Originally Posted by Highland3r
If you boot 201 or above then the PCI and AGP will be locked at 66/33.
Had a similar issue, iirc 8* wouldnt booot at all, 9-12 were fine, didnt try lower though.
Not sure how the AGP/PCI locks work on these boards tbh, only VERY recently moved over to them. Guessing at 170, the board is running a lock based on 166 fsb (ie setting 167 locks the bus) so 170 would be locked.
Thats only speculation though, someone who knows the answer will be able to explain it properly for you.
