Thanks,
Tell me if you need registers dump or anything I'll try to get them.
For some reason main windows has a blank Memory filed too. 2GB memory modules installed in slots 2, 3, and 4.
Thanks,
I will enable/disable Turbo Mode and/or the Multiplier via command line to reduce the power consumtion. :-)
On my w3520@4.2GHz i need ~320W on Multiplier x21. If i reduce the Multiplier to x12, power consumtion droops from 320W to 285W. My Systems runs 24/7 365 Days/year. In the night (an when the PC are not in use) i will reduce the multi with a script via a idle scheduler.
=> Chike: use this version: MemSet41.zip.
=> Cumulonimbus: enable EIST and C1E; if it's works, the best is to have these enabled in your bios.
i think i see what you mean
there was a program that could do that on amd64 and older platform called crystalCPUID
who would control multiplier/vcore according to the CPU's % of utilization, but i guess it's a bit far from this app origin.
I'd love to see some kind of profiles with multi and vcore stored in it, so you can use for example: night mode, full power mode and a 2d mode.
EIST is way too sensible, keeps going up and down and doesn't control vcore when oced
Is there any chance of memset supporting the Poulsbo chipset (Intel SCH US15W). I would really appreciate if the developer did so (would gladly donate to help if this is done). Since the gma 500 graphics uses the system ram, lowering the timings will greatly help the crappy gma 500.
=> Cumulonimbus: don't expect this feature for now, perhaps later.
=> DarthBane: could you make a registers dump (with cpuz->last table->registers.txt)
and send it at memset@hotmail.fr
Yes i got to try this and Thanks for the share.
Here is the 1.4 finale version: CPU-Tweaker 1.4.zip
I would like to add a monitoring panel in the next version...
http://img25.imageshack.us/img25/1238/cpu15b1.png
...but I don't know when I will be able to share a first beta. :)
Thank you very much for the continuous support for the overclocking community FELIX :)
On MSI GD65 with 1.7 bios CPU Tweaker 1.4 doesn't change timings at all. Is there any change to fix it?
Felix, one extra feature would be nice, integrated memtest :)
Hi, on my Sony notebook, which has an Intel i5 M520, CPU-Tweaker says "NOT FOR THIS SYSTEM". Why?
-> bartx: Read post #1184 in this thread.
-> Testa: Could you make a registers dump (with cpuz->last table->registers.txt)
and send it at memset@hotmail.fr thank.
Just wondering if memset will work with a ssd drive I just up-graded my memory from 4 gigs to 4+2 I also up-graded to a ssd drive now when I try to run memset the "apply" are is grayed out, it use to work before I up-grade my memory and ssd drive. This is a great program and I wish it would work again...
-> takovr: I don't understand how a new SSD could lock the mchbar.Have you upgraded your bios?
->Testa: You can send all of it.
No i diden't up-date my bios, the only thing i changed was I installed a new ssd drive and up-graded 4 gigs of ram to 6, i have a 4 gig stick and a 2 gig stick. When i run memset it showes the right timmings 7-7-7-20 but the apply buton is "grayed" out. I use to be able to get 6-6-6-15 for mem overclock, I did notice though when i chage the times to 6-6-6-15 when i
re-boot cpuz tells me my timmings are 10-6-6-15 any reason why the apply button dosen't work ?
Even though I get the message that 'MC_CFG_space Locked' I was always able to change my CPU Multiplier, EIST, Turbo, and C1E.
Since the version of CPU-T where the separate CPU window was eliminated in favor of an all in one window I can no longer change these CPU values.
Any thoughts on this? Seems that being locked doesn't lock everything.
Is there any way to unlock the RAM settings for an AsRock X58 Deluxe and Deluxe3?
anyone home?
=> Testa, streetwolf: I am very busy at the moment, but a revised version will come soon.
=> takovr: Could you make a registers dump (with cpuz->last table->registers.txt)
and send it at memset@hotmail.fr . Thank.
=> cyclone3D: Read post #1184 in this thread.
