I managed to drop my volts again, I don't know if they can get any lower:
CPU: +0.050
DDR: +0.400
Chipset: +0.225
FSB: +0.225
CPU1 GTL: 0.63VTT
CPU2 GTL: 0.63VTT
MCH GTL: 0.59VTT
CPU PLL: 1.6V
http://i40.tinypic.com/1z15t79.jpg
CPU: +0.050
DDR: +0.400
Chipset: +0.225
FSB: +0.225
CPU1 GTL: 0.63VTT
CPU2 GTL: 0.63VTT
MCH GTL: 0.59VTT
CPU PLL: 1.6V
Hey guys!
It's been a while, I sold my Biostar TPower I45, now have the Biostar TP45HP. Just wondering if the Bios for the I45 will work on this board? now that I type this I'm thinking nope. figured I'd ask as when I first got this board I had crazy over clocks then it just seemed to not want to OC as well after a while.....
Any and all help, Thanks!
What is the size of the fan on the I45 Chipset cooler?
The annoying RAID adapter message is the IDE controller making its presence known. There is no way to disable it with the official 7/10 BIOS; however, they did give out a beta that gives you that function. I've got it in the downloads section of my (just started) website, or you can get it from rebelshaven I believe.
So you got your Northbridge Cooler Aka 1 x DIY Thermal Kit just laying around in the Box?
http://img75.imageshack.us/img75/540...rmalkitta7.jpg
I might remove the fan since the 120mm fan in the antec 900 is right next to it. Then let it run "passive" even though theres a 120mm fan next to it.
need some help, trying run raid0
any help would be great,thanks
Just out of curiosity, has anyone e-mailed Biostar asking for smaller increment increases for voltages on this board?
Sorry Scorpion, never run raid so I'm of little help. Which OS; Vista or XP?
No one I know since Lvcoyote did. IIRC, they thanked him for his input, but they did send him the beta that lets you disable the Marvell controller (and get rid of the annoying RAID message) and adds some additional RCOMP configurations (you can get it here if you don't have it already).
greeting
I have the Biostar TPower I45. I wonder whether it is compatible cooling Thermalright Ultra-120 Extreme?
can image?
could'en get your pics to pop up are talking about this TRU 90
http://www.sidewindercomputers.com/thxpforforin.html
if you can show your case what your puttung this in so we can
have idea what your working with.
I intend to buy TRUE, but I'm not sure
Here's how it looks but is not TRU 120E but TRU 90 http://www.overclockersonline.net/im...large/tf21.jpg
http://www.overclockersonline.net/im...large/tf23.jpg
a display problems in the code.
I am now lies in the image code. if you do not work again, and here's the link http://www.overclockersonline.net/?p...um=1921&pnum=4
I would say that TRUE and TRU 90 is a bit similar in size a few more ..
I will try to send e-mail headquarters ThermalRight queries regarding compatibility and Biostar T-power ... although I would see some home support but nowhere on the list does not Biostar
That is piece of sh..t - doesn't hurt but does nothing better.
Overclocking with RAID setup isn't good at all. RAID contra will mess it up - it is not just Biostar, other (like Asus boards I have used) have the same problem.
Good news: I was told that Biostar RMA normaly takes 4 weeks (I sent my board them more than 4 ago).
I have raid0 here with a set of two partitions working like a charm and i just have saved this screen
So, Raid works very well, if its good or not i dont know yet, but this setting is running about 3 months ago.
Just an advice when using raid0, don't let important data on arrays, put them of a safe non-raid backup HDD or use another raid setting.
http://img360.imageshack.us/img360/2100/raidxv5.jpg
HI,
Just got my i45, with an e7300, (small budget)
Im using a TRU120 (non extreme) with a zalman F3, Im running at 3.6 (450x8) at 1.272v (havent tried any lower)
However, for 4GHz (10x400), or 4.05GHz I needed 1.416v, (not stable)
What do you think I should be able to get? (both max and 24/7)
tried for 4.5GHz (10x450), and it got just after the loading bar for windows before crashing,a nd that was at 1.56v!
