makes reading forums much easier and it automaticly switches back to normal viewing when i turn the monitorQuote:
but tell me that u don't play games like that ;)
hmmm having two three monitors turned vertical side by side, talk about wicked, well in theory anyway.
only tetris...lol j.k.Quote:
naw cant think of a reason why i would play that way
Originally Posted by vexvegaz
One reason and one reason only.
FLIGHT SIMS! I would have a sweet field of vision, with the Head tracking Kit, and one vertical monitor, and two horizntal. except the vert one would have to be the DELL 30"! WOOT! if it supported that use:D
now that si Xtreme :)
I just redid my wc because i recently killed my opty 148 with no warranty by taking the ihs off and knocking off an ic, so i have some free time. anyway, i made the tubes alot shorter and the wc box under the case, which i just rushed together, so its notjhing special, anyway, i dont have any ram cpu or video card in it, but its ready for them ;) -dont think ive seen you on eocf in awhile SaFrOuT
http://img152.imageshack.us/img152/5...lelr3wd.th.jpg
sorry, forgot to give specs. its a mag3 pump, dual heatercore with 2 120x38 panaflo medium speed fans which are mounted to the other side of the small case on the bottum, a dd rbx, maze 4 acetal and mix of tygon tubing and harder home depot stuff, with a 1:1 mix of dex-cool and water. anyone ever use dex-cool?
Is that a T-Line just in front of the CPU block? :nono:
yeah:( does it hurt the flow or something? i was going to change it but i didnt for some reasonQuote:
Originally Posted by jrw
*it was just the highest point of the loop
A T-Line should ALWAYS be positioned just before the pump.Quote:
Originally Posted by XFxGeforced
The purpose of the T-Line is to provide a surplus of water to the pump so that it performs its optimal.
In other words. Change loop order RIGHT NOW. :)
well my pump is already a little too powerful for my taste. it tends to squeeze my tubes. and what do you mean by a surplus. if i cap the tline and its a closed circuit, everything will be getting the same air, and if i made my tline at the pump, do you see where it is? i could never get the air out of the line that wayQuote:
well it wont be much difference when the loop is full. its only when filling, that the line its better to have in front of the pump. the t-line restriction doesnt change from one position in a setup to another. so just leave it where it is!Quote:
thanks, that's what I was thinking/hoping. Btw is that avatar cleavage of a butt?Quote:
Originally Posted by eXa
Wow...Quote:
hahahha
Hahah owned.Quote:
that is supposed to be his girlfriend's cleavage.
hm maybe ill shave my but and use that instead... :moon:
didnt mean as an insult, just asked that because I've seen pictures online where people make their butts look like cleavage :slap:Quote:
*you guys got me crackin' up. I had no idea :(
no offence taken! ;)
I think all this talk is just boosting his ego, cause if that is his girl, he has a right to brag, hell my gf would not let me do that, and I would have to put up a avatar that would turn her bright red :fact:
added a few cathodes twords the back. Side panels arriving tomorrow :D
http://img88.imageshack.us/img88/2694/gutz9oq.jpg
@ Phelan:
yeah something like that :D
@ JME
wow dual AquaComputer pumps (1046) thats... youd be better of with an ddc+
Holy crowded case batman!
more pics, less chatter
