It may be you have "microcode updation" disabled in BIOS. Try enabling it and see what you get.Quote:
iamjcl is right you have microcode update under cpu configuration in bios disabled deffo it needs to be enabled
K I will enable it. Thanks.
Does it do anything timportant other than prevent that error anyway?
not really mate it just updates the cpu info
Remember, what I said is just a theory.Quote:
Originally Posted by Thickbrit
I don't know what's really going on. But why would my computer not post at 400x9 @ 1.51v, but posts (and runs 100% stable) at 1.55v?
(BTW 3.6 ghz is dual prime stable at 1.5125v).
anyone have a 1305 bios link ?
All of them are hereQuote:
Originally Posted by graham_h
http://wiki.p5wdh.de/doku.php?id=downloads:bios
Guys, with the 1407 BIOS, my USB devices have just gone to hell. Mouse lags terribly in FPS games and wireless performance is terrible (in games). Has anybody else experienced this?
thanks Simon
Is 1305 still the best in most peoples opinion ?
I have tried most and am at 1405 atm - i have not seen much difference except the ability to change the CPU multiQuote:
I couldn't even boot with lower multi ! tried 1402/1403Quote:
Originally Posted by simonmaltby
lol
Hi I'm having an annoying problem with my setup - would appreciate any ideas..
I have the following spec:
E6600, Hiper Modular Type-R 580W PSU, 2x1GB XMS PC-8500 Ram, 2X 74GB Raptors, Gigabyte 6800 ultra, inside a watercooled Coolermaster Stacker Case - running on an ASUS P5W of course!
The problem I have is this: if I try to turn on the PC it stalls. There's a very short flash of the neon light and fans start to spin but then they stop. If I hold the On button for 5 seconds, then depress, then press again the system comes to life. Boots up normally, fully stable at FSB 360 (no other overclock).
It stalls on startup every time, and I have to go thru the same routine.... arghhh!! very annoying. I tried replugging everything - no difference. Tried several bios versions, currently 1405. I suspect its a PSU issue - but have no proof (only have one PSU) - - Any ideas??
i have a problem with memory timmings,
my e6600 is running at 3.3ghz [1.4v] 9x366
but i cant set the timmings my self, i have to use SPD for the board to boot
any way i can fix this cus the SPD timmings suck @ 18 6 6 5
when it should be 12 4 4 4
Hi I just built a system using the E6600 and i have it currently at 9x400 or 3.6 ghz on a Thermaltake Ultra-120. The problem im inquiring about is that I have to hit my MCH volts to 1.75 to get it stable at 3.6 ghz.
The ram im using is the 2GB corsair XMS2 PC2-6400C4.
I really cant figure out why i have to volt the MCH so high.
Guys does anyone know what's the differences for rev1.03 boards?
My USB issues have been solved. I reverted back to BIOS 1305.
Same prob right here. It's happening ever since I installed the wireless remote. Do you have the wireless remote installed? I dont think its it, but it could be somehow maybe.Quote:
Originally Posted by bazaarboy
Mine however, Starts up whenever the PSU switch is turned from off to on. Then it stalls (yet still beeps) and I am required to hold button for 5 secs, and then turn it back on a bam its fine. Sometimes it gives me the "overclock failed" when this happens too. Even though im perfectly stable.
Very similar: after stalling I can fix it in three ways, hold on button for 5 sec then press again, switch PSU on/off, or reset bios. For convenience I just do the first. I also get the "overclock failed" screen (once every ~20 bootups). I noticed that you have a different PSU... I know that if the load is too small for a PSU (eg <15% of its rated output) it can behave like this - - but my hardware exceeds that threshold significantly. btw I havent used the wireless remote.Quote:
Its really strange. It has never happened to me in the 2 months I've owned the motherboard, only started a week and a half ago, so I'm not 100% sure it's the PSU. I'm going to update bios and see if that helps. Currently I've been using 1305.
Other than temps seen differently by different progs, what am I looking at here? It's up and running and default and Auto settings, but where do I start to get the system running at spec ?
http://mysite.verizon.net/fibre/PC/screen1.JPG
Any input/help wanted, just prefer cpu and ram at least spec.
P5WDH deluxe (1305)
Cpu E6400 at 2.13Ghz (No Overclocking)
Bios Vcore: Auto (1.35v max written on box)
2 x 1Gb DDR2 at 800 OCZ Platinum 4-5-4-15 (OCZ2P8002GK)
Bios Vdimm: 2.1v (spec voltage)
Timings in bios are 4-4-5-15 (as it should be cause of reversed order of TRCD-TRP)
Hyper Path 3 is Disabled
Throttling is Auto
Everything else on BIOS on Auto
Sapphire 1950xtx
WD Raptor 150gb
SB X-Fi Extreme Music
600w Tagan Easycon XL
Stable on Memtest v1.65 for 19 hours (37 passes)
Stable on 2 threads of Super Pi mod1.5 XS
Stable on OCCT v1.0 for about an hour
Stable on Everest stress test for about 2 hours
Unstable after 1-2 hours (50 mins last try) on ORTHOS blend test.
"FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file."
The CPU temperature after the test failed was at 37 C with PC Probe and at 51C - 47C with CoreTemp.
Im using stock CPU fun, 1x12 front and 1x12 rear case funs
Assuming those Temperatures are normal, whats the next step in improving the stability of my system?
thanks in advance
PS. Im not intended to Overclock my system for the time being.
I have a few question about this board with an E6600 and some GeIl pc6400 CAS 4. BIOS 1401.
Got it running at 350*9 memory 1:1 all stock voltages, right out of the box. This is 1,5 hours prime stable. 370fsb wouldt boot, what would be the right order in raising voltage for stability? One of the three motherboard voltages or Vcore?
Also, Hyperpath3 is disabled, so is the Thermal stuff. Didnt set timings for the memory yet, so it was set by SPD. Is there anything of this that I should change or other general BIOS settings?
Thanks in advance, Im really new to this platform. :)
anyone?Quote:
Originally Posted by lockeh
To some one with some technical expertise.
I have a P5WDH Deluxe with a smith field chip my Ram is 1 stick 1 Gig OCZ DDR 2 800 Gold 5+5+5+12. I can give more specs on my perifs ect. if needed looking for a guide to setting up the bios for all possibilities of over clocking. I can over clock right know 30% however Im looking for more. Ill Give my specs in another thred or email them to someone who can help.
My problem is Boot up time is slower than my 2002 Asus P4-TE Rambus board with 768mg of ram and a 1.8 G P4 Processor North wood.
Joeys System Semi Budget Build:
Mother board:
Model Brand ASUS Model P5W DH DELUXE/WIFI-AP <GREEN> Supported CPU CPU Socket Type Socket T (LGA 775) CPU Type Intel Core 2 Extreme/Core 2 Duo/Pentium EE/Pentium FSB 1066/800MHz Supported CPU Technologies Hyper-Threading Technology Chipsets North Bridge Intel 975X South Bridge Intel ICH7R Memory Number of DDR2 Slots 4x 240pin DDR2 DDR2 Standard DDR2 800 Maximum Memory Supported 8GB Dual Channel Supported Yes Expansion Slots AGP Slots None PCI Express x16 2 PCI Express x1 2 PCI Slots 3 Storage Devices PATA 2 x ATA100 up to 4 Devices SATA 3Gb/s 6 x Internal Serial ATA 3.0Gb/s ports
1 x External Serial ATA 3.0Gb/s port SATA RAID RAID 0/1/5/10 Matrix RAID Additional RAID Controller Jmicron JMB363
Silicon Image 4723 Onboard Video Onboard Video No Onboard Audio Audio Chipset Realtek ALC882M Audio Channels 8 Channels Onboard LAN LAN Chipset Marvell 88E8053 Second LAN Chipset Marvell 88E8053 Max LAN Speed Dual 10/100/1000Mbps Rear Panel Ports PS/2 2 COM 1 USB 4x USB 2.0 IEEE 1394 1x 1394a S/PDIF Out 1x Optical and 1x Coaxial Audio Ports 6 Ports Onboard USB Onboard USB 4x USB 2.0 Onboard 1394 Onboard 1394 1x 1394a Physical Spec Form Factor ATX Dimensions 12.0" x 9.6" Features Power Pin 24 Pin Features ASUS Digital Home Features:
ASUS EZ-Backup:
2 x Serial ATA 3.0Gb/s support hardware RAID 0 or RAID 1 mode
Plug and play: Default setting in RAID 1 mode, no driver, no BIOS configuration required
ASUS WiFi-AP Solo :
54 Mbps IEEE 802.11g and backwards compatible with 11 Mbps IEEE 802.11b
Software Access point mode
Station mode : Infrastruceure mode and Ad-Hoc mode
1 x WiFi-AP Solo antenna jack
Digital Home Accessories:
1 x Asus DH Remote
1 x ASUS DH Remote Receiver
1 x ASUS MP3-In module
1 x ASUS WiFi-AP Solo Antenna
2 x ASUS EZ-Backup SATA cables
Asus DH Remote:
Power, Quick Power, Noise Off, EZ WiFi, Full Screen, AP Launch, Media Control Zone
ASUS MP3-In
Processor:
Model Brand Intel Series Pentium D Model BX80551PE2666FN CPU Socket Type CPU Socket Type LGA 775 Tech Spec Core Smithfield Multi-Core Dual-Core Name Pentium D 805 Operating Frequency 2.66GHz FSB 533MHz L1 Cache 24KB+32KB L2 Cache 2 x 1MB Process Type 90 nm Vista Ready Yes 64 bit Support Yes Hyper-Threading Support No Virtualization Technology Support No Multimedia Instruction MMX, SSE, SSE2, SSE3 Voltage 1.25-1.4V Cooling Device Heatsink and Fan included
Memory:
Model Brand OCZ Series Gold Model OCZ2G8001G Type 240-Pin DDR2 SDRAM Tech Spec Capacity 1GB Speed DDR2 800 (PC2 6400) Cas Latency 5 Timing 5-5-5-12 Voltage 2.0V ECC No Buffered/Registered Unbuffered Heat Spreader Yes Features Gold Layered XTC Heatspreader
Video Card:
Model Brand GECUBE Model GC-HM1600PG2-D3 (RoHS) Interface Interface PCI Express x16 Chipset Chipset Manufacturer ATI GPU Radeon X1600PRO Core clock 500MHz PixelPipelines 12 Memory Memory Size 256MB HyperMemory to 512MB Memory Interface 128-bit Memory Type GDDR2 3D API DirectX DirectX 9 OpenGL OpenGL 2.0 Ports DVI 2 TV-Out HDTV/S-Video Out VIVO No General Vista Ready Yes Tuner None RAMDAC 400 MHz Cooler With Fan System Requirements Intel Pentium 4 or AMD Athlon CPU
1GB or more for best performance when HyperMemory to 512MB
A motherboard with one PCI Express x16 slot
Specialized PCI Express 500 watt or greater power supply recommended.
Windows XP with Service Pack 2 (SP2)
High-resolution MultiSync or multi-frequency monitors or any other type or VGA monitor.
Digital flat-panel (DFP) displays or digital CRT display.
Connecting Device for CrossFire--Only one display while enable Cross-Fire capability. Features Features Dual DVI (double Dual-link) + HDTV + D-sub support
ATIs Avivo? technology connects to home entertainment devices and creates true-to-life image reproduction, and the smoothest video playback ever offered by ATI. Get high image fidelity with CRT and LCD displays, TVs, rear projection and plasma TVs, and projectors.
New ultra-threaded core 3D architecture with ATIs revolutionary Avivo video and display technology to drive performance to new heights with incredible speed and intense 3D graphics.
The Radeon X1600 is CrossFire Ready to deliver multi-GPU gaming performance.
Shader Model 3.0
New High Dynamic Range features visual effects, and enhances realism with adaptive anti-aliasing and lightening fast performance.
Accelerated MPEG-2, MPEG-4, DivX,WMV9, VC-1, and H.264 decoding (including DVD/HD-DVD/Blu-ray playback), encoding & transcoding.
CATALYST: Full Windows Vista LDDM support including Aero Glass visuals Packaging Package Contents HDTV Cable
1-2 S-Video Cable
ATI Driver
DVI to VGA Dongle
Manual
Power Supply:
Model Brand OCZ Model OCZ600GXSSLI Series GameXStream SPEC Type ATX12V Maximum Power 600W Fans 120mm fan x 1 PFC Active Main Connector 20+4-Pin Dual +12V Yes SLI Support Yes Modular Cabling Support No Efficiency 80% @ 115V (Typical load)
83% @ 230V (Typical load) Over Voltage Protection YES Input Voltage 100 - 240 V Input Frequency Range 50/60 Hz Input Current 10A @ 115V, 5A @ 230V Output +3.3@36A,+5V@30A,+12V1@18A,+12V2@18A,+12V3@18A,+12 V4@18A,-12V@0.5A,+5VSB@3.0A MTBF >100,000 Hours Approvals CB/CE/CSA/UL/FCC Features Connectors 1 x 20+4-pin ATX
1 x 4-pin/8-pin CPU
2 x PCI-Express
6 x 4-pin peripheral
2 x 4-pin floppy
6 x SATA Features Designed specifically for the demanding computing environments of PC Enthusiasts, Power Users, and Gamers.
The GameXStream features high-quality components to ensure your PCs vital hardware is supplied with clean, stable and reliable power without compromising effectiveness.
Remains virtually silent and supremely cool even at peak loads.
Drives:
Sony DVD-RAM Burner:
Model Brand SONY Type DVD Burner Model DRU820A Performance DVD-ROM Access Time 130ms CD-ROM Access Time 135ms Cache 2M WRITE Speed DVD+R 16X DVD+RW 8X DVD-R 16X DVD-RW 6X CD-R 48X CD-RW 32X DVD+R DL 8X DVD-R DL 4X DVD-RAM 5X READ Speed DVD-ROM 16X CD-ROM 48X Physical Spec Form Factor 5" Panel Color Beige Configuration Load Type Tray Interface E-IDE/ATAPI Software Operating Systems Supported Windows 2000 or Windows XP Home or Professional Operating Systems Software Contents SONY Software Disc Features System Requirements Pentium III 800 MHz or faster (or equivalent) CPU minimum. Pentium IV 1.6GHz or faster (or equivalent) CPU is recommended for real time video authoring/editing
128 MB of RAM (256 MB or more for Windows XP Systems)
10GB of hard disk space Features Works With 4.7GB DVD+R/+RW and 8.5GB Double/Dual Layer Discs
Record Up To 4 Hours Of Video on Double/Dual Layer Discs
Easy To Install EIDE/ATAPI Interface Drive For Windows 2000/XP
Preserve Home Movies On DVD
Back Up Your Computer, Make Music Discs, and More
Ultra Fast CD Burning Too Packaging Package Contents Internal DRU-820A Double/Dual Layer DVD drive
Black front panel replacement kit
ATAPI cable and mounting hardware
Users Manual
Software CD-ROM
Sony DVD Drive:
Model Brand SONY Type DVD-ROM Drive Model DDU1615 Performance DVD-ROM Access Time 80-220ms CD-ROM Access Time 165ms Cache 512K READ Speed DVD-ROM 16X CD-ROM 48X Physical Spec Form Factor 5" Panel Color Beige Configuration Load Type Tray Interface IDE Features Features Internal Half Heigh Drive, Short Form Factor
Hard Drive:
Model Brand Western Digital Series Caviar SE Model WD1600JB Performance Interface IDE Ultra ATA100 Capacity 160GB RPM 7200 RPM Cache 8MB Average Seek Time 8.9ms Average Write Time 10.9ms Average Latency 4.2ms Physical Spec Form Factor 3.5" Features Features FAST
COOL
Cool operation results in the highest reliability, even in intensely hot environments such as digital video recorders. That's why these, the coolest on the market, are the drives of choice for the world's leading consumer electronics and PC manufacturers.
QUIET
The technology that Tom's Hardware Guide called "very fast and nearly silent" is used throughout this family of drives. Our WhisperDrive technology minimizes noise to levels near the threshold of human hearing.
To cut seek noise, SoftSeek technology streamlines read/write seeking algorithms, resulting in more efficient operation.
Floppy:
Model Brand SONY Model MPF920 Beige Spec Panel Color Beige Capacity 1.44MB Average Access Time 94ms Track to Track Access Time 3ms Rotational Speed 300 rpm Interface Internal Media Type 3.5" Micro Floppy Disks Operating Systems Supported Windows 98SE/ ME/ 2000/ XP Features High Quality and Reliability Physical Spec Form Factor 3.5"
USB Devices:
Printer:
Model Brand Brother Model MFC-7420 Recommended Use Personal Printer SPEC Print Technology Laser Output Type Monochrome Printer Black Print Speed 20ppm Max. Print Speed 11~20ppm Black Print Quality HQ1200 (Up to 2400 x 600) Max. Duty Cycle 10,000 printed pages Fax SPEC Color Fax No Fax Transmission Speed (seconds per page) Approx. 6 seconds per page Fax Memory Up to 500 page fax memory Copier SPEC Copy speed, Black 20cpm Black Max. Copy Speed 11~20cpm Copy Quality, Black 600 dpi Class Scanner SPEC Scan Resolution, Enhanced Up to 9600 dpi Scan Resolution, Optical 600x2400 dpi Scan Technology 24-bit Paper Handling / Media Input Capacity, std. 250-Sheet Input Capacity Output Capacity, std. 100 sheets Media sizes supported Minimum Input for ADF (Width/Height):5.8"/5.8"
Maximum Paper Width/Length (Paper Tray):8.5"/14.0" Hardware SPEC Noise Level (Approx.) Machine Noise (Standby/Operating): 30 dBA / 53 dBA Memory, std. 16MB Modem Speed 14.4K bps Fax Modem Cartridges Compatible DR350/ TN350 Power Requirements AC 120V 50/60Hz Power Consumption Power Consumption - Sleep/Standby/Peak: 10W/75W/1032W Ports USB Ports Yes LPT Ports Yes Compatibility Emulations GDI Windows Compatible 98/98SE, Me, NTฎ 4.0, 2000, XP Macintosh Compatible OS 9.1-9.2, OS X 10.2.4
or greater Physical SPEC Dimensions 17.0" x 15.6" x 11.6" Weight 20.8 lbs. Warranty Manufacturer Warranty 1 Year Limited
Voice Recorder:
Olympus VN-960 Digital Voice Recorder
Built-in microphone and earphone jack
128MB flash memory
Up to 16 hours recording time in LP mode; up to 5 hours in higher quality settings
Large, backlit LCD screen
Files are saved in ADPCM (WAV) file format
3 quality modes
Program the VN-960PC to begin and end recording audio at specific times
Timer recording lets you set the start and end times for a recording
Listen to audio at speeds 20% slower or 30% faster than real time with Slow and Fast Playback functions
Variable Control Voice Actuator (VVCA) setting saves time and battery life by recording only when sound is sensed
4 folders are capable of storing up to 100 files each
Alarm playback can be set to notify you of important meetings, dates, times, and more
LCD display shows date, time, battery life and more
Includes Creative Labs Sound Blaster 16 or 100% compatible card
Metal clip for hands-free recording
Two AAA batteries provide up to 25 hours of continuous operation
Hubs:
Cyber Power USB 2.0 Hub:
The latest product innovation from CyberPower Systems provides you with the ability to easily connect and operate up to four USB devices simultaneously. The new USB 2.0 4-port powered Hub features a compact space saving design freeing up valuable space on your desktop; plus, you will have quick access to your USB devices. Monitoring your device activity has never been easier with LEDs that indicate power status as well as which ports are active. Dual speed compatibility means this Hub works seamlessly with all your USB 1.1 and USB 2.0 devices.
Features
USB 2.0 data transfer up to 480 Mbps
Easy Plug and Play installation
Works with all USB 2.0 and USB 1.1 Devices
Ultra compact space saving design
Requirements
Windows 98SE, ME, 2000 or XP
Mac OS 8.6 and above
Contents
USB 2.0 4 port hub
AC power adapter
18" USB 2.0 cable
User manual
Connectivity
Form Factor Hub/Switch
Additional Information
Self Powered ? No
Manufacturer Information
Parts Warranty Lifetime
Labor Warranty Lifetime
Creative Labs Muvo:
Model Brand Creative Model 73PD051100006 Features Features Built-in FM radio and recorder
Integrated voice recorder with built-in microphone
Skip free audio, perfect for the active lifestyle
Drag and drop for songs and data files between your computer and the player
5-band custom equalizer and 4 presets (Jazz, Rock, Pop and Classical)
Stores data files such as photos and presentations Video Spec Display Displays ID3 tags for song title
Reversible LCD for left or right handed operation Audio Spec SNR >90dB Frequency Range 20Hz to 20kHz File Format MP3/WMA Audio Recording Format IMA ADPCM, Mono General Spec Color Silver Capacity 128MB Interface USB 2.0 Ports 3.5mm stereo mini jack Battery 1 x AAA Alkaline battery Playing Time Up to 15 hours of MP3 Dimensions 1.4" x 2.9" x 0.6" Weight 1.1 oz (without battery)
TI-83 Calculator Graph Link Cable:
Texas Instruments Graphing Calculator Connectivity Kit
The TI Connectivity Kit includes a TI-GRAPH LINK USB cable for Windows/Mac and TI Connect software. Use this powerful combination to add really cool Apps to your TI graphing handheld, such as Organizer, StudyCards, Periodic Table, Puzzle Pack, GeoMaster, and more.
"What else can you do with a TI Connectivity Kit", you ask? Why, you can use it to create captivating lab reports and homework assignments, capture screen shots from your TI handheld, create and transfer StudyCards stacks, or download data from the internet to your TI graphing handheld. Even transferring data between Microsoft Excel and your TI-83 plus, is a snap when you use the CellSheet App. And it's easy to download software updates and the latest Apps from education.ti.com with your TI Connectivity Kit.
UPS Battery Back Up:
Model Brand APC Model BE350R Iuput Input Voltage Range 88 - 139 V Input Frequency 50/60 Hz Output VA Rating 350 VA Watts 200 W Output Voltage 120V Outlets 8 Battery Battery Run Time 9.7 minutes (100 Watts) Battery Recharge Time 16 hour(s) Spec Interface Port USB Management Software YES Approvals cUL, FCC, NOM, UL Surge Protection Data Line Protection RJ-11 Modem/Fax/DSL protection Surge Energy Rating 365 joules Physical Spec Weight 22.05 lbs. Dimensions 15.8 x 10.2 x 9.5 inches Features Features Battery replacement without tools
Disconnected battery notification
Intelligent battery management
LED status indicators
USB connectivity
Key Board & Mouse:
Model Brand Logitech Name Cordless Internet Pro Desktop Model 967461-0403 Keyboard Connection Type Keyboard Interface USB Keyboard SPEC Design Style Slim Palm Rest Detachable Normal Keys 104 Function Keys 8 Keyboard Color Black Wireless Type RF Wireless Power Supply 2x AA Batteries Mouse Included Mouse Included Yes Mouse Connection Type Mouse Interface USB Mouse SPEC Hand Orientation Both Hands Tracking Method Optical Buttons 3 Scrolling Capability 1x Wheel Mouse Color Black Features Features The slim Internet Pro Keyboard provides media and Internet control with
Must be purchased with Hardware
one-touch access to frequent tasks such as email, visiting home pages, and
music.
Monitors:
Samsung Sync master:
Model 955DF-T/T (Two-Tone)
________________________________________
CRT Size 19" Viewable 18" Type DynaFlatTM Dot Pitch (mm) 0.20 (H) Surface Treatment Smart IIITM Deflection 90 degrees
FREQUENCY Horizontal (kHz) 30-85 Vertical (Hz) 50-160
BANDWIDTH Maximum (MHz) 185
RESOLUTION Maximum 1600x1200 / 68 Hz Recommended 1280x1024 / 75 Hz
SIGNAL INPUT Connector 15-pin d-Sub Sync Signal Separate H/V
PLUG AND PLAY DDC DDC 2B/2Bi
POWER Consumption 100 Watts Voltage AC90~264VAC, 50/60Hz Universal Power
MICRO-
PROCESSOR Factory Saving 8 modes User Saving 8 modes
CONTROLS Brightness, Contrast, Position, Size, Zoom, Parallelogram, Rotation, Pincushion, Trapezoid, Pinbalance, Linearity, Moire, Color Temperature, Degauss, Recall, Video Input level, Display Timing, Menu Color, Menu Duration, Halftone, Languages, OSD Lock/Unlock, Highlight Zone
REGULATIONS Safety UL, CE, CSA, TUV, CB ,NEMKO, Korea EK, CCIB, PSB, NOM, GOST, CDRH, IRAM EMI/Emissions FCC, CE, VCCI, C-tick, BSMI, Mic, ICES, TUV GS Emission Standard TCO '95
POWER
MANAGEMENT Regulations (US) Energy Star, Energy 2000
CABINET COLOR Front/Back Silver/Black
DIMENSIONS Physical (WxHxD) 17.3x18.1x18.1 (inches) Packaging (WxHxD) 24.6x21.3x22.0 (inches)
WEIGHT Net(Physical) 46.2lbs Gross (packaging) 51.7lbs
FEATURES Highlight ZoneTM, Natural ColorTM Software
INCLUDED 15-pin d-Sub
OPTIONAL USB Hub
WARRANTY Parts/Labor/CRT 3/3/3
COMPATIBILITY Operating Systems Windows
Macintosh
Sun Microsystems
UNIX
Gateway Flat Panel with DVI & AVI:
Specifications
Agency
CertificationsEnergy Star�, UL, cUL, FCC Class B,
NOM, CE, TUV/GS, VCCIBrightness250 cd/m2Colors16.2 millionContrast Ratio450:1Dimensions
(W x H x D)13.71" x 13.60" x 5.67" with stand
13.71" x 11.32" x 1.97" without standDisplay StandIncluded (Tilt backward/forward adjustments)Electrical
RequirementsNormal operation: 40 Watts
Off (power-save): 2 Watts
100-240 VAC, 50/60 HzLimited
Warranty1 year parts and laborMountCompatible with VESA (4x100mm) compliant mounting solutionsPanel TypeLCD Active Matrix TFTPixel Pitch0.297mmPortsAC Power Input, Kensington Security Lock SlotResolution1024 x 768 (native and maximum)Response Time16msScreen TreatmentAntiglareSignal InputsAnalog (VGA) � 15-pin mini d-sub VGA
Digital (DVI-D) 24-pin DVD-DTiltYesUser ControlsPower On/Off Button, On Screen Display Menu Control ButtonsViewable Area15 inches (diagonal)Viewing Angles130� Left/Right; 100� Up/DownWeight5.74 lbs. with stand
7.94 lbs. packaged
Speakers:
Description & Specifications
The subwoofer is not the same one as in the 221's. Upgraded not only to five satellites from two, this system has a resemblance to the 221 model in style. The boom box gets more power and a 5.25 inch driver, up from 4 inches.
As these satellites are in sealed boxes, I was unable to verify that the 3 inch mid/high driver in the very same one from the ACS-48 and 621/641 models; however, after listening to the 251's for over 40 hours, I can conclude that they do have many of the same characteristics.
Power Output: 45 Watts RMS @ 1% THD, 60 Watts RMS @ 10% THD, 90 Watts Total Peak Power
Frequency Response: 35Hz-18KHz
Drivers: 5.25" Woofer, 3" Satellites
Shielded Satellites
Input Impedance: 10Kohm
S/N : >70dB
