3049A330 *A2800 52X
3101A201 *A1564 53X
More multi then 4Es on UD7:(
3049A330 *A2800 52X
3101A201 *A1564 53X
How do you check max multi on these?
Does it matter where its assembled?
hmm let me know my vid, which one
http://img339.imageshack.us/img339/3669/defk.jpg
(EIST/speedstep/C3/C6 must be disabled). ----> Done
LLC Auto = 1212 v
LLC Enable = 1.236 v
4.2 GH on 1.224
http://img52.imageshack.us/img52/5306/69423361.jpg
Can you use realtemp 3.67 and check the VID? You can toggle the button on the top right in real temp. Realtemp usually reports accurate VID as long as the CPU is idle and no power saving is enabled. Plus the clocks are there too.
The screen shot has me confused. One has your cpu running at 3.5 ghz while coretemp reports 3.4 ghz. If you're at 3.5 ghz, then the VID will be higher than at 3.4 ghz.
With a CPU as good as yours, your VID should be no higher than 1.24v, and probably lower. However I've seen some cpu's with a low default VID at 3.4 ghz and a high VID at 5 ghz, and some with high VID (1.24+ is considered high) at 3.4 ghz but ironically, lower VID at 5 ghz (like 1.36v VID).
as u wish
http://img695.imageshack.us/img695/6624/idley.jpg
so vid 1.251---> BAD ones ?
Thanks, but can you do it at 3.4 ghz?
you're at 3.5 ghz. That's why your VID is so high.
Make sure you don't have turbo enabled in the BIOS, because it will boot you at +1 multiplier if all 4 cores are enabled.
Weekend fun:D...Binning 2600Ks
First...L047A901 *A3180 not even boot up @ 52X:(
Second cpu...
Finally:)
Another 3101A201 *A1983
http://img263.imageshack.us/img263/2...nshot023gs.jpg
Turbo OFF
http://img707.imageshack.us/img707/6654/offpu.jpg
4.8 GH @ 1.40v
http://img684.imageshack.us/img684/3170/83009425.jpg
Nice! 57x with 4C8T!Quote:
Second cpu...
Finally
Thanks:D
All those 2600Ks or....900s of INTC
This cpu gotta work early...
http://img577.imageshack.us/img577/1...enshot025w.jpg
5th cpu.. -
5ghz linx stable on 1.336V
more to come.
http://img193.imageshack.us/img193/9743/56001.jpg
What app to use to check for stock VID?
My Fatal1ty board gave the +1 working multiplier to the processor which was capable of 55 multi.
Maximus IV extreme + my 2600K = 5580max, 55 multi (SS)
Deluxe, Pro + my 2600K = 5560 max, 55 multi (SS)
MSI GD65 + my 2600K = ~~5300MHz max, 52 multi (SS)
Asrock Fatality + my 2600K= 5600MHz, 56 multi (Air cooled, Prolimatech Megahalems)
http://img824.imageshack.us/img824/2...litymax.th.jpg
Please don't look at the SPI run time etc. (I was just testing the 56 multi :))
Thanks OC:up:..I can build a small benching shack probly with all those 2600Ks:D
Interesting personal observation from all these 2600Ks are
Most of >54Xs s/n last two digits are in between 80~99
A few cpu came with a square heatsink imprint which indicated that Intel did randomly test its sb chip (and mostly is a dud)
finally dumo!
its not a 5770 but hey 5720 can do :p. same as mine.
how did your 5770 chip die?
Someone on OCN just got a X59 bootable chip (it can actaully prime at X54 with PLL overvolt DISABLED)...
