Awesome job snow. Looks just like mine.
http://img5.abload.de/img/nt2szj2d.jpg
http://img9.abload.de/img/htpc84s4rqa.jpg
I am cutting the heat-shrinks with one heat-shrinkmodel (verry old :D).
I just hold the 13.86mm long model next to the uncut heat-shrink and then cut it with a pair of scissors.
Then I have to watch out, that the sleeving everytimes is exactly in the same distance to the pin.
to get everytimes the same length of the heat-shrink (on the sleeve) I hold one sleeved cablemodel next to the new one.
Just don't shrink the heat-shrink completely that you can correct the position ;)
Then it should look like this:
http://www.abload.de/img/sleeve2su5yb.jpg
I hope you understood :rolleyes:
How does your sleeving hold tight all the time? I can pull out several of my sleeves on single wires all the time.. i practically have to "drag" it back, so that it atleast looks ok again.
Another thing i dont understand, is how the guy above me can get his heatshrink to hold when he is using that little heatshrink?
Hold the cable horizontal and the heat-shrink stays at its position...
To avoid that the sleeve and heat-shrink move you simply have to shrink over the pin ;)
Excellent work Xien, you should be really proud of the results that you have here mate. :up:
Top quality
Ok here goes some teaser pics for you guys:
BTW the sleeving is done...some more pics later this evening.
http://img707.imageshack.us/img707/5389/img0074k.jpg
http://img197.imageshack.us/img197/8981/img0039up.jpg
http://img709.imageshack.us/img709/2355/img0086ql.jpg
http://img697.imageshack.us/img697/9161/img0061vh.jpg
Thank you Nils.
Great system but I think you are not ready yet ;)
I made a new sleeving tutorial: Sleeving Anno 2010
I am planning to translate it into english and I hope I manage it that you at least understand the meaning :D
2 different EPS extensions :D
http://www.abload.de/img/dsc03686358z.jpg
http://www.abload.de/img/dsc03687muoe.jpg
Nice sleeve job men :up:
I've been dying to re sleeve my PSU cables individually like just about every photo in this thread, and after going through about 20 pages of photos, I have a feeling I'm going to be placing an MDPC-X order soon. After ordering my 5870 that is :)
Hell, probably a new PSU too. If I'm going to do it, might as well do it right, right?
I'm looking for someone to do some sleeving work for me if someone has some good credentials and is located in the stats please send me a pm. Its a rather easy job that involves some fans and power connectors and molex connectors.
I think fhantastic does that kind of jobs
(correct me if I am wrong
Best background ever :D
http://www.abload.de/img/bug1xggl.jpg
PET sleeving ?
http://www.abload.de/img/dsc03705ddzp.jpg
http://www.abload.de/img/dsc03706xfo3.jpg
BURN IN HELL !
http://www.abload.de/img/dsc03710043i.jpg
http://www.abload.de/img/dsc03711r34f.jpg
http://www.abload.de/img/dsc03712u0t7.jpg
http://www.abload.de/img/dsc0371383q4.jpg
http://www.abload.de/img/dsc03714k4h6.jpg
fhantastic
right move :rofl::rofl:
Great idea fhantastic :D
On the Power cable topic:
http://www.abload.de/img/kabel9sxfnw.jpg
I sleeved into the new plug so that you only can see some millimeters of the heat-shrink...
http://www.abload.de/img/kabel10sxfam.jpg
A 7mm cable is no problem for the MDPC-X smallsleeve :D
what's wrong with PET sleeving?
lots of people dont like it in the smaller sizes *under 3/8ths in IIRC) because its 1x1 weave...whereas the MDPC stuff is 3x3...which is much tighter and harder to see through
that one is off-topic, but I'm sure you will be "shocked" a bit :)
One guy did it in 18s days, completely handmade PC CASE!
http://de.fishki.net/picsw/042009/09/walle/tn.jpg
http://de.fishki.net/picsw/042009/09/walle/030.jpg
full story- > http://fishki.net/comment.php?id=50311
andy2kfi
Russian GO, GO :D
