Load temp max 45C I using water cooling. I can not change on 9, because max the multiplier this CPU 8.5x i try to set GTL +40 ;)
NB temp on LC max 32C
SB -||- -||- 42c
my setting with a QX6800,OCZ DDR2 PC2-8500 / 1066MHz / Fatal1ty Edition, 2x8800gt sli. I know some of my volts were alittle high but she didnt heat up on my much more then 58c full load for 2 hours, the only thing that i had a problem with was NB/SB the contact between my heatsinks and the nb/sb was :banana::banana::banana::banana:y as seen on the last page (57).
FSB 345
multi x11
linked ram at 1080mhz
BIOS:1802
CPU:1.50
CPU PLL:1.62
RAM:2.0
CPU GTL:+40
NB GTL:+30
NB:1.46
SB:1.60
VTT:1.42
LOADLINE:OFF
EPP/SLIRAM : OFF
GPU EX:OFF
forgot to say my cpu was LC'ed
I want show my results in overclosking on S2F :)
CPU stress:
http://images29.fotosik.pl/306/272c183ac162f693m.jpg
Mem test:
http://images45.fotosik.pl/42/bb506141dc3532e5m.jpg
Settings in BIOS 1802
CPU 1.3.8750v
CPU PLL 1.60v
CPU VTT 1.36v
Memory 2.10v
NB 1.44v
SB 1.50v
1.2HT 1.20v
Bridge 1.20v
CPU GTL +40mV
NB GTL +40mV
DDRII Controller DDR2 REF +20mV
System is stable over 4h :)
best ram performance in striker 2 formula 475fsb or high
only 475 fsb 4.4.4.12 1t @950 not stable in 780i best everest record
475 fsb 4.4.4.12 2t 100% stable only good
http://www.virtual-hideout.net/revie...racer_Logo.gif
http://www.virtual-hideout.net/uploa...Build26_sm.jpg
http://shahrsakhtafzar.com/img/out.p..._cachemem6.png
http://shahrsakhtafzar.com/img/out.p...rosshair.2.png
http://shahrsakhtafzar.com/img/out.p...achemem.33.png
http://shahrsakhtafzar.com/img/out.p...cachemem22.png
http://shahrsakhtafzar.com/img/out.p..._cachemem2.png
http://shahrsakhtafzar.com/img/out.p...8_cachemem.png
http://shahrsakhtafzar.com/img/out.p...7_cachemem.png
4GHz is possible on S2F & Q9550:)
http://images32.fotosik.pl/425/002bf14c5efa734am.jpg
how can you do that. SB and NB dont have protection like the cpus chip u see to support the water cooling
if i knew better about nvidia chipset i would have gotten asus rampage formula :(
There's plenty of options for WC the NB and SB/NS200
Here's a link to one of them
EK Waterblocks
If you looked back through this thread, you would see plenty of pictures of WC NB/SB/NS200s
LOL water cool the sb and nb tis just a waist of cash slap a fan on the nb job done :)
OK i have this board it's an upgrade from my striker that i rma'd. i geuss i can call it an upgrade however my ram from my old striker will not even post.
Thats why i am here :) i have 4 gigs of crucial ballistix tracer(4x1).
My system is a e6600,8800 gts and the x-fi card.
I have tried to set the time in the bios on this cheap ram then reset and swap the sticks however thats a no go, my bios is fully updated.
once i install any of the sticks and try to boot i get codeini on the lcd poster, but the lights on the ram are flashing if that counts for anything ha
any help would be nice, and last but not least will the OCZ Flex EX 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1200 (PC2 9600) work on this board?
i am watercooled as well.
pretty sleek design, the cooler. But yeah one cooler alone for just nb is whooping expensive.
Anyway asus granted my wish :) they agreed to trade my asus striker II formula with asus rampage formula, the one with intel chipset instead. So im happy
Hi guys :)
You know maybe where there are points to the measurement voltage CPU on S2F? :confused: I want to check what be real vcote on CPU :)
I need help getting my q6600 stable at 3.0ghz. Anybody have any settings for me to try out? I have it somewhat stable but still get a bsod every once in a while. Here is what I changed to get it to boot into 3.0ghz. This is all I messed around with. I figured with it being such a mild overclock I didn't have to do too much but maybe I am missing something? Help me please. I also did my memory timings of course which is on the qvl sheet for compatible ram.
Vcore - 1.36250
CPU PLL Voltage - 1.52
CPU VTT Voltage - 1.32
BIOS 1901
Description Striker II Formula
Enhance compatibility with certain memory modules.
BIOS 1901
hi, I updated my s2f bios to 1802, and I want to have at least 3.5 to 3.6ghz in air cooling in my e8400, my question is do I need to disable my AIsuite so I can preform a stable OC for 3.5/3.6ghz ?
also could you give me a guid on what part should I setup in my bios setting in the overclock section?? I dont know which setting do I need for me to be able to OC my CPU??
