http://futuremark.yougamers.com/foru...70&postcount=1
"They used the 10.2 ATi cats for their comparison by the way."
Incorrect according to even hardocp's tests:
http://www.hardocp.com/article/2010/...er_performance
They saw a moderate improvement (12% across min/max/avg) in Dirt 2 and negligible in everything else they tested.
Fermi is much more likely to add on performance over time (with drivers) IMHO.
I got three letters for you, S-L-I... 3008WFP here and I had 3007WFP before this one. I've been 30 inches for a while now and once you go there you just can't go back! Look at the increases with SLI, IMO the scaling is better than crossfire solution which is mostly why I'm still sticking with Nvidia.
only thing that can fix metro performance is patch from developer
SLI scaling indeed looks good, especially on lower FPS's, which is why you get a SLI system anyway
Has anyone even checked the FPS numbers? BC2 for example. HD5870 according to nV gets 62 FPS yet in [H] review with lower AA it gets 43.5
God knows what settings nV used for this benchmarks. I wouldn't be surprised if its not even DX11.
Exactly. ATI has had what, 7 months or so to refine their drivers? Nvidia should easily add about 15 to 20% (possibly more) increase in performance from driver optimizations alone over the next few months..
I'm betting the 200.xx drivers will be the first to have real G100 optimizations..
If this is true, we have a deference from 470 to 480 32sp witch seems to be a +20% advantage for GTX480, if fermi was with its whole sp512 then maybe we have seen xtra +20% advantage from 5870.
Hope GTX480 ultra or something hits the marker.
Yeah, I'm on a 30 incher myself and those SLI numbers if true look really good.. :eek:
And I'm sure they'll get better as well in the future.
But it's hard to justify spending 1,000 bucks on graphics alone, especially when only a handful of games require that sort of juice to play at 2560x1600 maxed settings..
I don't... they had to have been tweaking things a lot, I doubt they had the first chips ready several months ago and had the specs 100% nailed down at that point in time.
Exactly... it's very hard to justify spending $1k for GFX when half that will max out virtually everything even at 2560x1600, with the remainder being playable with slightly lower settings.
Anyone thats a long time user of Nvidia knows what I'm talking about..
There are a number of occassions in the past where Nvidia has released drivers that increased performance by as much as 20 to 30% on a new architecture..
The best example of this was the GF3 series.....but even the G200 got a good 20% boost in performance from the 180xx and 190xx drivers, compared to the release 170xx drivers.
