rebels heaven? What the hell is that? I searched it in google, but I aint found anything useful:confused:
this is the rebels heaven
http://www.rebelshavenforum.com/sis-...;f=20;t=000361
http://www.rebelshavenforum.com/sis-...;f=20;t=000362
another quet. for all
there is any voltage mood for P5Q mobo.
ohh s**t I misunderstood it. And what thred to search on this forum? Is there a tutorial thread or something like that?
Can someone please help and tell me how to flash my old bios back to version 1406, i now have 1611 i i cant pass 550FSB, with 1406 600fsb easy. Dice is whaiting my here , but bios not god. I have a P5Q. THNX
this two link for the thread which ket start to mood bios
in the rest of forum you can find the tools and how to use
ise the tool in this thread to downgrad the bios version
http://www.xtremesystems.org/forums/...d.php?t=186538
and then flash using EZ-Flash as you wish
or you can use this method
http://www.xtremesystems.org/forums/...postcount=1396
Ket if i use bios downgradable it stil doesnt work. :confused:
With afudos i have problem too, it says problemm with bootable device ,or file dameged- And i only have 256mb USB key and no floopy:(
question about the mylogo app. I just pulled the dragon logo from a previous post by Ket and used mylogo to insert it into the m1703 bios file I have saved on my thumb drive. do I now have to reflash my bios? If so, since I am using the same bios but with a new logo, can I save an oc profile in the bios, flash with bios file saved with dragon logo and then just load settings from the oc profile?
well.... it didnt work. I ended up creating my own boot logo from my avatar pic (full size, not the actual resized one for the avatar) and used mylogo to insert it into the bios but after I flashed and cleared CMOS it still would not display. I guess I'll just have to live with the post screen and no logo. no big deal.
Thats very weird how it wont work even that way :S have you tried using paint.net to convert the image to .gif?
download the AsusUpdt61002.zip from here and tick "bios downgradable" in options
It worked for me:yepp:
Vcore 1.275 in bios:
http://img384.imageshack.us/img384/8...shot004eq7.jpg
With P5Q Deluxe 1702m:clap:
I might be joining the 4GHz club soon :D pending tests but so far I'm at 3.8GHz with the new E7200 @ 1.45v (actual). I won't be pushing past 1.5v. Damn 45nm are too dainty for that :mad:
I wasnt sure if it had to be a specific file extension like .gif or not. I guess it's worth a shot at this point. I had forgotten to save my current settings to an oc profile so after the flash I manually set everything and it did run prime95 for 7 hours without any errors. I get wary about over flashing because previously oc settings would stop working that had worked prior. That was before I started using the best bios ever..... MBIOS :)
wow Ket.... great advise on paint.net. that is a great little app. i tweaked my bios image a bit and saved to .gif format. when i get home from work i will place in the bios file with mylogo and flash to see what happens.
Oh, the forum that I got banned from for mentioning that my Tpower I45 could use a new bios. Yeah, real rebels over there. I think it's owned by Biostar.
Also, I just wanted to mention that Im having good luck with 1702m. Its taking less voltage for the same clocks on 1406. Ill do a bit more testing when I get my other 2x2gb kit back from an rma.
Being a Stalker modder as well, taking on a mammoth project like Twilight K.E.T. If theres a free app worth having, chances are I know :D
I don't think Biostar own rebels haven, and I've never known Polygon or anyone else to ban someone from there. Maybe a mod was editing your post for something and hit the wrong button without realising it? :shrug:
Here is a set of "new" mBIOSes. They sacrafice a little in way of CPU compatibility (not as many microcodes) but memory compatibility theoretically is through the roof. V1 versions in this pack use a memory table from a early BIOS version of the Maximus 2 Formula, where the other vesrion in the pack uses the memory table from the latest M2F BIOS, 1802.
In summary;
- Replaced memory table with M2F mem table
- Replaced CPU table with M2F CPU table
You will probably notice various other changes when experimenting - this is all down to the above mentioned changes. Naturally, feedback is essential.
DL Link
Why you didnt used 17xx BIOS-es for these new modifications ?
For memory compatibility and OCing reasons.
