Sorry if you've already answered this but why do you cover up your a64 tweaker settings? I'm sure other members with the same ram would like to give them a try.Quote:
i have found 2 bugs with this memory.... i post it next time
here is a better and bigger 2 gb oc list :
http://www.forumdeluxx.de/forum/showthread.php?t=177162
honestly, what's the point of posting it then if you won't reveal how you got there? ;)Quote:
i have on my hands some kingston 2x1gb kit KHX3200AK2 that seeing the xtremesystems ram list this ram mount winbond ch-5. this is true also for 2gb kit?
Can I post a screen with any CPU/FSB Frecuency Ratio?
Is this the good stuff thats -5b D hitting 300 plus?
I want 1:1 badly
http://www.tankguys.biz/ballistix-pc4000-p-823.html
Impossible, i bet it has some old Hynix on em.Quote:
Originally Posted by Ludus
Hey,
I would say that reaching 300+ is a rare feat even for ballistix, also I have had 2 sets of 2x1 die on me after a while.
First set reached round 260 the other set reached 280.
Due to the stability issues with Ballistix (heard that they stopped selling them) I cant really recommend them unless you are willing to RMA them if they are bad (also make sure that the warranty period covers atleast 3 months)
/Q
wow, alot of new entries since i posted last, lol.
Hey bro, mind sharing with us batch #? Want to see how far i'm off ;) i'm currently in possession of 4gigs of ballistix.Quote:
Originally Posted by TheMeatFrog
Newer ones pushing 250 2.5-2-2-51T strong.
i have 2x1GB kingston value ram with micron -B5 D chips.
run stable at 230 3-3-3-8 1T. in memtest i can run them 240 at same timings but loading win fails. is the pcb bad or what? max voltage is 2.8 over that i get blue screen
Here is my result with corsair VS 2*1024MB. They are using samsung UCCC, and it is pretty new sticks.
http://img485.imageshack.us/my.php?i...shot0037fa.jpg
Validation:
http://valid.x86-secret.com/show_oc?id=75471
http://img485.imageshack.us/img485/9...shot0021ny.jpg
Validation:
wish i could have done a touch better, but oh well. it gets me up there. maybe i'll drop the cpu multi and push it with a bit less of a load :p:
my board reports a touch high. haven't manually measured vdimm yet, but this was with 2.8v set in the bios. ;)
ozzimark | 2x1GB TeamGroup Xtreem Cronus - Micron -5B F | 3-3-3-1 1T @ 297MHz | 2.8v | Link! - SPi 32M Stable: Yes
cpu-z:
http://valid.x86-secret.com/show_oc?id=75579
shot:
http://eclipseoc.com/phpwcms_filestorage/1/1_187.png
and a picture showing the awesome F's:
http://eclipseoc.com/phpwcms_filestorage/1/1_170.jpg
my first contribution here might as well be worth while...
cpu-z validation:
http://valid.x86-secret.com/show_oc.php?id=75528
3oh6 | 2x1GB OCZ PC4000EB Platinum - Infineon CE-6 | 3-3-2-7 1T @ 287 | 2.89v | Link! - SPi 32M Stable: Yes
ss for the clickity click impaired:
http://3oh6.com/forum_posted/xtremes...2048ebpe-1.png
this is the best i could get out of them at 3-3-2-7. i actually shaved about 40 seconds off the 32M time but couldn't get A64 Tweaker to cooperate with the tweaked settings. this kit does more with looser timings but the performance doesn't really warrant it for the most part.
as ozzi has above, i shall provide some eye candy of the sticks in question:
http://3oh6.com/forum_posted/xtremes...2048ebpe-2.jpg
thinkingbear | 2x1GB OCZ PC4000EB Platinum - Infineon CE-6 | 2.5-3-2-5 1T @ 241MHz | 2.6v | Link! - SPi 32M Stable: Yes
CPU is a CCBWE 0544 XPMW, default voltage 1.395. At stock voltage it will do 2.65 GHz, takes over 1.5v to get 2.7 GHz. Because my PC is upstairs in a warm room I am sticking at 2.65v, going to 2.7 GHz is just to warm for my poor TTBT with stock fan. Since I cannot get these sticks 3D stable at >259 MHz I am running a 10/11 divider for effective 241 MHz mem speed. According to Sandra and Everest I am seeing slightly better read and write performance at these speeds and settings than I got with my Ballistix @ 265 MHz 1:1 3-3-3-8, but slightly higher latency. This was first try at tight timings, I think I may have a bit more to shave off tRC, tRFC, Async Latency, and Read preamble, but not much
http://kupras.net/img/265x10on183div.GIF
Eldonko | 2x1GB Mushkin XP4000 - Samsung UCCC | 3-4-4-8 1T @ 283MHz | 2.7v | Link! - SPi 32M Stable: Yes
http://members.shaw.ca/zryan/mush4000-14.JPG
I'm having some real issues with my tracer on my expert passing memtest. Would anyone give me some help?
try with my timings two posts before your, and use the orange slots.Quote:
Originally Posted by TransNone13
