great!!! im waiting for my p6t dlx v2, arrives friday. gonna flash right away with this bios. bye bye throttling :D
@ unclewebb, does also as the support for xeons cpu's?
thanks,
infected_
thanks,
infected_
I'll flash my v2 tonight and test it out. Will post back with results and findings.
I just downloaded from your link and extracted the .RAR. There is the bios and a .txt file. The text file says the following:
"This is a beta bios for the Asus P6T Deluxe Version 1 only."
Your post states Asus has come out with a special bios for the Asus P6T Deluxe v2 board but the above statement taken from the text file included with the BIOS says its only for P6T Deluxe v1?????????
yeah, saw that txt file now also. what gives?! lol
Oops, I forgot to update the nasty warning message. I didn't think anyone actually reads that junk. I'll go update that but the bios contained in that download should be for the v2 board. It will have v2 in the bios file name.
Edit: I changed a 1 to a 2 in the warning message. Everything should be good now.
http://www.mediafire.com/download.php?loyym02zgtm
I don't yet know about improved Xeon support.
Use the latest versions of RealTemp and i7 Turbo when testing things out.
http://www.fileden.com/files/2008/3/...alTempBeta.zip
If I had a Xeon handy I'd be testing now but I don't. Let me know what you find out.Quote:
im almost sure asus did placed support for xeon's on this bios. im gonna try to convince a friend to test it on is p6t dlx v2 and xeon.
Do you know if this is the latest 0610 bios with turbo throttling disabled or is this an older bios? Thanks for clarification on the warning message, the bios does have V2 in the bios name.
Asus isn't very good with the numbering of these special bios versions. They usually start with 000_ but sometimes they count up and sometimes they count down. It's always good to have a look at the bios date.
The date on this special bios looks like today's date in the file.
11/03/2009
You will likely see that date in the CPU-Z Mainboard tab.
I also had a look inside the file and it is definitely a v2 bios.
it is in fact CPU that needs reseating that will often fixed that issue
it has for me on many i7 boards including this one
you start dropping channels if its not sitting right....
had anyone here used one of these boards for Extreme OC? what bios are you using?
Still seeing it drop the multiplier with this bios, shows 11/3/2009 in CPUZ. UGG:(
Hey all, Im probably going to be buying one of these nice boards, I am just wondering what kind of temps you are reaching on your NB with a 4.0 oc on stress and idle, and if anyone happens to have pics of a P6T DL V2 with full chipset and mosfet cooling.
Thanks!
Can you post a screen shot of RealTemp / i7 Turbo / CPU-Z while running Prime 95 or LinX so I have something to send to Asus.
Use the latest tools:
and turn on the log file option in i7 Turbo and send that my way as well.
Open CPU-Z up to the Mainboard tab so the bios version is displayed.
You can upload it to www.sendspace.com
So far Asus has been good at fixing things as long as you can fully document the problem. Make sure you don't have any other monitoring software running while testing including any side bar monitoring gadgets. Some applications use the system timers in an unfriendly manner and can interfere with your results so I want to make sure that your monitoring is accurate.
dinos22: Most users have been cross flashing the v2 boards with the special 0006 v1 bios with good results.
Obviously, the special 0001 v2 bios is still a work in progress and needs some further testing.
unclewebb is correct , i observed Everest with windows monitoring gadget causes i7Turbo tool to misreport multi throttling even with special rev1 bios ( who doesn't throttle for me )
Its a good idea not to run several different monitoring softwares .
New bios 0001 works great for my Xeon W3580, no throttling. 32x134@4288MHz HT on.
im gonna test this new bios 0001 on my p6t dlx v2, which arrives today :D, and 920 D0, and post also the results.
Works great for me as well. There is no throttling. Only issue I see is with version 1 bios the motherboard esata was working. Now with version 2 bios my esata drive is no longer detected. I may crossflash back to version 1 bios as I do use esata. Strange that with stock version 2 bios esata doesn't work either.
unclewebb, post #1380
I flashed my V2 last night to the new 0001 V2 bios and it works great. I was using RealTemp 3.0 and i7Turbo 6.8 while testing after the flash and was getting throttling. I switched to the latest RealTemp 3.39 and i7Turbo 6.9 as unclewebb advised and there is no throttling at all while running LinX @ 4280Mhz HT On.
Thank You!
Thanks for testing this out guys and I'm happy to see no more turbo throttling. :up:
The i7 Turbo program (and RealTemp) works by reading two high performance system timers for each thread to calculate the real time multiplier for that thread. Unfortunately these timers are not a protected resource like they should be so any monitoring software can reset, clear or change these timers at any time which will screw up the results that i7 Turbo displays. Test with as few monitoring programs going as possible. Once you see the results, then go back and enable your other monitoring programs and it will be very clear what programs aren't using your timers in a friendly manner.
Pipeman597: Interesting observation about esata. Your comment will be going directly to Asus and hopefully they can have a look at this.
I read somewhere for 240blck on P6T Deluxe, but it depends from the processor I think.
hey unclewebb
i just flashed to it
everything is alive booting into windows at 5GHz
lets see whats going on with this bios
i'll load up your realtemp as well for temps...hopefully it can pickup core temps when then spike into positives
on SS atm
I think I've seen a screen shot or two with Core i7 sensors working at about -12C. If they're not sticking, they might even go a little lower than that.
They have a much greater range of motion compared to the old 45nm Core 2 sensors that used to get iffy at anything below 50C.
A 5GHz screen shot should put a smile on the Asus rep when he drops by to see how the new bios is doing. :rofl:
S1N3: I just had a look at your log file and it is definitely showing signs of turbo throttling. I can't understand why the other users here aren't having this problem with this new bios. What sort of core temperature are you hitting on core 0? It's odd because it was running OK at the start of your log but it looks like after it's run for a while and as the temps come up it starts to cycle between 21 and 20. Post some screen shots and I'll see what I can do.
Your log file is such a perfect example of what turbo throttling looks like that I decided to post it here so other users can have a look.
The CMULTI column is the average Calculated Multiplier of all of your threads.
The STDEV column beside that shows the Standard Deviation of the multipliers. A very low number like 0.001 or 0.002 shows that all threads are reporting pretty much the exact same thing.
This is definitely showing that the multiplier at full load is cycling back and forth between 21 and 20 on all threads. If you would have kept testing it would probably continue to drop lower and lower until the multiplier was finally spending all of its time at 20X. The MSR multiplier column is just more confirmation that there's a problem here and as soon as this throttling starts to happen, it can no longer maintain the Load meter at 100%.
The moment the load stops, the multiplier is able to jump back up to 21X.
Code:DATE TIME CMULTI STDEV MSR LOAD% NOTES
11/05/09 22:06:50 21.000 0.000 21.000 100.00
11/05/09 22:06:52 21.000 0.000 21.000 100.00
11/05/09 22:06:53 21.000 0.000 21.000 100.00
11/05/09 22:06:55 21.000 0.000 21.000 100.00
11/05/09 22:06:56 21.000 0.000 21.000 100.00
11/05/09 22:06:57 21.000 0.000 21.000 100.00
11/05/09 22:06:58 21.000 0.000 21.000 100.00
11/05/09 22:06:59 21.000 0.000 21.000 100.00
11/05/09 22:07:00 21.000 0.000 21.000 100.00
11/05/09 22:07:01 21.000 0.000 21.000 100.00
11/05/09 22:07:02 21.000 0.000 21.000 100.00
11/05/09 22:07:03 21.000 0.000 21.000 100.00
11/05/09 22:07:04 21.000 0.000 21.000 100.00
11/05/09 22:07:05 21.000 0.000 21.000 100.00
11/05/09 22:07:06 21.000 0.000 21.000 100.00
11/05/09 22:07:07 21.000 0.000 21.000 100.00
11/05/09 22:07:08 21.000 0.000 21.000 100.00
11/05/09 22:07:09 21.000 0.000 21.000 100.00
11/05/09 22:07:10 21.000 0.000 21.000 100.00
11/05/09 22:07:11 21.000 0.000 21.000 100.00
11/05/09 22:07:12 21.000 0.000 21.000 100.00
11/05/09 22:07:13 21.000 0.000 21.000 100.00
11/05/09 22:07:14 21.000 0.000 21.000 100.00
11/05/09 22:07:15 21.000 0.000 21.000 100.00
11/05/09 22:07:16 21.000 0.000 21.000 100.00
11/05/09 22:07:17 21.000 0.000 21.000 100.00
11/05/09 22:07:18 21.000 0.000 21.000 100.00
11/05/09 22:07:19 21.000 0.000 21.000 100.00
11/05/09 22:07:20 21.000 0.000 21.000 100.00
11/05/09 22:07:21 21.000 0.000 21.000 100.00
11/05/09 22:07:22 21.000 0.000 21.000 100.00
11/05/09 22:07:23 21.000 0.000 21.000 100.00
11/05/09 22:07:24 21.000 0.000 21.000 100.00
11/05/09 22:07:25 21.000 0.000 21.000 100.00
11/05/09 22:07:26 21.000 0.000 21.000 100.00
11/05/09 22:07:27 21.000 0.000 21.000 100.00
11/05/09 22:07:28 21.000 0.000 21.000 100.00
11/05/09 22:07:29 21.000 0.000 21.000 100.00
11/05/09 22:07:30 21.000 0.000 21.000 100.00
11/05/09 22:07:31 21.000 0.000 21.000 100.00
11/05/09 22:07:32 21.000 0.000 21.000 100.00
11/05/09 22:07:33 21.000 0.000 21.000 100.00
11/05/09 22:07:34 21.000 0.000 21.000 100.00
11/05/09 22:07:35 21.000 0.000 21.000 100.00
11/05/09 22:07:36 21.000 0.000 21.000 100.00
11/05/09 22:07:37 21.000 0.000 21.000 100.00
11/05/09 22:07:38 21.000 0.000 21.000 100.00
11/05/09 22:07:39 21.000 0.000 21.000 100.00
11/05/09 22:07:40 21.000 0.000 21.000 100.00
11/05/09 22:07:41 21.000 0.000 21.000 100.00
11/05/09 22:07:42 21.000 0.000 21.000 100.00
11/05/09 22:07:43 21.000 0.000 21.000 100.00
11/05/09 22:07:44 21.000 0.000 21.000 100.00
11/05/09 22:07:45 21.000 0.000 21.000 100.00
11/05/09 22:07:46 21.000 0.000 21.000 100.00
11/05/09 22:07:47 21.000 0.000 21.000 100.00
11/05/09 22:07:48 21.000 0.000 21.000 100.00
11/05/09 22:07:49 21.000 0.000 21.000 100.00
11/05/09 22:07:50 21.000 0.000 21.000 100.00
11/05/09 22:07:51 21.000 0.000 21.000 100.00
11/05/09 22:07:52 21.000 0.000 21.000 100.00
11/05/09 22:07:53 21.000 0.000 21.000 100.00
11/05/09 22:07:54 21.000 0.000 21.000 100.00
11/05/09 22:07:55 21.000 0.000 21.000 100.00
11/05/09 22:07:56 21.000 0.000 21.000 100.00
11/05/09 22:07:58 21.000 0.000 21.000 100.00
11/05/09 22:07:59 21.000 0.000 21.000 100.00
11/05/09 22:08:00 21.000 0.000 21.000 91.79
11/05/09 22:08:01 20.856 0.002 21.000 99.93
11/05/09 22:08:02 20.860 0.002 20.875 99.94
11/05/09 22:08:04 20.804 0.001 20.875 99.91
11/05/09 22:08:05 20.837 0.003 21.000 99.92
11/05/09 22:08:06 20.839 0.005 20.875 99.93
11/05/09 22:08:07 20.795 0.003 21.000 99.91
11/05/09 22:08:08 20.774 0.001 21.000 99.90
11/05/09 22:08:09 20.786 0.002 20.750 99.90
11/05/09 22:08:10 20.754 0.001 20.625 99.89
11/05/09 22:08:11 20.737 0.000 20.750 99.88
11/05/09 22:08:12 20.745 0.001 20.875 99.88
11/05/09 22:08:13 20.733 0.000 20.625 99.88
11/05/09 22:08:14 20.736 0.000 20.500 99.88
11/05/09 22:08:15 20.755 0.001 20.750 99.89
11/05/09 22:08:16 20.758 0.002 20.625 99.89
11/05/09 22:08:17 20.727 0.001 20.625 99.87
11/05/09 22:08:18 20.765 0.000 20.750 99.89
11/05/09 22:08:19 20.751 0.001 20.750 99.89
11/05/09 22:08:20 20.774 0.001 20.875 99.90
11/05/09 22:08:21 20.760 0.000 20.875 99.89
11/05/09 22:08:22 20.762 0.001 21.000 99.89
11/05/09 22:08:23 20.756 0.001 20.750 99.89
11/05/09 22:08:24 20.770 0.001 20.750 99.89
11/05/09 22:08:25 20.721 0.001 20.750 99.87
11/05/09 22:08:26 20.742 0.000 21.000 99.88
11/05/09 22:08:27 20.747 0.001 20.750 99.88
11/05/09 22:08:28 20.720 0.001 21.000 99.87
11/05/09 22:08:29 20.718 0.001 20.625 99.87
11/05/09 22:08:30 20.710 0.000 20.625 99.87
11/05/09 22:08:31 20.697 0.002 20.625 99.86
11/05/09 22:08:32 20.708 0.001 20.500 99.87
11/05/09 22:08:33 20.691 0.000 21.000 99.86
11/05/09 22:08:34 20.700 0.001 20.875 99.86
11/05/09 22:08:35 20.737 0.001 20.750 99.88
11/05/09 22:08:36 20.714 0.000 20.750 99.87
11/05/09 22:08:37 20.721 0.001 20.875 99.87
11/05/09 22:08:38 20.745 0.001 20.500 99.88
11/05/09 22:08:39 20.716 0.001 20.750 99.87
11/05/09 22:08:40 20.722 0.001 20.625 99.87
11/05/09 22:08:41 20.728 0.000 20.750 99.87
11/05/09 22:08:42 20.794 0.002 20.750 99.90
11/05/09 22:08:43 20.763 0.002 20.750 99.89
11/05/09 22:08:44 20.719 0.000 20.625 99.87
11/05/09 22:08:45 20.702 0.000 20.500 99.86
11/05/09 22:08:46 20.713 0.001 20.750 99.87
11/05/09 22:08:47 20.661 0.001 20.750 99.84
11/05/09 22:08:48 20.690 0.002 20.750 99.86
11/05/09 22:08:49 20.679 0.002 20.375 99.85
11/05/09 22:08:50 20.678 0.002 20.875 99.85
11/05/09 22:08:51 20.680 0.001 20.500 99.85
11/05/09 22:08:52 20.735 0.001 20.625 99.88
11/05/09 22:08:53 20.662 0.001 20.500 99.84
11/05/09 22:08:54 20.696 0.000 20.750 99.86
11/05/09 22:08:55 20.692 0.000 20.500 99.86
11/05/09 22:08:56 20.684 0.001 20.625 99.85
11/05/09 22:08:57 20.657 0.002 20.500 99.84
11/05/09 22:08:58 20.660 0.002 20.875 99.84
11/05/09 22:08:59 20.659 0.001 20.625 99.84
11/05/09 22:09:00 20.719 0.001 20.875 99.87
11/05/09 22:09:01 20.708 0.001 20.750 99.87
11/05/09 22:09:02 20.719 0.002 20.625 99.87
11/05/09 22:09:03 20.715 0.003 20.625 99.87
11/05/09 22:09:04 20.721 0.001 20.750 99.87
11/05/09 22:09:05 20.712 0.002 20.625 99.87
11/05/09 22:09:06 20.675 0.001 20.500 99.85
11/05/09 22:09:07 20.631 0.001 20.500 99.83
11/05/09 22:09:08 20.685 0.001 20.625 99.86
11/05/09 22:09:09 20.683 0.000 20.750 99.85
11/05/09 22:09:10 20.700 0.000 20.625 99.86
11/05/09 22:09:11 20.708 0.002 20.750 99.87
11/05/09 22:09:12 20.728 0.001 20.625 99.87
11/05/09 22:09:13 20.700 0.000 20.750 99.86
11/05/09 22:09:14 20.684 0.000 20.750 99.86
11/05/09 22:09:16 20.692 0.002 20.500 99.86
11/05/09 22:09:17 20.642 0.001 20.875 99.84
11/05/09 22:09:18 20.672 0.001 20.500 99.85
11/05/09 22:09:19 20.659 0.001 20.750 99.84
11/05/09 22:09:20 20.694 0.001 20.500 99.86
11/05/09 22:09:21 20.701 0.001 20.750 99.86
11/05/09 22:09:22 20.686 0.001 20.625 99.86
11/05/09 22:09:23 20.662 0.001 20.500 99.84
11/05/09 22:09:24 20.675 0.001 20.875 99.85
11/05/09 22:09:25 20.649 0.002 20.625 99.84
11/05/09 22:09:26 20.608 0.003 20.875 99.82
11/05/09 22:09:27 20.630 0.002 20.750 99.83
11/05/09 22:09:28 20.621 0.001 20.500 99.83
11/05/09 22:09:29 20.672 0.001 20.750 99.85
11/05/09 22:09:30 20.651 0.002 20.875 99.84
11/05/09 22:09:31 20.658 0.001 20.875 99.84
11/05/09 22:09:32 20.680 0.001 20.500 99.85
11/05/09 22:09:33 20.655 0.002 20.625 99.84
11/05/09 22:09:34 20.643 0.001 20.625 99.84
11/05/09 22:09:35 20.660 0.003 20.875 99.84
11/05/09 22:09:36 20.625 0.003 21.000 99.83
11/05/09 22:09:37 20.634 0.002 20.750 99.83
11/05/09 22:09:38 20.652 0.000 20.500 99.84
11/05/09 22:09:39 20.696 0.001 20.625 99.86
11/05/09 22:09:40 20.653 0.003 20.750 99.84
11/05/09 22:09:41 20.660 0.003 20.500 99.85
11/05/09 22:09:42 20.609 0.007 21.000 99.83
11/05/09 22:09:43 20.866 0.004 21.000 96.89
11/05/09 22:09:44 21.000 0.000 21.000 4.39
11/05/09 22:09:45 20.999 0.001 21.000 2.05
11/05/09 22:09:46 21.000 0.000 21.000 1.97
11/05/09 22:09:47 20.999 0.001 21.000 2.25
11/05/09 22:09:48 21.000 0.001 21.000 2.48
11/05/09 22:09:49 20.999 0.000 21.000 2.25
11/05/09 22:09:50 20.999 0.000 21.000 1.58
11/05/09 22:09:51 20.999 0.000 21.000 2.06
11/05/09 22:09:52 20.999 0.000 21.000 1.53
11/05/09 22:09:53 20.999 0.000 21.000 1.92
11/05/09 22:09:54 20.999 0.000 21.000 1.97
11/05/09 22:09:55 20.999 0.000 21.000 1.99
11/05/09 22:09:56 20.999 0.000 21.000 1.83
11/05/09 22:09:57 20.999 0.000 21.000 2.19
11/05/09 22:09:58 20.999 0.001 21.000 2.01
11/05/09 22:09:59 21.000 0.001 21.000 2.34 21x_multi
11/05/09 22:10:00 20.999 0.000 21.000 1.61
11/05/09 22:10:01 20.999 0.000 21.000 2.06
11/05/09 22:10:02 21.000 0.001 21.000 1.77
11/05/09 22:10:03 21.000 0.000 21.000 2.02
11/05/09 22:10:04 20.999 0.000 21.000 1.61
11/05/09 22:10:05 21.000 0.000 21.000 2.01
11/05/09 22:10:06 20.999 0.000 21.000 1.75
11/05/09 22:10:07 21.000 0.000 21.000 2.01
11/05/09 22:10:08 20.999 0.000 21.000 1.60
11/05/09 22:10:09 20.999 0.000 21.000 2.31
11/05/09 22:10:10 20.999 0.001 21.000 2.34
11/05/09 22:10:11 20.999 0.001 21.000 2.14
11/05/09 22:10:12 21.000 0.000 21.000 1.77
11/05/09 22:10:13 20.999 0.000 21.000 1.87
11/05/09 22:10:14 20.999 0.000 21.000 2.03
11/05/09 22:10:15 21.000 0.000 21.000 1.81
11/05/09 22:10:16 20.999 0.000 21.000 1.80
11/05/09 22:10:17 20.999 0.000 21.000 1.75
11/05/09 22:10:18 20.999 0.000 21.000 1.73
11/05/09 22:10:19 20.999 0.000 21.000 1.81
11/05/09 22:10:20 20.999 0.000 21.000 1.81
11/05/09 22:10:21 20.999 0.001 21.000 1.80
11/05/09 22:10:22 20.999 0.000 21.000 1.79
11/05/09 22:10:23 21.000 0.000 21.000 1.81
11/05/09 22:10:24 20.999 0.000 21.000 1.81
11/05/09 22:10:25 20.999 0.000 21.000 1.79
11/05/09 22:10:26 20.999 0.001 21.000 1.80
11/05/09 22:10:27 21.000 0.001 21.000 1.81
11/05/09 22:10:28 20.999 0.000 21.000 2.10
11/05/09 22:10:29 21.000 0.000 21.000 2.30
11/05/09 22:10:30 20.999 0.000 21.000 2.12
11/05/09 22:10:31 20.999 0.001 21.000 2.02
11/05/09 22:10:32 20.999 0.000 21.000 1.86
11/05/09 22:10:33 21.000 0.000 21.000 1.76
11/05/09 22:10:34 20.999 0.001 21.000 1.71
11/05/09 22:10:35 21.000 0.001 21.000 1.74
11/05/09 22:10:37 20.999 0.000 21.000 1.76
11/05/09 22:10:38 21.000 0.000 21.000 1.82
11/05/09 22:10:39 20.999 0.000 21.000 1.81
11/05/09 22:10:40 21.000 0.000 21.000 2.18
11/05/09 22:10:41 20.999 0.000 21.000 2.02
11/05/09 22:10:42 20.999 0.001 21.000 1.80
11/05/09 22:10:43 20.999 0.000 21.000 1.80
11/05/09 22:10:44 21.000 0.000 21.000 1.81
11/05/09 22:10:45 20.999 0.000 21.000 1.79
11/05/09 22:10:46 20.999 0.000 21.000 1.94
11/05/09 22:10:47 20.999 0.000 21.000 1.78
11/05/09 22:10:48 21.000 0.001 21.000 1.79
11/05/09 22:10:49 20.999 0.000 21.000 1.75
11/05/09 22:10:50 20.999 0.000 21.000 1.75
11/05/09 22:10:51 20.999 0.000 21.000 1.75
11/05/09 22:10:52 21.000 0.001 21.000 1.74
11/05/09 22:10:53 20.999 0.000 21.000 1.73
11/05/09 22:10:54 20.999 0.001 21.000 1.72
11/05/09 22:10:55 21.000 0.000 21.000 3.18
11/05/09 22:10:56 20.999 0.000 21.000 2.13
11/05/09 22:10:57 20.999 0.000 21.000 1.95
11/05/09 22:10:58 20.999 0.001 21.000 1.78
11/05/09 22:10:59 21.000 0.001 21.000 2.09
11/05/09 22:11:00 21.000 0.000 21.000 4.55
11/05/09 22:11:01 20.999 0.000 21.000 2.30
11/05/09 22:11:02 20.999 0.001 21.000 4.37
11/05/09 22:11:03 21.000 0.001 21.000 2.03
11/05/09 22:11:04 20.999 0.001 21.000 4.12
11/05/09 22:11:05 21.000 0.000 21.000 3.15
11/05/09 22:11:06 20.999 0.000 21.000 2.11
11/05/09 22:11:07 20.999 0.000 21.000 2.00
11/05/09 22:11:08 20.999 0.001 21.000 2.43
11/05/09 22:11:09 21.000 0.000 21.000 2.47
11/05/09 22:11:10 20.999 0.000 21.000 1.74
11/05/09 22:11:11 20.999 0.000 21.000 1.70
11/05/09 22:11:12 21.000 0.000 21.000 2.02
11/05/09 22:11:13 20.999 0.000 21.000 2.12
11/05/09 22:11:14 20.999 0.001 21.000 2.05
11/05/09 22:11:15 21.000 0.000 21.000 2.55
11/05/09 22:11:16 20.999 0.000 21.000 2.19
11/05/09 22:11:17 21.000 0.000 21.000 4.63
11/05/09 22:11:18 20.999 0.000 21.000 1.99
11/05/09 22:11:19 21.000 0.000 21.000 2.14
11/05/09 22:11:20 20.999 0.000 21.000 2.07
11/05/09 22:11:21 21.000 0.000 21.000 1.85
11/05/09 22:11:22 20.999 0.000 21.000 1.86
11/05/09 22:11:23 21.000 0.000 21.000 1.75
11/05/09 22:11:24 20.999 0.000 21.000 1.73
11/05/09 22:11:25 21.000 0.000 21.000 1.72
11/05/09 22:11:26 20.999 0.000 21.000 1.71
11/05/09 22:11:27 20.999 0.000 21.000 1.67
11/05/09 22:11:28 21.000 0.001 21.000 1.69
11/05/09 22:11:29 20.999 0.000 21.000 1.73
11/05/09 22:11:30 20.999 0.000 21.000 1.77
11/05/09 22:11:31 21.000 0.000 21.000 1.76
11/05/09 22:11:32 20.999 0.000 21.000 2.85
11/05/09 22:11:33 20.999 0.000 21.000 2.01
11/05/09 22:11:34 20.999 0.001 21.000 1.88
11/05/09 22:11:35 21.000 0.001 21.000 2.01
11/05/09 22:11:36 20.999 0.000 21.000 2.59
11/05/09 22:11:37 21.000 0.000 21.000 2.80
11/05/09 22:11:38 20.999 0.001 21.000 2.09
11/05/09 22:11:39 21.000 0.001 21.000 2.06
11/05/09 22:11:41 20.999 0.000 21.000 2.10
11/05/09 22:11:42 20.999 0.000 21.000 1.78
11/05/09 22:11:43 20.999 0.000 21.000 1.73
11/05/09 22:11:44 21.000 0.000 21.000 2.05
11/05/09 22:11:45 20.999 0.000 21.000 1.73
11/05/09 22:11:46 20.999 0.000 21.000 1.85
11/05/09 22:11:47 20.999 0.001 21.000 1.58
11/05/09 22:11:48 21.000 0.001 21.000 2.49
11/05/09 22:11:49 20.999 0.000 21.000 2.15
11/05/09 22:11:50 21.000 0.000 21.000 3.20
11/05/09 22:11:51 20.999 0.000 21.000 8.48
11/05/09 22:11:52 21.000 0.000 21.000 8.97
11/05/09 22:11:53 20.999 0.000 21.000 1.89
11/05/09 22:11:54 20.999 0.000 21.000 2.10
11/05/09 22:11:55 20.999 0.000 21.000 1.62
11/05/09 22:11:56 21.000 0.000 21.000 1.95
11/05/09 22:11:57 20.999 0.000 21.000 2.08
11/05/09 22:11:58 21.000 0.000 21.000 3.12
11/05/09 22:11:59 20.999 0.000 21.000 2.03
11/05/09 22:12:00 21.000 0.000 21.000 1.97
11/05/09 22:12:01 20.999 0.001 21.000 1.69
11/05/09 22:12:02 21.000 0.000 21.000 2.53
11/05/09 22:12:03 20.999 0.001 21.000 1.66
11/05/09 22:12:04 21.000 0.001 21.000 2.07
11/05/09 22:12:05 20.999 0.000 21.000 1.75
11/05/09 22:12:06 20.999 0.000 21.000 2.05
11/05/09 22:12:07 20.999 0.001 21.000 1.57
11/05/09 22:12:08 21.000 0.001 21.000 1.94
11/05/09 22:12:09 20.999 0.000 21.000 1.55
11/05/09 22:12:10 20.999 0.000 21.000 1.93
11/05/09 22:12:11 20.999 0.000 21.000 1.72
11/05/09 22:12:12 21.000 0.000 21.000 1.73
11/05/09 22:12:13 20.999 0.000 21.000 1.89
11/05/09 22:12:14 20.999 0.000 21.000 1.78
11/05/09 22:12:15 20.999 0.000 21.000 1.75
11/05/09 22:12:16 21.000 0.001 21.000 1.72
11/05/09 22:12:17 20.999 0.000 21.000 1.69
11/05/09 22:12:18 20.999 0.000 21.000 1.84
11/05/09 22:12:19 20.999 0.000 21.000 1.85
11/05/09 22:12:20 20.999 0.000 21.000 1.81
11/05/09 22:12:21 20.999 0.000 21.000 1.76
11/05/09 22:12:22 20.999 0.000 21.000 1.86
11/05/09 22:12:23 20.999 0.000 21.000 1.76
11/05/09 22:12:24 21.000 0.000 21.000 1.78
11/05/09 22:12:25 20.999 0.000 21.000 1.74
11/05/09 22:12:26 20.999 0.000 21.000 1.73
11/05/09 22:12:27 20.999 0.000 21.000 2.00
11/05/09 22:12:28 20.999 0.000 21.000 1.91
11/05/09 22:12:29 20.999 0.000 21.000 1.88
11/05/09 22:12:30 20.999 0.000 21.000 1.95
11/05/09 22:12:31 20.999 0.001 21.000 1.83
11/05/09 22:12:32 21.000 0.001 21.000 1.74
11/05/09 22:12:33 20.999 0.000 21.000 1.70
11/05/09 22:12:34 20.999 0.000 21.000 1.73
11/05/09 22:12:35 20.999 0.000 21.000 1.93
11/05/09 22:12:36 21.000 0.000 21.000 2.12
11/05/09 22:12:37 20.999 0.000 21.000 1.76
11/05/09 22:12:38 20.999 0.000 21.000 1.68
11/05/09 22:12:39 20.999 0.000 21.000 2.63
11/05/09 22:12:40 20.999 0.000 21.000 2.15
11/05/09 22:12:41 20.999 0.000 21.000 2.12
11/05/09 22:12:42 20.999 0.000 21.000 1.98
11/05/09 22:12:43 20.999 0.000 21.000 2.02
11/05/09 22:12:44 21.000 0.000 21.000 2.61
11/05/09 22:12:45 20.999 0.000 21.000 2.45
11/05/09 22:12:46 21.000 0.001 21.000 1.92
11/05/09 22:12:47 20.999 0.000 21.000 1.80
11/05/09 22:12:48 20.999 0.000 21.000 1.74
11/05/09 22:12:49 20.999 0.000 21.000 1.73
11/05/09 22:12:50 21.000 0.000 21.000 2.49
11/05/09 22:12:51 20.999 0.000 21.000 2.35
11/05/09 22:12:52 20.999 0.000 21.000 2.24
11/05/09 22:12:54 21.000 0.000 21.000 3.60
11/05/09 22:12:55 21.000 0.001 21.000 2.24
11/05/09 22:12:56 20.999 0.000 21.000 2.26
11/05/09 22:12:57 20.999 0.000 21.000 2.17
11/05/09 22:12:58 20.999 0.000 21.000 2.97
11/05/09 22:12:59 20.999 0.000 21.000 2.35
11/05/09 22:13:00 20.999 0.000 21.000 2.07
11/05/09 22:13:01 20.999 0.000 21.000 1.94
11/05/09 22:13:02 20.999 0.001 21.000 2.28
11/05/09 22:13:03 21.000 0.000 21.000 2.80
11/05/09 22:13:04 20.999 0.000 21.000 4.81
11/05/09 22:13:05 21.000 0.000 21.000 6.58
11/05/09 22:13:06 20.999 0.001 21.000 1.74
11/05/09 22:13:07 21.000 0.000 21.000 1.74
11/05/09 22:13:08 20.999 0.000 21.000 1.72
11/05/09 22:13:09 20.999 0.000 21.000 1.70
11/05/09 22:13:10 20.999 0.000 21.000 8.69
11/05/09 22:13:11 21.000 0.001 21.000 2.09
11/05/09 22:13:12 20.999 0.000 21.000 2.03
11/05/09 22:13:13 20.999 0.000 21.000 1.92
11/05/09 22:13:14 20.999 0.001 21.000 1.92
11/05/09 22:13:15 21.000 0.000 21.000 2.19
11/05/09 22:13:16 21.000 0.000 21.000 2.21
11/05/09 22:13:17 20.999 0.000 21.000 1.86
11/05/09 22:13:18 20.999 0.000 21.000 2.29
11/05/09 22:13:19 21.000 0.001 21.000 2.32
11/05/09 22:13:20 20.999 0.000 21.000 1.85
11/05/09 22:13:21 20.999 0.000 21.000 1.86
11/05/09 22:13:22 20.999 0.000 21.000 1.89
11/05/09 22:13:23 20.999 0.000 21.000 2.10
11/05/09 22:13:24 20.999 0.000 21.000 1.77
11/05/09 22:13:25 20.999 0.000 21.000 1.79
11/05/09 22:13:26 20.999 0.000 21.000 1.72
11/05/09 22:13:27 21.000 0.000 21.000 1.88
11/05/09 22:13:28 20.999 0.000 21.000 2.18
11/05/09 22:13:29 20.999 0.000 21.000 1.75
11/05/09 22:13:30 20.999 0.000 21.000 1.86
11/05/09 22:13:31 21.000 0.001 21.000 2.50
11/05/09 22:13:32 20.999 0.000 21.000 1.94
11/05/09 22:13:33 20.999 0.000 21.000 1.81
11/05/09 22:13:34 20.999 0.000 21.000 2.21
11/05/09 22:13:35 21.000 0.001 21.000 1.90
11/05/09 22:13:36 21.000 0.000 21.000 1.72
11/05/09 22:13:37 20.999 0.000 21.000 1.74
11/05/09 22:13:38 20.999 0.000 21.000 1.72
11/05/09 22:13:39 21.000 0.001 21.000 1.73
11/05/09 22:13:40 20.999 0.000 21.000 1.72
11/05/09 22:13:41 20.999 0.000 21.000 1.90
11/05/09 22:13:42 20.999 0.001 21.000 2.13
11/05/09 22:13:43 21.000 0.001 21.000 1.99
11/05/09 22:13:44 20.999 0.000 21.000 1.68
11/05/09 22:13:45 20.999 0.000 21.000 2.15
11/05/09 22:13:46 20.999 0.000 21.000 1.86
11/05/09 22:13:47 20.999 0.000 21.000 1.87
11/05/09 22:13:48 20.999 0.000 21.000 1.69
11/05/09 22:13:49 20.999 0.000 21.000 1.87
11/05/09 22:13:50 20.999 0.001 21.000 1.97
11/05/09 22:13:51 21.000 0.001 21.000 1.80
11/05/09 22:13:52 20.999 0.000 21.000 1.96
11/05/09 22:13:53 20.999 0.000 21.000 1.91
11/05/09 22:13:54 20.999 0.001 21.000 1.92
11/05/09 22:13:55 21.000 0.001 21.000 2.81
11/05/09 22:13:56 20.999 0.000 21.000 1.85
11/05/09 22:13:57 21.000 0.000 21.000 1.82
11/05/09 22:13:58 20.999 0.000 21.000 2.47
11/05/09 22:13:59 20.999 0.000 21.000 2.24
11/05/09 22:14:00 20.999 0.000 21.000 1.74
11/05/09 22:14:01 20.999 0.000 21.000 1.75
11/05/09 22:14:02 20.999 0.000 21.000 1.94
11/05/09 22:14:03 20.999 0.000 21.000 1.61
11/05/09 22:14:04 20.999 0.000 21.000 1.84
11/05/09 22:14:06 20.999 0.000 21.000 1.46
11/05/09 22:14:07 20.999 0.000 21.000 1.89
11/05/09 22:14:08 20.999 0.000 21.000 1.53
11/05/09 22:14:09 20.999 0.000 21.000 1.91
11/05/09 22:14:10 20.999 0.000 21.000 1.56
11/05/09 22:14:11 20.999 0.001 21.000 2.01
11/05/09 22:14:12 21.000 0.001 21.000 1.78
11/05/09 22:14:13 20.999 0.000 21.000 2.17
11/05/09 22:14:14 20.999 0.000 21.000 1.76
11/05/09 22:14:15 20.999 0.000 21.000 1.93
11/05/09 22:14:16 20.999 0.000 21.000 1.55
11/05/09 22:14:17 20.999 0.000 21.000 1.92
11/05/09 22:14:18 20.999 0.000 21.000 1.76
11/05/09 22:14:19 20.999 0.001 21.000 1.97
11/05/09 22:14:20 21.000 0.001 21.000 1.50
11/05/09 22:14:21 20.999 0.000 21.000 2.06
11/05/09 22:14:22 20.999 0.000 21.000 1.55
11/05/09 22:14:23 20.999 0.000 21.000 2.15
11/05/09 22:14:24 21.000 0.001 21.000 1.78
11/05/09 22:14:25 20.999 0.000 21.000 2.67
11/05/09 22:14:26 20.999 0.000 21.000 2.02
11/05/09 22:14:27 20.999 0.000 21.000 2.14
11/05/09 22:14:28 20.999 0.000 21.000 2.95
11/05/09 22:14:29 20.999 0.000 21.000 2.20
11/05/09 22:14:30 20.999 0.000 21.000 1.97
11/05/09 22:14:31 20.999 0.000 21.000 1.90
11/05/09 22:14:32 21.000 0.000 21.000 1.79
11/05/09 22:14:33 20.999 0.000 21.000 1.73
11/05/09 22:14:34 20.999 0.000 21.000 1.73
11/05/09 22:14:35 20.999 0.001 21.000 1.73
11/05/09 22:14:36 21.000 0.000 21.000 1.70
11/05/09 22:14:37 20.999 0.000 21.000 1.69
11/05/09 22:14:38 20.999 0.000 21.000 1.69
11/05/09 22:14:39 20.999 0.000 21.000 1.68
11/05/09 22:14:40 21.000 0.000 21.000 1.69
11/05/09 22:14:41 20.999 0.000 21.000 1.79
11/05/09 22:14:42 20.999 0.000 21.000 2.84
11/05/09 22:14:43 20.999 0.000 21.000 2.80
11/05/09 22:14:44 21.000 0.000 21.000 2.08
11/05/09 22:14:45 20.999 0.000 21.000 1.74
11/05/09 22:14:46 20.999 0.000 21.000 1.76
11/05/09 22:14:47 20.999 0.000 21.000 2.88
11/05/09 22:14:48 21.000 0.000 21.000 2.00
11/05/09 22:14:49 20.999 0.000 21.000 1.74
11/05/09 22:14:50 20.999 0.000 21.000 1.75
11/05/09 22:14:51 20.999 0.000 21.000 1.73
11/05/09 22:14:52 20.999 0.000 21.000 1.72
11/05/09 22:14:53 20.999 0.000 21.000 1.70
11/05/09 22:14:54 20.999 0.000 21.000 1.69
11/05/09 22:14:55 20.999 0.000 21.000 1.71
11/05/09 22:14:56 20.999 0.001 21.000 1.69
11/05/09 22:14:57 20.999 0.000 21.000 1.67
11/05/09 22:14:58 20.999 0.000 21.000 1.68
11/05/09 22:14:59 20.999 0.001 21.000 1.74
11/05/09 22:15:00 20.999 0.001 21.000 1.75
11/05/09 22:15:01 20.999 0.000 21.000 2.10
11/05/09 22:15:02 20.999 0.001 21.000 1.94
11/05/09 22:15:03 21.000 0.001 21.000 1.78
11/05/09 22:15:04 21.000 0.000 21.000 1.75
11/05/09 22:15:05 20.999 0.000 21.000 1.77
11/05/09 22:15:06 21.000 0.000 21.000 4.10
11/05/09 22:15:07 20.999 0.000 21.000 2.29
11/05/09 22:15:08 21.000 0.000 21.000 2.43
11/05/09 22:15:09 21.000 0.000 21.000 5.02
11/05/09 22:15:10 20.999 0.000 21.000 2.30
11/05/09 22:15:11 20.999 0.000 21.000 2.90
11/05/09 22:15:12 20.999 0.000 21.000 2.11
11/05/09 22:15:13 20.999 0.000 21.000 1.97
11/05/09 22:15:14 21.000 0.000 21.000 2.63
11/05/09 22:15:15 20.999 0.000 21.000 1.87
11/05/09 22:15:16 20.999 0.000 21.000 2.12
11/05/09 22:15:17 20.999 0.000 21.000 2.10
11/05/09 22:15:19 20.999 0.000 21.000 2.07
11/05/09 22:15:20 20.999 0.000 21.000 3.06
11/05/09 22:15:21 21.000 0.000 21.000 2.31
11/05/09 22:15:22 21.000 0.000 21.000 2.76
11/05/09 22:15:23 20.999 0.000 21.000 2.09
11/05/09 22:15:24 20.999 0.000 21.000 1.83
11/05/09 22:15:25 21.000 0.000 21.000 2.02
11/05/09 22:15:26 20.999 0.000 21.000 1.77
11/05/09 22:15:27 20.999 0.000 21.000 1.82
11/05/09 22:15:28 20.999 0.001 21.000 1.77
11/05/09 22:15:29 21.000 0.001 21.000 1.72
11/05/09 22:15:30 20.999 0.000 21.000 1.72
11/05/09 22:15:31 21.000 0.000 21.000 1.74
11/05/09 22:15:32 20.999 0.000 21.000 1.78
11/05/09 22:15:33 21.000 0.000 21.000 1.68
11/05/09 22:15:34 20.999 0.000 21.000 1.75
11/05/09 22:15:35 20.999 0.000 21.000 1.96
11/05/09 22:15:36 20.999 0.000 21.000 1.77
11/05/09 22:15:37 20.999 0.000 21.000 1.73
11/05/09 22:15:38 20.999 0.000 21.000 1.80
11/05/09 22:15:39 21.000 0.000 21.000 1.75
11/05/09 22:15:40 20.999 0.000 21.000 1.78
11/05/09 22:15:41 21.000 0.000 21.000 1.72
11/05/09 22:15:42 20.999 0.000 21.000 1.76
11/05/09 22:15:43 20.999 0.000 21.000 1.76
11/05/09 22:15:44 20.999 0.000 21.000 1.77
11/05/09 22:15:45 21.000 0.001 21.000 1.92
11/05/09 22:15:46 20.999 0.000 21.000 1.79
11/05/09 22:15:47 21.000 0.000 21.000 1.72
11/05/09 22:15:48 20.999 0.001 21.000 1.72
11/05/09 22:15:49 21.000 0.001 21.000 2.10
11/05/09 22:15:50 20.999 0.000 21.000 2.15
11/05/09 22:15:51 21.000 0.000 21.000 2.32
11/05/09 22:15:52 20.999 0.001 21.000 2.00
11/05/09 22:15:53 21.000 0.000 21.000 1.82
11/05/09 22:15:54 20.999 0.000 21.000 1.85
11/05/09 22:15:55 20.999 0.000 21.000 1.94
11/05/09 22:15:56 20.999 0.000 21.000 1.79
11/05/09 22:15:57 21.000 0.000 21.000 1.78
11/05/09 22:15:58 20.999 0.000 21.000 1.80
11/05/09 22:15:59 20.999 0.000 21.000 1.82
11/05/09 22:16:00 20.999 0.000 21.000 1.82
