Hi all guys,i have a questio.
who is the best bios for this mobo?
im using qx9770 and patriot extreme pc9600.
cant boot @460 fsb on stock bios.
regards
regards
i managed to lower my timings somewhat , to 5-5-5-15-42 still cant get 4-4-4 it just goes spastic if i do . no shortage of volts either. but i did get mhc and performance level to 8. is lower or higher better? not much info on these settings.
also i tried e-a-e-e-e- /e-a-a-e-e- but it wouldnt post . tried many times same result ,no post. c1 sometimes sticks on 25.
im not sure why my latency is so slow . ive tried differenct modules -double sided ballistix this is all highend gear im using . psu cpu etc it should be giving me alot more. i cant even get 4-4-4-12 with 2gb ram. im starting to think its the board. every change i make makes it c1 . does this board ever not c1 lol its all it does , its like its being designed to c1 on a pro level. its so annoying.tested my ram on another system and it runs great but on this board it just gives u c1.
I managed to fix stable my UT X48 with a Q9450 cpu and 4x2gb g.skill 8500 at 3400mhz (8x425), with the following settings:
CPU 1.35000v
DRAM 2.03v
SB 1.510v
NB 1.392v
VTT 1.250v
GTL 115-107-100
considered this is my first attempt with DFI I cannot complain that much if somebody has any suggestion to fine tune even better my settings feel free to do so, my end goal is to reach stable 3600mhz (8x450) for 24/7 usage.
Just purchased 4x1GB Cellshock PC-2 8500 D9GMH 64Mx8 chips from MemoryC. I hope these clock better than my 4x1GB PC-2 8500 D9GKX Mushkins did on this board. I had a hard time getting 5-5-15-42 @ 1067MHz PL7 stable on this board when I was running 5-4-4-12-32 @ 1067MHz PL7 on my Maximus/Rampage conversion. This has got to me my last DDR2 purchase or I am never going to be able to move up to DDR3.
need help guys.....:)
just bought E8400 but i dunno why, nothing can detect it, whats going on here...? heres the ss of real temp, everest, core temp, and cpuz.....:confused:
http://i10.photobucket.com/albums/a1...untitled-2.jpg
anyone any idea whats going on ?
thx
anubis_is_evil, is multicore processing enabled or disabled in bios?
Hi guys can any1 tell me if this looks ok for my new oc.
http://i249.photobucket.com/albums/gg211/wils07/RAM.jpg
You were able to hit 4-4-4-12 @ 1000MHz w/ your Mushkins on this board? If so, what NB voltage did you need? I would have been happy with those timmings @ 1000MHz but for some reason I couldn't get CAS4 to work. Did you have to lax PL in order to get such tight timmings?
I don't know, to me your Rd speed seems rather low and your latency high. Couldn't you choose a different divider to increase throughput and maybe go 5-4-4-12 w/ your timmings? I was in the mid 9000's with a much lower latency running 1067 @ 5-4-4-12 on my old Formula/Rampage board.
Hi to All,
One simple question: is the bios from 20-03-2008 the last one for the LT board?
In DFI website, it's the last one available, but in the beta section this board is not even listed there...
This seems strange, because I've read here some time ago about a new bios comming out soon...but that "soon" seems to be 1 or 2 months ago...
HastaSSSS :)
That's a 2 gig kit though, right? So I'd probably need around 1.55V for a 4 gig kit then, about the same as I needed with my old board. Have you tried to hit CAS4 w/ 4 gigs? I'm starting to think its nearly impossible to hit CAS4 w/ 4 gigs.
I spoke with Clunk the other day and he had said that the new BIOS should be out any day now, until then 0320 is the current BIOS.
Thankx for the info m8 :up:
