Nice craig, what kind of cooling?
General question for all: Whats the highest vcore an AMD can take without frying it? Just wondering I'm modifying my BIOS.
Here's a totally unstable max screenie from my week 33 FX53 + R507 prom cooling
http://home.exetel.com.au/codered/fx53/cpuz3256.jpg
Its a good chip ... ehh. This chip will do most benchies at 3127 MHz. See my sig for superpi, pifast and 3dmark01.
A R404a system. I always give my A64s 1.7V as if it was the "stock" voltage.Quote:
Originally Posted by =[PULSAR]=
True :DQuote:
Originally Posted by flytek
1:1 real gives a lot performance even with CL3 3-4-4-8 1T like mine
http://www.thelab.gr/attachment.php?s=&postid=110436
Also MEM performance / Bandwidth is Huge when running CMD 1T @ 295 1:1 :D
http://www.thelab.gr/attachment.php?s=&postid=110345
So as I'm wating for the +3000 s939 to be in stock at the local store...I was wondering what mobo I should go with, I was looking to pick up the AV8 S939 K8T800PRO...but if you have any better suggestions please let me knw.
thx.
My CPU: 2800+ CBASC 0413MPM - this is a good week (I tested few and all worked at 2450-2500MHz at 1.5V).
WC-cooled...
2550MHz 1.5V - full stable (Prime95, Superpi, bencharks etc.) 24/7
2700MHz 1.5Vx110% superpi 16M passes at 13'14" - ftp://83.16.182.254/Superpi_16M_13_14.jpg
2727MHz 1.5Vx110% superpi 1M at 32" ftp://83.16.182.254/superpi32s.jpg (I don't like that not exact measure time).
Originally Posted by rapra
Great CPU :D
What was water temp ending Super Pi 16M ?
I don't know :) - but rather low - there is outumn and at the mornings is good temperature to overclocking. maybe 15 centigrades...
15 DEGREE CELSIUS in da hause ??
Don't chill the room-mate :slapass:
here's where I'm currently at:
http://www.xtremesystems.org/forums/...id=18058&stc=1
Hi there I have overclocked my 3400+ NC CPU til 2700MHz..
I wonder how much Vcore it can handle safe with watercooling??
Its not very stable tought but here is the picture :)
http://members.home.nl/ethanol/oc.JPG
welcome Speedy-J
you could give it a little more voltage on water but not much. it will just overheat and crash if you give it too much.
- DFI nF3
- A64 3200+ CBAEC 0428RPMW@1.65Vcore
Water temp @ 25ºC on full load, shes stable for me
http://koti.mbnet.fi/dani69/DFI%20nF...%202651MHz.gif
- DFI nF3
- A64 3200+ CBAEC 0428RPMW@1.72Vcore
Water temp @ 27ºC on full load, shes stable for me
http://koti.mbnet.fi/dani69/DFI%20nF...3MHz%2010h.gif
Ok I have seen a few people...two three in fact that have the same stepping as me.
ADA3200AEP5AP
CAAAC 0345RPMW
9777555K30002
For those of you that do have this what are you getting out of them and at higher clocks do you get memory errors? I need help with this bad.
MSI K8N NEO2
90nm 3200+
GS TCCD
AIR COOLER:HYPER 6
http://my.so-net.net.tw/xu1060/G20.JPG
http://my.so-net.net.tw/xu1060/G16.JPG
@ peter lu
nice overclock m8...:) ime running a 3000+ 90nm on a asus a8v delux rev 2...
this chip need more juice than yours to attain the same speeds...
when i get home from work later ill take some screenshotz...
ime running 290htt @ 1.7v ddr @ 5/4
unfortunatly this ram A-data 4000 dosnet seem to run the 1/1 multy for :banana::banana::banana::banana:... gets buggy at anything over 240htt cas 3-4-4-8-10
where as in the Ai7 it wsas running 280fsb 1/1 2.5-4-4-7... looks like i need some new ram for this setup...
holy crap. 2.8ghz at 1.6v with air is awesome. I am still working out my new winny but the election keeps distracting me;) I am at 260x10 at 1.6v so far.
:toast: Here's to hoping I can make it close to your clock!
Bad mobo :( (MSI K8N Neo FSR)
waiting for RMA to EPoX 8KDA3J
only 2.48 on air (BOX al cooler)
http://www.topmods.net/tin/2488.gif
My Koolance needed to be modded to fit on A64. Damn.
Here's my air cooled FX-55
http://www.aocb77.dsl.pipex.com/3000.jpg
As you can tell from the lack of benches not that stable, will do pifast at 2930Mhz or so though.
Regards
Andy
2800+ NV CG, K8NS, TCCD
9 x 262 24/7 Prime Stable = 2365mHz.....
Venus 12 on LOW speed setting.....
Good enuff' for my multimedia PC
in sig....sata drives are limiting me :(
3200+ winchester, msi
260x10 = 2,6 ghz @ 1,55v rockstable
@ silent watercooling
Heya - I'm new :D
just bought new system (CPU @ MOBO) and wanted to see how far i'll go with Original AMD's cooling @ Adata's 256MB PC3200
(I'm pretty noobish so dont lough at me pls :D )
http://www.hwzone.co.il/ocdb/users_p..._CPU240FSB.JPG
http://www.hwzone.co.il/ocdb/users_p...ndra240FSB.JPG
3dMark 2001SE Rsaults at my signature (9800SE @ Pro no OC)
Hi all,
I am new too.
Got me a Winchester 3500+, check it out:
Click
