For you guys ;)
http://img5.abload.de/img/uv4sfk5x.jpg http://img5.abload.de/img/uv5suws8.jpg
No problem ;)
some old ones:
http://img5.abload.de/img/kable8sekin.jpg
http://img10.abload.de/img/kable7scdv3.jpg
I just tried my first Xigmatek fan with black sleeve and used black 3-pin MOLEX fan housings from MDPC-X. :up: I suppose result is good and shots below;
http://i47.tinypic.com/2iaftxw.jpg
Classic...
http://i46.tinypic.com/ae5cso.jpg
Its better than ever been!
nice sleeving job dude, even i dont like the xigmateks :p
http://www.abload.de/img/cimg13034uhv.jpg
it seems like when i put the heatshrink on the PSU end it slid a little bit and you can see the wire showing a little bit, how can i prevent this?
yiannit, you could do layers.. as in: First, heatshrink on both ends where you would want your heatshrink, so yea.. first two small heatshrink pieces, then you pull on whatever sleeving you are using. Then, put on the second layer of Heatshrink. That should do it, and dont pull on it while its still hot, let it settle, and cool down before you do the other end of heatshrink.
I've found that this works for me atleast. As long as i let one of my ends cool down before i do the other end, i get a pretty ok result.
thank you viking. about how long should i wait?
Just started on the SG-05 300w PSU:
http://i50.tinypic.com/2hpq4gh.jpg
PCI-e
http://i50.tinypic.com/2lnjse8.jpg
http://i46.tinypic.com/23roi2v.jpg
Molex
http://i49.tinypic.com/289viap.jpg
Looks really interesting :clap:
That's some nice sleeving
Cheers, this is the first full PSU I've done (just fans and other small bits before).
Waiting for some 4.8mm 2:1 heatshrink for the main 24 pin cable.
Got in from work to find this on my doorstep!!
Cant wait to start sleeving... back to work on the build... more pics soon
All thanks go to Nils, he's the man!
http://fc01.deviantart.net/fs71/i/20..._by_TBahre.jpg
Hi, I got it from Chilled PC.
My Corsair 750W HX Sleeve ;)
http://img94.imageshack.us/img94/6546/008nz.jpg
Very precise work and in my opionion just the right balance between color and black. I think I would do the same :yepp:
