you may use -E version, but gigabit adapter will not work.Quote:
I tried the P4C800 E Deluxe bios in my P4C800 Deluxe but it didn't work, i can boot and get in the bios but that's the only thing i could do.Quote:
I read somewhere that it will work if you disable the onboard lan in the bios but i haven't tried that so i'm not sure.
I now use 1021D.004 which is very good but no multipliers,there is a 1021.005 for the P4C800 Deluxe too with mulipliers but they didn't work on my system(i can choose different multipliers but if i save it it's still at 13) but someone here had more more luck,he can choose different multipliers and save them.
i don't care about the LAN, i ll give a try to 1024.001 bios.
HI,Quote:
Originally Posted by leejsmith
can you give some info to mount the XP90 on CT-479
THX
Hi I have 730 on ASUS P4GPL-X
with CM Hyper6 +92mm
Stable 2800mhz 2830 benchable @ 1.65V
I have a question about Vdrop mod on that board,found no info ,about that nowhere:(
Here SuperPI now with crappy ram ,I go with better and post new scores.But please help me with Vdrop mod I'm unstable and it's very bad 0.05v under load
http://img351.imageshack.us/img351/7...42832ey.th.jpg
sse2
http://img351.imageshack.us/img351/5...22830ne.th.jpg
With TCCD I go down with more than 1 sec @ 1:1 2.5-3-3-x I do it soon :p:
Will these mods work on a Banias chip ?Quote:
Originally Posted by stryg
Ryan
Strange...strange...Quote:
Originally Posted by DStealth
1 sec. improvment just changing RAM-chips? Same timings? I find that more than suspect.. same goes for your 3dMark03-score in your "sig".. :nono:
@DStealth: How u managed to get 280 benchable? what hardware configuration, IDE HDD? PCI-E clock ?
His nature score is bugged.Quote:
Originally Posted by TL1000S
What you suspect can't get 1sec improvement from 226 3-3-3-6 to 283 2.5-3-3-6 ???:)))I find that these days when I get Tccd'sQuote:
@ociFalcon
pata disk :) PCI-e @129 when booting Windows :p:
@wwwww
Yes my nature is buggy:)3D03 - Old result ,but I like it :)Not many scores single XT over 18600p :)Registred ORB
And is there someone ,who can help with Vdrop mod?
I just checked your attached images.. no sign of FSB283 there.. so that's why I thought it was somewhat suspect.. :)Quote:
Well.. 226 3-3-36 to 283 2.5-3-3-6 would indicate "some" improvements.. yes.. :p:
Nice clockings.. and a good 730 you've got there.. I'm just envious I guess.. :(
I updated ram 3-4-4-8 287mhz ,still no TCCDs .I improve even more.this 730 is crazy proc :banana:
http://img125.imageshack.us/img125/2...42872fm.th.jpg
But still need Vdrop mod ,so badly :p:
DStealth,Thats one nice 730. My TCC5 at 6-3-3-2 is faster than any memory I have at any setting, Even my hynix el4200 that will run 280fsb at 7-4-4-2.5.
4x512 6-3-3-2 25.6s superpi http://community.webshots.com/photo/...87052438KZofSM
Even 5-2-2-2 pat turbo at 212 will not give me the same number.
You are joking right?.....2880MHz @ 25.6 sec!..... :)Quote:
Originally Posted by fordf250
http://www.thelab.gr/images/Hipro5/D...-Pi_25_png.png
2 x 256MB BH-6 full PAT...... :)
Please can you check with superpi mod 1.4, then we will have ms :DQuote:
Originally Posted by hipro5
Why do you up your AGP/PCI rates?Quote:
I have with 2896 24.843s but i would be able to get a sec off with higher fsb.
I have a strange problem, i can' get rams to work over 223fsb, tried all sorts of ram. I have tried with my adapter, proc and rams (some TCCD) on my friends board and they did 285 easyly, probaly more, but there was limit by cpu. Then I tried on my board (P4C800-E del, same bios settings) and they didn't even want to boot at 200, booting at 166, and then upping by clockgen, i got to 210.
I tried all sorts of things, tried 4 different boards, 2 P4C800-E del and 2 P4C800 del, different bioses, changed PSU, changed adapter, changed GPU.....
Does anybody have any idea what is the problem. The only thing different was the mobo, and I treid 4 different ones and couldn't get it working. The only other thing, he has Ati GPU, i haven't tried with that, cause kinda sux, no AGP/PCI lock at booting 200.
I got the BIOS reflashed with the 1024.001 BIOS. It still wants to give me ~1.1vCore. Can't change the settings in BIOS. I tried the easy vmod trick to give ~1.55 but that has failed as well.
http://www.xtremesystems.org/forums/...id=39622&stc=1
http://www.xtremesystems.org/forums/...id=39623&stc=1
What BIOS should I be using ? And could someone link me ?
Ryan
This was an old bench(7-2005)..........I have other ones BUT at about 3000MHz+ OR lower at 2500 - 2600 MHz with the modded Super-Pi 1.4....... :)Quote:
Originally Posted by JeanY
I ALWAYS bench at over 72MHz AGP........More stability and overclockability............. ;)Quote:
Originally Posted by wwwww
Going to try a 1022.003 BIOS flash. Hopefully I don't :banana::banana::banana::banana: anything up again :)
Ryan
f im looking at yout screeneshot i see that you have agp/pci not locked. Did you set to 72/36 in bios.?Quote:
it's locked, set at 80/40, i think hipro5 said once in an Abit MAX3 ocing guide that it helps, so if card can handle it i set it as high as possible, but over 40 SATA controler doens't want to work well, so it's set to 80/40
if i set it to any value, even 66/33 doesn't help.
Flashed to 1022.003 and still no vCore change avaliable and still defaulting to ~1.1v in BIOS.
I'm starting to wonder if my Banias chip or the CT479 is borked ?
Will try some other mods later on. But atm, it's running at 600Mhz {6*100} with no problems.
Ryan
does anyone know what rail the ct479 draws its power from ? +5v or +12v ?
