Where can I get that Wallpaper???
I do not have disc, could someone please email me a copy?
hardass1@comcast.net
I sure would appreciate it.:up:
You can download from this page: http://www.hwmania.org/forum/evga/73...allpapers.html
Sapphire hd 5770 @ mod bios.
Maybe i can try with a 8400gs or 7300LE
I'm with a hd 4870 @ mod bios to 800/1000. I tried another vga but it was worst. I read in this forum a guy who swapped the vga and was able to break the 223 bclk wall.
Most of the time it's just the settings with the latest bios revisions...
so guys i have a wierd issue and i dont know if its my soundcard or the board itself. For some reason the board will not detect my creative xfi pci card, when i try to install drivers the software says no creative product is found in this system, nothing is in device manager either. The card works on my gigabyte p45 board and my brothers olds chool 478 board. PCI raid card works fine on my evga board. So the PCI slot works, but wont see my creative card. Any ideas or tricks? Thanks
DOH! didnt even think about bios update, i will try that and report back.
so heres what i did:
Bios update: still didnt work
Creative Patch for this specific issue: "no creative product detected in system"
Happened to get my Antec tpq1200 from fedex, installed the PSU. Guess what, out of no where the sound card works. How wierd... im wondering if now that im using two 8 pin motherboard connectors that provide more power? Im not too sure but heckl it saved me from buying a new soundcard.
but it works. Not sure how it started to work but i think the PSU had something to do with it strangely enough.
I have a problem with my asus xonar, when i put this card in any pci-e slots mobo will not boot showing FF code, any one know how to fix that? xonar is working fine with other (asus) mobo.
Are all 759's, Limited Editions?
New beta bioses are out! :D
Added "Turbo Performance" option !!
Turbo performance seems to have problems with dram multiplier -> 10x/12x do not work, I read. It's being set to 8x instead.
Been looking at getting a Classified 760 for my planned uber intel build however despite much searching and also asking on EVGA forums I cant find a conclusive answer to my questions regarding using ether the Prolimatech Mega Shadow or Thermalright True Black on this board.
I would like to be able to use a high end air cooler such as the above mentioned ones in the traditional facing case rear exhaust orientation and also be able to use memory with large heatspreaders/sinks such as G.Skill Perfect Storm's, Corsair Dominator GT etc.
However from what ive read so far i am unable to find out to a high degree of certainty what the situation is, and therefore cant go ahead and start ordering for the new build..
They will fit fine, just don't use 38mm fans.
So as to try and avoid fitting issues ive been looking at Triple Chan DDR3 kits which don't have silly big heat spreaders on as the margins for error with kits with them on is a lil to close for my liking.
Anyone have any thoughts on what would happen with the following(Classy 760/i7 920) -
Geil Black Dragon 12800
http://www.overclockers.co.uk/showpr...=8&subcat=1389
G.Skill HK 12800
http://www.memoryc.com/computermemor...triplekit.html
G.Skill NQ 12800
http://www.tekheads.co.uk/product/GS...Kit_25117.html
Or have any other suggestions ?
Just don't use 38mm fans and you're golden. Can use 1 meter tall RAM if you like then.
