It should be a little better for RD790. Check here, this is what you should be getting at stock (end): http://www.xtremesystems.org/forums/...postcount=1215
On X64, it should be more because X64 has access to higher memory bandwidth. Recheck that CPUZ 1.44.1 is reading dual channel. Post your Memset latencies next time you run it too. What WinRAR shows is essentially your memory bandwidth.
Copy all the register EDX and EAX but for the 22. Change that to 20 and writeMSR for each core. Check multi-threaded and make sure something else is not heavily taking up your memory.Quote:
i'll look into it, not really looking into formatting again, will if it needs it. will attempt to build a new iso with vlite, see if i can get a promise raid driver intagrated right this time. as soon as i decide on the format, i'll switch back to trying P0H.
UPDATE :
i think i may got an issue, my 0xc0011023 doesn't match
1.13B doesn't have any patch. Post me a screenshot of AMD Power Monitor, CPU-Z CPU, Mainboard, Memory, SPD tabs and Memset altogether please when you run this bench (make sure either the pic is resized to less than 1024x768 or thumbnailed). Your RAM perf. there is like Athlon 64 X2 5000+ BE rather than how Phenom should be.Quote:
UPDATE #2 : flashed 113, did BOTH register changes and got :
http://www.imagehosting.com/out.php/i1611527_bnc.jpg
When you choose disabled, it's only disabled on the 1st core and not on the other 3 = bad perf.
Always does, an AOD bug. Check in latest CPU-Z, if it shows dual channel, it'll be dual channel. ;)
Looks like you ran it single threaded and not started by ticking the multi-threaded box (?).Quote:
And I was to understand BIOS 1.1 would not have the TLB-fix, howcome it gets the same performance as the newer ones?
