strong mems and imc there alex :)
- all scores added up to this post
- ICs added for all the scores that were missing IC info ( only if I know the IC for sure of course )
- new top 3570K score marked
Enjoy! :up:
165k views :X wowzers
l0ud_sil3nc3 - 6:18:953 - 50x100.0 - 1300MHz - 8-11-7-22- - Asrock Z77 OC Formula - G.Skill 2133 8-9-8 2x2GB - 1.87v - Cpu LN2 / memory air 3570K
http://i.imgur.com/wIdI5Sb.png
Still implement this rule?
I saw some scores exceeded this limit.Quote:
1. Screenshot Requirements:
5ghz +/- 3mhz
Screen shot just for info if anyone's interested.
After seeing Alex-Ro's post I thought I'd have another look at 2860 10.12.12 to see if I could match 2800 9.12.12. Looks like with a little more tweaking 2860 10.12.12 could run shoulder to shoulder with 2800 9.12.12 using a fair bit less voltage. I killed the bios after this shot recovered it then killed windows so that's it for now.
20oC ambient in a case.
http://i106.photobucket.com/albums/m...2126M18859.png
More volts than I wanted to push through these sticks that I'm supposed to be saving for Haswell but hay ho it was worth it.......
C-N - 6:18:141 - 49x102.09 - 1430MHz - 9-12-12-22-114-1 - Gigabyte UD5H - Corsair Platinum 2666 CL10 2x4GB (Samsung HCH9) - 1.99v - Stock Air
Ambient 17oC
http://i106.photobucket.com/albums/m...2126M18141.png
Crap,i remember i tested my samsungs and passed couple of loops at 2933 9-12-12 at 2v+ with -5 ambient,i might switch mobo to feel my wrath.....:D Joking aside,great run :)
Thanks mate it was good fun :up:
I'm sure there's a little bit more left in 2860 C9 sub 18 should be doable but for me that's enough. I'm not even going to attempt 2933 but by the sounds of it you are real close.
He he if you feel the wrath maybe try 104.17 x 48 that'll get you 5G & 2917 ish & you can work from there if your sticks don't melt first :D
Awesome run C-N:up:
Next stop is sub 18 with samsung:D
Really nice work C-N and Alex-Ro,
Hey guys,I thought since im starting to use this forum more now and some nice people on here its about time I paid my subscription,I am Extreme :yepp:
I look forward to posting and viewing plenty more results
Bull
:eek: 5G Haswell at least 6s less, did not think about that range.
:yepp:
Woohoo,maybe sub 6 mins :D
Guys, quick question...got 4x2gb psc good for 2400mhz and 2600mhz with decent timings under 1.85v. Which should I run to benefit from that config? XP should do better, but it's only 32bit (xp 64 was a mess from what I gather)
Thanks! :p
xp32 you use maxmem anyway ;)
Yeah...figured so, but the whole 4x2gb thing still confuses me lol xD
with 32 bit still every stick is used, but memory is limited. anyway as alex said, you use maxmem limitation and spi does not need that much memory ;)
Yeah...it's an interesting art form, superpi 32m tweaking that is.
I got microxp atm, gonna try a few different oses and tweaks before submitting anything.
Doubt I can do any better than the top scores though :p
nachtfalke - 6:18:000 - 49x102.1 - 1429.8MHz - 9-12-12-21-115-1 - Asus M5E - G.Skill TridentX 2666 CL10 2x4GB (Samsung HCH9) - 1.92v - Stock Air
http://i900.photobucket.com/albums/a...psbf49b1df.png
Awesome run nachtfalke:up:
Can you try to run 5ghz +/- 3mhz?
