Sweet I hope mine will do the same. Not bad 2 great batches here for me now.
http://i274.photobucket.com/albums/j...e/IMG_2778.jpg
http://i274.photobucket.com/albums/j...e/IMG_1686.jpg
Started testing this newest member of my week 45, 2008 batch family - i7 920 3845B260 cpu. Nice temps although 4Ghz prime95 mark vcore required is slightly higher than my other cpus.
http://nx.i4memory.com/reviewimages/...845b260_01.jpg
http://nx.i4memory.com/reviewimages/...845b260_02.jpg
System:
- Intel Core i7 920 3845B260
- EK Supreme LT 1366 / FESER 480 / MCP655
- Asus P6T6 WS Revolution
- Gskill Trident F3-16000CL9T-6GBTD
- 512MB Inno3D 8800GT OC Edition 190.62WHQL
- 750GB Samsung SATA
- Pioneer DVR-217 DVD-RW
- Corsair HX1000 PSU
- Dual Boot - WinXP Pro SP3 (nLite fully updated) with Vista Theme & Win7 Ultimate 64bit RTM
4Ghz Prime95 Comparison results
- W3520 3845A935 - 4ghz HT enabled at 1.184v
- W3540 3845B010 - 4ghz HT enabled at 1.168v
- i7 920 3845B260 - 4ghz HT enabled at 1.216v
i7 920 3845B260 default auto vcore and 4Ghz 1.216v Prime95
http://fileshosts.com/intel/Asus/P6T...ime95_load.png
Thanks for that- will be interested to see further progress;)
My 3845B260 does 4.2 @ 1.244 full load, LinX stable etc. Have serious problems with my GB Extreme above BCLK 210-215, despite my best efforts. Went all the way up to 222 easily on a friends EVGA 758 board, so may get one of those...
Nice angelreaper you got exact same batch as my w3520 :)
uranium, your cpu looking good is that with peltier-chilled H20 ?
Next stop 4.2Ghz at 1.288v. i7 920 3845B260 seems to be one of those higher vcore low temp cpus - it runs around 0.05v higher vcore than my Xeon 3845 cpus but runs around 3-5C cooler than my W3520 3845A935 and around 10-13C cooler than my W3540 3845B010 at same clock speeds even with higher vcore requirements!
Yes it is:) Keeps the CPU at low 50s C running LinX at 4.2 GHz:)
Peltier set-up is here, in case you are interested:
http://www.xtremesystems.org/forums/...d.php?t=230755
Hmm if thats creazy then what it is? sick? :p:
http://img519.imageshack.us/img519/1460/3845b027.jpg
http://img18.imageshack.us/img18/5194/4200r.jpg
update result
Test on R2E 1504 bios
i7 920 D0 3910A778 1.1v VID
Trident 12800 6-7-6-18
http://i37.tinypic.com/2v0lx01.jpg
Got my self another Batch 3849A914 ... not too shabby ... :D
http://img4.imageshack.us/img4/1667/imo4134mhz132v.png
Managed to boot in to windows and grab the validation 4700 MHz @ 1.49v ;)
Perhaps theres more in it with water....I sense 5 GHz :rolleyes:
Core i7 920 D0
Batch 3849A914
4700 MHz @ 1.49v
http://img251.imageshack.us/img251/7219/4700.png
Lindasso Wagner hahahha,Congrats my Friend
i7-920 [3849A837]
CPU: i7-920
Mainboard: DFI UT X58 T3eH8
RAM: G.SKILL DDR3 6G PC3-16000 TRIDENT 2x3G
VGA: ATI HD5870
HDD: WD SATA2 500G
Power: OCZ-Z1000W M
Cooler: WATER
OS: Microsoft Windows 7 Utimate K 64bit
http://cfile22.uf.tistory.com/image/...4ADF026D840C9F
http://cfile29.uf.tistory.com/image/...4ADF026E869C9D
http://cfile3.uf.tistory.com/origina...4ADF026F87FA1F
1M
http://cfile4.uf.tistory.com/origina...4ADF0270895C49
32M
http://cfile2.uf.tistory.com/origina...4ADF02728BC627
http://cfile2.uf.tistory.com/origina...4ADF02728CFC3F
wPrime
http://www.playwares.com/xe/files/at.../screen004.jpg
Prime95
Xeon W3520 [3910A724] 4.4G
http://cfile29.uf.tistory.com/image/...4AD5E1872E1ACC
http://cfile29.uf.tistory.com/image/...4AD5E18930DC4B
http://cfile30.uf.tistory.com/image/...4AD5E18D36C609
CPU: Intel Xeon W3520
VGA: ATI HD5870
HDD: WD SATA2 500G
Power: OCZ-Z1000W M
Cooler: WATER
EIST Function: Enabled
CxE Function: C1E
CPU : 1.4v
VTT : 1.5v
RAM : 1.69v
http://cfile24.uf.tistory.com/origin...4AD90A5131BBBA
1M
http://cfile10.uf.tistory.com/origin...4AD90A5232644A
32M
http://cfile23.uf.tistory.com/origin...4AD90A53343D56
wPrime
http://www.playwares.com/xe/files/at...a331086275.jpg
3DMark06
http://www.playwares.com/xe/files/at...04bcf4da65.jpg
3DMark vantage
Olha onde o Nash veio me achar?? :rofl::rofl::rofl:
Thanks, that cpu is not that bad..:D:D
Another result:
http://img62.imageshack.us/img62/1111/wprime45003.jpg
namegt very very nice batches there as well :D
very nice cpu there mate :D
Trying to figure out max super pi 32M bclk headroom for this i7 920 3845B260 cpu and it looks very nice managing to boot straight from bios into windows at 227bclk bios set (226.8bclk) to run Super Pi 32M and then using Asus TurboV to push bclk to 228bclk (227.7bclk) to run Super Pi 32M. Ended up with screenie @229bclk (228.7bclk) :)
System:
bios set boot into windows @227bclk
http://fileshosts.com/intel/Asus/P6T...8m49s969ms.png
TurboV bumped to 228bclk and 229bclk
http://fileshosts.com/intel/Asus/P6T...8m47s781ms.png
http://fileshosts.com/intel/Asus/P6T...ker_576061.png
Nice bclk eva :)
Is it the cpu that limits higher bclk or the P6T6 WS ?
How much PCI did you use ?
On my GB Extreme with 103 PCI this is max I can boot and run with stability:
http://img.techpowerup.org/091019/43...nx%20small.png
Ok, I do not have a SS, but here is my validation for 4.8Ghz:
http://valid.canardpc.com/show_oc.php?id=794165
Batch is 3849B018 and was done under phase. It's on the Blood Rage after I did the PCIe mod and was able to take it to 231Bclk x 21.
Nice Utnorris :up:
You can't go higher with BCLK?
Have to RMA my BR, it blew up. :D
