9600
i put a thermochill 120 on case and plan on havin a/c ducted to it:D
:yepp:
but i dont like to freeze:rofl: and if water gets too cold gotta put a/c temp higher to avoid condensation
if i were to run linx i leave it to the max a few min before i start
You were right, guys :)
I oced my Q9650 for 450x9 for now @ 1,25volts. 5 hour Prime64bit running is stable.
Couldn`t you post your 500x8 and 500x9 bios setting for Q9650 on Maximus II Formula please :up:
Some pics soon
i dont think there are very many stable 8/9x500 templates for the Q9650+ maxIIformula
And i need performance level 8 ofcourse :)
i think grnfinger had a Q9650 at 9x500 in the maxII thread
I'm slooooooooowly (as time allows) moving from Q9650/x48 Blackops to one of those newish gigabyte p45 usb3 mobos. This is not something I wanted to do but that's life. Reaching Q9650/450-460 fsb on x48, with preferred settings/stability/AIR-COOLING, took a fair amount of effort.
I REALLY hope there are no Q9650 issues with these gigabyte p45 usb3 mobos :D.
XmX
andressergio has done great with his EP45-USB3 and his quads:DQuote:
you shouldnt have any problems doing 500fsb:up:
aaa yes you will have HORRIBLE stability issues :D
http://img828.imageshack.us/img828/6627/50061.jpg
http://img576.imageshack.us/img576/3...cr2pl7linx.jpg
