Thanks Vivi:D
Yours is awesome too:) Love your 285's '01 run:up:
I suspected the old enemy of condensation that killed it, but also my CWT 1300Watter psu was on the brink of dying @ that time. Few times MIVE gave an "overvoltage warning" in bios:(
My new 2600K L101B801
54X multi; 5455 wall
VID @ 3.4GHz = 1.2109v
2600K L045B387 VID@3.4GHz = 1.192 - Is it good? And any suggestions for vcore for 5GHz? And the other voltages as well...
I'm @
4.6GHz 1.35v
4.7GHz 1.38v
(strange if)
AsRock Extreme4 Motherboard
Patriot Division 2 9-11-9-27 @1866 1.65v
O_O
That's the lowest VID I've seen (at stock)....
Yet my VID at 5 ghz is 1.3611...(in bios and RT).
Guess at one point RT is stop checking and saying 1.3611 for everything.
Able to boot @56multi with Ait cooling.
Soon will be watercooling thsi machine for quieter use. And will see what's going on.
Still hard to stable it @48Multi and above with air.
RAM is 2x4GB 1.65v so... yepp.
is it bad for the VTT to be 1.051 when the Dv is 1.65. diff >0.45
what anyone ever tried batch L102b281?
I'm glad I decided to try my luck again today at the local Microcenter. L046B028 2600K. 5ghz at 1.408V loaded. 56x multi. 51x multi without pll overvolt.
I dont get a very good OC on my 2500K. I havent done much tweeking but some quick and dirty OC'ing by just wratcheting up everything and setting it to even 45X or more and its not stable. Anyone got any ideas for me because I have followed the OC guides but I still havent seen a good stable OC over about 4.5 Ghz. Maybe its my WS revolution board. Iono.
2500K batch # 3101A127.
Letting Asus utility do a quick OC from the desktop it sets me up at 4.2Ghz and 1.195V. What does this info tell me exactly in terms of OC ability? Anything?
2x 2600K's incoming with in 48-72hrs.. will be paired with a UD4-B3, is 4.5Ghz a guaranteed minimum OC?
anyone know how to find MAX multi on 26K or 25K ?
Fastest way plz
With low air / stock cooler, disable PLL overvoltage, 1.45v , 2cores, HT off ( 2600k ) . Start with 50x, and walk your way down.
Your max multi will more likly be [multi without PLL ov ] + 5. So if you can do 50x without PLL ov you 55x will be your max multi.
I have a silverstone zues 750zf (3yrs old)and silverstone strider gold 80 750watts (brand new) on my end and will be initially testing the OCing on the strider 80, in this case would the PSU matter in overclocking or its not really a concern ?
Think I'm done with SB. Gonna go back to 1366 and wait for Ivy Bridge. No more binning SB CPUs.
Did you at least try swapping the board first?
