Case: Danger Den Torture Rack Acrylic Case
CPU: Intel I7 930 (4.0GHz Daily profile and 4.2GHz Performance profile)
Operating System: Windows 7 Ultimate
Motherboard:ASUS P6X58D Premium
Memory: 6GB (3x 2GB) Patriot PC2000MHz PV236G2000LLKB
Video Card: ATI Radeon 5870 (900MHz GPU clock and 1300MHz Memory clock)
Hard Drive: Intel 160 Gigabyte X25M SSD & Western Digital Black Caviar 1 Terabyte
PSU: Kingwin Lazer 1000W (modular)
Case Fans: 3 x Aerocool Silver Lightning 120mm Silent White LED Fan
Memory Cooler: Kingston KHX-FAN HyperX Memory Cooling Fan
SATA Cables: 2 x SATA III UV Blue
Thermal Grease: Masscool Shin-Etsu Thermal Interface Material G751
Cable Management: UV Blue Sleeving/Heatshrink, White Sleeving/Heatshrink, and UV Blue spiral wrap
CPU Waterblock: Swiftech Apogee XT
GPU Waterblock: EK 5870 Acrylic/Nickel + Nickel Backplate
Reservoir: 9Primochill Typhoon III Rev A.
Radiators: 2 x Black Ice SR-1 240
Radiator Fans: 4 x 120mm Xigmatek "Crystal Series" 120x25mm White LED & 4 x Triebwerk TK-122 120mm
Shrouds: 2 x Tecnofront AirBox 240
Pump: Swiftech MCP655
Flow Meter: Koolance INS-FM17 Coolant Flow Meter & Adapter Board
Temperature Sensor: Bitspower Liquid Cooling Temp Probe Display
Tubing: Feser White/Blue UV 3/8"
Fittings: Mix of Bitspower and Feser fittings.
Anti Kink: Thermaltake iStripe
Biocide: PT Nuke & Silver Kill Coil
UV: 1 x 4" Logysis UV Cathodes + 3 x 8" Logysis UV Cathodes
Power Switch: 22mm White Illuminated Bulgin Style "Momentary" Vandal Switch
HDD LED: 3mm White LED
Fan/Light Power Management: Bitspower BlueX-Station
http://i44.tinypic.com/bji9n6.jpg
http://i39.tinypic.com/2mo8j1i.jpg
http://i44.tinypic.com/2mydk41.jpg
I'm in the process of a major aesthetic upgrade. I'll repost revised stats and pics after.
