Ok
I had some PC2-8500 Doms. a while back, they were awesome and then they died (I balm my P5E) and I got :banana::banana::banana::banana: ones back from RMA that couldn't run stock. The great thing is that they died to :D
Ok
one stick is @ 1200 5 5 5 15
Nice
What volts?
2.3 with one stick seems high. but i thing it due to this dfi 680 lt
Corsair QC at its best its been for years there :up:
it was @ 2.31 i lowerd it to 2.28 ill see if i can go lower
k i lowered the voltage to 2.19.
Same thing happened to me. My version 1.2 and 1.4 Dominators died in less than a year and they sent back absolute trash in return. With one stick DOA. They would do 1040Mhz C5 stable but not much more. I'm done with them.
Don't blame your P5E those sticks seem to die fast regardless of voltage or motherboard.
Those sticks seem to be hit or miss. Same with the PC2-6400 C3 on Newegg, lots of people posting reviews that the memory is either DOA or dies after a month or two.
I wonder what Corsair is sending people who's PC2-9136 sticks die or the PC2-8888 for that matter. Are they just sending back slightly higher binned 8500C5D?
Well I got ver 1.1 when I originally brought my kit and I got sent ver 1.1 back.
I agree, there is no reason kits shouldn't be able to run stock.
im loving the UT-P35-T2R memory performance with my d9gmh.
http://i39.tinypic.com/2hn5hzb.jpg
Those numbers arent so far off P45 for that FSB, in fact, I've seen higher numbers on the P45 with very similar settings, so indeed not a bad showing from a P35 :up:
Maybe someone could tell me why my bandwidth is so low?
With these setting on my P5E I got around 92xxMB/s for Read, Write and Copy.
http://i292.photobucket.com/albums/m...AMLowSpeed.jpg
Those subtimings are awfully loose, but P45 isn't going to match the bandwidth of X38 either way.
